Broken trash size limit when setting remember each folder
If the “Remember display style for each folder” option is set in dolphin settings, the trash can no longer takes size limits into account, displays warnings or performs actions such as automatic deletion.
preferences-general-behavior
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: udev.log_priority=3 acpi_enforce_resources=lax
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 info: kdocker wm: kwin_x11
vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Welcome to the Manjaro forum. Do you have reason to believe that this problem is specific to Manjaro? If not, you may have better luck raising the issue upstream on KDE Discuss or KDE Bugtracking.
The thing is that I just tried to reproduce the error by creating a new user and it doesn’t happen.
I don’t know if it is specific to manjaro. I’m going to try my luck in KDE.
It’s a bug…
https://bugs.kde.org/show_bug.cgi?id=478273
edited to actually link to the mentioned bug
