Hello,
I recently installed bspwm-manjaro package but when I try to login to bspwm the screen hangs. I can still move my mouse but that is about it. I added both of my monitors into the bspwmrc. What am I doing wrong?
Hello,
Can you access console with alt+ctrl+F3?
Yes I can. I can also switch back, but then there is just a black screen with a mouse cursor
Can you post the output of
systemctl status lightdm
Unit lightdm.service could not be found.
Aah, I had not read the OP correctly. I thought you were running bspwm edition.
What you are experiencing is the eexpected behavior of bspwm-manjaro. Bspwm is a Unix style window manager. It only manages windows, it doesn’t provide keybindings, draw desktop background or panels or anything like that. If you want something different than a black screen, you are going to have to set it up yourself.
That being said, bspwm-manjaro does have some automation,so the default keybindings should work. However,many of the default apps that the keybindings call might not be installed. Installing manjaro-bspwm-settings and sterminal should pull most of the needed stuff. You may still want to copy the relevant configs from /etc/skel to your home directory.
But if you want out of the box bspwm experience, just try the bspwm iso. It is much easier than setting up bspwm from scratch.
I see, for some reason bspwm leaves the login screen as a background image? That got me confused, but since I am able to now launch dmenu i think i should be ok. Guess just setting the wallpaper in bspwm will fix it. Thanks for your help
That moment when its so fast you dont realize anything has happened
“Is it frozen?”
“No … its finished.”
