Hi
after 2020-11-18 update I have problem booting from luks encrypted volume. using kernel 5.9 after grub when kernel must boot it says ERROR /dev/mapper/luks… not found. I was suspecting on kernel installed kernel 5.4 from live system. But have same issue. there is no /dev/mapper directory at all. Could someone help please?
downgrading kernel and grub to previous working version did not help
as mentioned here
encrypt
must be added to mkinitcpio.conf and to avoid entering password twice add FILES=(/crypto_keyfile.bin)
to the same file.
