Breath theme broken?
#1
I have now small icons in the taskbar an dthe tooltip looks like not machting the theme.
All i did is changed for curiosity reasons from breath to breeze* theme and beside that i tryed the new “look and feel” theme option from kde
#2
I’m running Breath on all my KDE installs, both Stable on Unstable branches. I can’t replicate this.
Did you try rebooting? Maybe some cache is messed up.
#3
After rebooting and reinstalling the breath theme stuff nothing changed (altough the wallapper, because i like it more).
I have small icons and grey tooltip…
#4
I have the same size icons in my launcher. It’s not small in my opinion.
The right click menu is because of the theme. You are using the normal color one. I use the Breath Dark color one, which has dark tooltips/right click menus.
#5
Is there a way to change the icon size? Because the icons were bigger before (from scratch there were as small as one, but after an update they got “bigger”).
Actually i cannot change to the dark “right click menu” (see pic)
#6
How did you install the theme? With plasma5-breath-themes?
#7
yes, see attached:
#8
Here’s what mine looks like:
#9
So sth is wrong…
#10
If you go into System Settings - > Appearance -> Color do you have a Breath and a Breath Dark, or just a Breath?
#11
there was a dark colour sheme so i applyed this. thx
But in general this hole theme-setting stuff is annoying. In my opionion it is too complicated.
If i want a dark theme i want too choose it just once and all the stuff wich is related to this theme should be apllied automatically. Otherwise you have too click trhough at least 3 options in system-settings.
Beside that there should be a option for the taskbar to choose the icon size. Right now the only way to do this is to resize the panel.
#12
Well. That’s just how KDE theming works. You should mention it to the kde.org people.
#13
Thx i know. I will do that.
