entered it, it had no output, i’m guessing it did something
Let’s check. Provide the output of:
cat /etc/default/grub
…again, please.
sir i personally wouldn’t know either, i specialize in huffing glue, all i know is my system is uefi and x86_64
this is the output of cat /etc/default/grub:
GRUB_DEFAULT=saved
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3g splash vt.global_cursor_default=0"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
#GRUB_ENABLE_CRYPTODISK=y
#GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
GRUB_TIMEOUT_STYLE="menu"
GRUB_TIMEOUT="10"
GRUB_THEME="/usr/share/grub/themes/Shodan/theme.txt"
It seems to have successfully removed it, then.
Now let’s update it. Still in the chroot
environment, run the following:
update-grub
If there were no errors, exit the chroot
exit
And reboot your PC.
I don’t know if it’ll work, but at least you won’t be worse off. I think.
But even if it does, I recommend that you backup your stuff and reinstall everything.
Could be the grub from the ventoy partition, did you choose a 32-bit version of ventoy?
(I’m not sure if it makes a difference to the Manjaro boot …)
alright, trying rn
ventoy is on a usb, i only plugged it in after grub went into grub rescue
it’s still in grub rescue and doesn’t boot
In that case, my knowledge has been depleted and I don’t know further. Personally, I’d have skipped all this, and just reinstalled everything.
i have a lot of programs and settings installed and games and passwords all saved there, isn’t there any way to completely remove grub and reinstall it, or any way of moving all my data? reinstalling and moving everything is going to take at least a whole week
There is a way to rescue it, most likely, but I don’t know more than we’ve done, so I honestly don’t know how to do it, or even what “it” is for that matter. I’ve given you all the links I could find here and I don’t have or know anything extra. Sorry.
Did you follow steps in GRUB/Restore the GRUB Bootloader - Manjaro ?
Looking at it, there are steps for BIOS vs EFI, the BIOS step has
root # grub-install --force --target=i386-pc --recheck --boot-directory=/boot /dev/sdy
whereas the EFI step has
root # grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
I think the BIOS step would end up with the error shown …
Did you follow the EFI step?
hello, it’s been a couple of days, it said that EFI variables are not supported on this system so efibootmgr failed to register the boot entry
can you recheck all option in your UEFI motherboard
create a profile for linux if possible
SecureBoot off
Fast Boot off
No CSM
No Legacy
all disks on AHCI
fTPM off ( Amd Ryzen )
for USB live iso
boot only on UEFI:<partition 1> → EFI install manjaro
you can check in terminal , before chroot
inxi -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
sudo lsblk -fs
sudo efibootmgr -v
sudo parted -l
so you are sure is it safe to apply those settings? i don’t want to break my system even more than it already is
this is the output of inxi -Fxza before chroot (as in inside the live usb’s terminal)
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2137 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1 rdinit=/vtoy/vtoy
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B450M DS3H V2 v: x.x
serial: <superuser required> BIOS: American Megatrends LLC. v: F61
date: 07/13/2021
Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
desc: 2x8 MiB
Speed (MHz): avg: 2172 high: 2344 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2344 2: 2052
3: 2053 4: 2196 5: 2195 6: 2196 bogomips: 43134
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 06:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.52x10.94")
s-diag: 525mm (20.66")
Monitor-1: HDMI-0 res: 1680x1050 hz: 60 size: N/A modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-4:2 chip-ID: 03f0:0b92 pcie:
class-ID: 0300 gen: 3 speed: 8 GT/s serial: <filter> lanes: 16
bus-ID: 06:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: HP HyperX Virtual Surround Sound type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-3:3 chip-ID: 0a12:0001 class-ID: e001
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 3-4:4 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci1 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.17 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD110
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7PD256HCGM-000H7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 6H6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB model: N/A size: 7.5 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: 2.00
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Generic model: Flash Disk
size: 7.5 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 47.6 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Processes: 258 Uptime: 23m wakeups: 0 Memory: 15.56 GiB used: 3.66 GiB
(23.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1156 lib: 320
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.20
“test -d /sys/firmware/efi && echo efi || echo bios” 's output:
bios
the output of sudo lsblk -fs
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda1 ext4 1.0 15bcc38a-c5fd-402c-a04d-6bb8e3a0d676
└─sda
sda2 ext4 1.0 634b77fc-47d7-4969-bcec-9e2ec94d8907
└─sda
sda7 ext4 1.0 p3 9b98e355-79d1-473a-b03a-a7a3d3b2c314
└─sda
sda8 ext4 1.0 71a2b10d-4f8e-4acb-bcd5-49227782de2f
└─sda
sdb1 vfat FAT32 NO_LABEL D2C5-272C
└─sdb
sdb2 ext4 1.0 MOOOON a07ad4de-42e0-4649-858a-266965f2e1aa
└─sdb
sdb3 swap 1 swap 11e0da9a-9c9c-4711-8847-bc08ac54f8c9
└─sdb
sdc2 vfat FAT16 VTOYEFI C559-2E5D
└─sdc
sdd ext4 1.0 31ce81ea-f3ea-40ba-8b2a-367bf6134ad9
sde1 vfat FAT32 32EE-A032
└─sde
ventoy iso9660 Joliet Extension MANJARO_XFCE_2137 2022-08-16-12-55-20-00 0 100% /run/miso/bootmnt
└─sdc1 exfat 1.0 Ventoy EBC0-A722
└─sdc
running sudo efibootmgr -v gives:
EFI variables are not supported on this system.
error trace:
and sudo parted -l gives:
error trace:
and i also ran fdisk -l /dev/sdb (sdb is my root directory’s disk) which gave me this:
Disk /dev/sdb: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: SAMSUNG MZ7PD256
Disklabel type: gpt
Disk identifier: A4005191-8973-1747-ABD1-48BEA97D5D8B
Device Start End Sectors Size Type
/dev/sdb1 4096 618495 614400 300M EFI System
/dev/sdb2 618496 481648510 481030015 229.4G Linux filesystem
/dev/sdb3 481648511 500103449 18454939 8.8G Linux swap
and when i open gparted i see that i have fat32 partition on my disk (which has my root directory which i’m trying to boot into) with it’s flags being: “boot, esp”
you have booted in Bios , not UEFI as required , also there is update four your motherboard
see GIGABYTE B450M DS3H V2 Motherboard|GIGABYTE
( it should be F62 or F63 ) , not forget to reset settings
create a USB live iso with DD ( be very careful before that , always recheck sudo fdisk -l for name /dev/sdX )
i’m using a manjaro live usb, my actual system is uefi, also do i really need to update my bios? power tends to go out a lot where i live with no notice and i don’t want my system to be turned into expensive paper weight
what is “DD”?
so for your understanding
- you have first installed in UEFI , becaause sdb is GPT and there is /boot/efi with flag boot&esp
- your options in boot UEFI motherboard is bad for your Live USB iso , so you force to boot in Bios mode,
for that you CANT restore GRUB in UEFI , and you CANT install bios on GPT
question 1 : are you using a USB live iso ?
question 2 : is it a ventoy install or something else
question 3 : in case of ventoy without GPT and efi ( see ventoy -h) , can you get another USB live iso with GPT and Efi boot?
you have to boot your USB live iso in UEFI for Restore GRUB in UEFI.
