Hi,
Normally it should update every 4 or so I guess?
Last update was more than two days ago it seems.
Last Updated: 2021-01-13 02:59 12742 packages
btw. Is it UTC or local time? (maybe timezone should be added)
kind regards,
MO
Hi,
kind regards,
MO
No idea how often it gets updated, but you can check out branch-compare code in the GitLab repo to check.
I assume it’s UTC time, but yes, it would be nice to get the time zone added so that people know which it is.
You can’t see that there. It’s fetching .json from the server and you don’t know how often the file is updated there. I’m pretty sure it usually updates multiple times per day though…
btw.: This is not a complaint or anything like that. I just wanted to bring it to the attention of the manjaro team to check…
“date” is the mirror last update and not last branch-compare cron
cron code is here
Error is not in compare-branche but is ssl certificate mirror
curl https://mirror.netzspielplatz.de/manjaro/packages
curl: (60) SSL certificate problem: certificate has expired
Aha, they use that mirror to make the list.
That explains it
Expires On
Wednesday, January 13, 2021 at 5:55:50 AM
Got fixed in the meanwhile.
Seems to be UTC time.
