Brother DCP-L2550DW Laser Printer - How To Set Up?
Hi,
I just did a clean install of Manjaro KDE Plasma.
I am having great trouble in setting up a Brother DCP-L2550DW laser printer.
I installed the driver from AUR, and setup the printer, but print test page does not print?
Printer is connected by USB and wired network.
Would also like to be able to scan from the printer as well.
Any help would be appreciated, thank you!
Jesse
This is a network printer and scanner and does not really need a driver for the most functions.
So, you can just try to look for it in the printer settings - add new printer wizard and if it is connected to the network it should appear.
Pretty sure it is the same with the scanner part since i see airprint in the specs.
Maybe you are missing part of the printer support? The metapackage manjaro-printer, cups, avahi, mdns, sane, sane-airscan packages? Are those installed? And avahi service should be running.
Ok, I have printing working through local wired network…
… Sitll unable to scan, Scanlite says it can’t find the printer scanner?
Ok, after installing Skanlite flatpak, the scanning now works, thanks!
