Bright UI in Darktable
Hello,
I installed darktable 4.0.0 from the official repository but found that the interface is so bright. Anyone know how to fix it?
You should have ability to change it in Darktable preferences.
Thanks. I really forgot where the preference page is :sweat_smile: . Changing the theme solved the problem.
