Brother HL-L2350DW not able to add
Thanks for the Plasma6.0.5 update. My Brother HL-L2350DW usb/laser printer is detected perfectly. That AUR driver I could never get it to work. Great job!!
What is the actual problem that you seem to have?
Your topic title and post are a bit contradictory.
:thinking:
…and why are you using italics?
Sarcasm maybe? Who knows. At least i fixed the tags (it was in Forum Feedback?!)
Brother is generally a bit user friendlier than some other companies. There are deb and rpm packages for this printer, so it should be possible to adapt something as aur. But one has to do his research and ask specific questions.
Perhaps a simple Thanks for the feedback, and then a little closure. :man_shrugging:
