Brightness and sleep don't work after update
Hi! I recently switched to linux59 and I’ve started to notice that my laptop isn’t waking up from sleep (my keyboard lights up, but the screen remains black) and that my screen brightness controls have stopped working (I get the pop up whenever I adjust the brightness, but it doesn’t seem to have any effect). This only seems to happen when I’m using linux59 (I tried to replicate it with linux54 and linux58 unsuccessfully), so I’m guessing it has something to do with that.
I’m a bit new to manjaro, so I’d greatly appreciate any help.
Thanks!
Here’s the output from inxy -Fazy:
  Kernel: 5.9.8-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=e9c9fb12-ffc1-41ca-aa43-3fc96f3990dd rw quiet apparmor=1
  security=apparmor resume=UUID=3fde0643-e8fe-4d07-9fa0-b1c90a6aadc2
  udev.log_priority=3
  Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 info: latte-dock wm: kwin_x11
  dm: SDDM Distro: Manjaro Linux
  Type: Convertible System: LENOVO product: 81CU v: Lenovo YOGA 730-15IKB
  serial: <filter> Chassis: type: 31 v: Lenovo YOGA 730-15IKB serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
  UEFI: LENOVO v: 7KCN30WW(V1.11) date: 05/24/2019
  ID-1: BAT1 charge: 38.8 Wh condition: 41.0/51.6 Wh (79%) volts: 12.9/11.2
  model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x PABAS0241231 type: Li-ion
  serial: <filter> status: Charging
  Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: E0
  L2 cache: 8192 KiB
  bogomips: 32012
  Speed: 624 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
  4: 700 5: 700 6: 700 7: 700 8: 700
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5917
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
  driver: nvidia v: 450.80.02 alternate: nouveau,nvidia_drm bus ID: 3b:00.0
  chip ID: 10de:1c8d
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-5:3
  chip ID: 04f2:b61e serial: <filter>
  Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
  driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 192 s-size: 508x285mm (20.0x11.2")
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 3840x2160 dpi: 283 size: 345x194mm (13.6x7.6")
  diag: 396mm (15.6")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.2
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71
  Sound Server: ALSA v: k5.9.8-2-MANJARO
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be
  port: 4000 bus ID: 3a:00.0 chip ID: 10ec:b822
  IF: wlp58s0 state: up mac: <filter>
  Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
  bus ID: 2-1.3:4 chip ID: 0b95:1790 serial: <filter>
  IF: enp0s20f0u1u3 state: down mac: <filter>
  Local Storage: total: 2.29 TiB used: 183.30 GiB (7.8%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000L2
  size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 serial: <filter> rev: 5L1QEXA7 scheme: GPT
  ID-2: /dev/sda type: USB vendor: Western Digital model: WD My Passport 25E1
  size: 1.82 TiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1021 scheme: GPT
  ID-1: / raw size: 459.74 GiB size: 451.52 GiB (98.21%)
  used: 183.30 GiB (40.6%) fs: ext4 dev: /dev/nvme0n1p2
  ID-1: swap-1 type: partition size: 16.90 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3
  System Temperatures: cpu: 42.5 C mobo: N/A
  Processes: 245 Uptime: 3m Memory: 15.36 GiB used: 2.30 GiB (14.9%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
  pacman: 1472 lib: 419 flatpak: 0 Shell: Zsh v: 5.8 running in: kitty
  inxi: 3.1.08
Hello,
Make sure you follow this:
https://wiki.archlinux.org/index.php/Lenovo_yoga_730#Suspend
Hi,
I have been using Manjaro for a little while now and I am seeing a lot of problems with upgrading and kernel upgrades above the LTS. The newest kernel 5.9.10 and the first one before it 5.9.8? sleep does not work for me. If you put it to sleep or it does itself after time, my screen opens to black and the only thing I could do was it ctrl-alt-delete, maybe. it would shut down. or I just had to hold the power button for 10 seconds to kill it and then restart. It is unusable. I had to go back to the LTS 5.4.x kernel and that works.
other problems I have had with newer kernels are that suspend does not even suspend. I close the lid and the system keeps running. I have had my laptop get extremely hot which also seems to be a kernel version issue.
I generally like to upgrade when they come, but I find that is just not safe with Manjaro.
If you upgraded a kernel and need to back out/change the one used you can add or remove kernels
in Manjaro Settings, pick kernels. then install/remove
then to set your boot up defaults; install and run: grub-customizer
