My laptop’s (Lenovo Thinkpad E15) screen backlight brightness adjustment doesn’t work. It’s fixed at 100% all the time. Slider moves but brightness doesn’t change.
I tried a solution of an older thread: adding a pararameter (i915.enable_dpcd_backlight=0) to my grub but this didn’t solve my issue. I guess because i915 relates to intel drivers?
This has been going on forever even when I was on older kernel versions.
Also, my CPU fan never spins even when reaching temperatures around 70°C. It does in windows though.
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM
Type: Laptop System: LENOVO product: 20T9S01800 v: ThinkPad E15 Gen 2
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20T9S01800 serial: <filter> UEFI: LENOVO
v: R1AET37W (1.13 ) date: 04/09/2021
ID-1: BAT0 charge: 20.0 Wh (46.7%) condition: 42.8/45.7 Wh (93.5%)
volts: 11.1 min: 11.1 model: SMP 5B10X026 serial: <filter>
status: Discharging
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 rev: 1 cache: L2: 4 MiB
bogomips: 31958
Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1636
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6c2
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.15-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 04:00.1 chip-ID: 1002:1637
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A bus-ID: 04:00.5 chip-ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0
chip-ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus-ID: 02:00.0 chip-ID: 8086:2723
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-4:2 chip-ID: 8087:0029
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 931.51 GiB used: 26.06 GiB (2.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 24.9 C
ID-1: / size: 456.89 GiB used: 26.06 GiB (5.7%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 511 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5
System Temperatures: cpu: 29.2 C mobo: N/A gpu: amdgpu temp: 28.0 C
Fan Speeds (RPM): fan-1: 0
Processes: 280 Uptime: 0m Memory: 14.86 GiB used: 1.99 GiB (13.4%)
Init: systemd v: 249 Compilers: gcc: 11.1.0 Packages: pacman: 1137
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
