Botched dual boot
Good Evening, I have botched my GRUB reinstall and i am at a wall. To start off i had a working UEFI dual boot installation Manjaro KDE and WIN10. I upgraded my spinning rust for a SSD in my windows install. After reinstalling windows i attempted to reinstall the grub from manjaro (live). I tried to chroot into the system only to get the “windows did not shut down properly”. I think this is where i screwed up. I attempted a nonEFI grub install (large sigh). After finding out that my windows installation was in hybrid sleep i tried the grub install again. And now i am completely lost as to what to do.
I can run manjaro live and chroot into the root directory. Also i can mount /dev/sda3 as /mnt but i can only mount /dev/sda1 as /boot/efi.
I would really prefer not to have to reinstall manjaro if i can learn something here.
@1slotrk, welcome here.
First, you have to find a way to boot into your Windoze install and shut it down fully (switch off all Fastboot and hibernate features). Little chances to repair your system if your Windoze has only hibernated as it will lock essential parts of your file system. How to do - best ask in a Windoze forum (or hope for some other forum members to assist).
I have shut both of those features off. Also I can get in and out of my windows just fine. Also thank for the warm welcome.
Do you still
error message?
When running a live ISO please enter the following commands and post it here:
inxi -Fxxxza --no-host
sudo parted -l
sudo blkid
Use “~~~” in front and at the end to format the output nicely.
Have you tried chrooting using manjaro-chroot?
https://wiki.manjaro.org/index.php?title=GRUB/Restore_the_GRUB_Bootloader
Can you 100% confirm that both OS are installed in UEFI mode?
           parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
           misolabel=MANJARO_KDE_202 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
           i915.modeset=1 radeon.modeset=1
           Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: MSI model: Z87-G45 GAMING (MS-7821) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.9
           date: 07/21/2014
CPU:       Info: Quad Core model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
           stepping: 3 microcode: 28 L2 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 64025
           Speed: 800 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 801 7: 801 8: 801
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: eVga.com. driver: nouveau v: kernel bus ID: 01:00.0
           chip ID: 10de:17c8
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nouveau unloaded: modesetting
           alternate: fbdev,nv,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
           Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
           Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
           OpenGL: renderer: NV120 v: 4.3 Mesa 20.2.3 direct render: Yes
Audio:     Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:8c20
           Device-2: NVIDIA GM200 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:0fb0
           Sound Server: ALSA v: k5.9.11-3-MANJARO
Network:   Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
           bus ID: 03:00.0 chip ID: 1969:e091
Drives:    Local Storage: total: 6.61 TiB used: 156.8 MiB (0.0%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT
           ID-2: /dev/sdb vendor: SanDisk model: SSD PLUS 1000GB size: 931.52 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 00RL scheme: GPT
           ID-3: /dev/sdc vendor: Seagate model: ST4000DM000-1CD168 size: 3.64 TiB block size: physical: 4096 B logical: 512 B
           speed: 6.0 Gb/s rotation: 5900 rpm serial: <filter> rev: CC43 scheme: GPT
           ID-4: /dev/sdd vendor: Kingston model: SA400S37480G size: 447.13 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 71B1 scheme: MBR
           ID-5: /dev/sde vendor: Seagate model: ST31500541AS size: 1.36 TiB block size: physical: 512 B logical: 512 B
           speed: 3.0 Gb/s rotation: 5900 rpm serial: <filter> rev: CC95 scheme: MBR
           ID-6: /dev/sdi type: USB vendor: Lexar model: USB Flash Drive size: 29.82 GiB block size: physical: 512 B
           logical: 512 B serial: <filter> rev: 1100 scheme: MBR
Partition: ID-1: / raw size: N/A size: 11.68 GiB used: 156.8 MiB (1.3%) fs: overlay source: ERR-102
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 29.0 C
           Fan Speeds (RPM): N/A gpu: nouveau fan: 750
Info:      Processes: 251 Uptime: 2m Memory: 15.58 GiB used: 1.10 GiB (7.1%) Init: systemd v: 246 Compilers: gcc: N/A
           Packages: pacman: 1224 lib: 332 flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.0
parted -l
Disk /dev/sda: 250GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      1049kB  525MB   524MB   fat32                 msftdata
 2      525MB   4720MB  4194MB  linux-swap(v1)        swap
 3      4720MB  250GB   245GB   ext4
Model: ATA SanDisk SSD PLUS (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
 1      1049kB  106MB   105MB   fat32        EFI system partition          boot, esp
 2      106MB   123MB   16.8MB               Microsoft reserved partition  msftres
 3      123MB   1000GB  1000GB  ntfs         Basic data partition          msftdata
 4      1000GB  1000GB  523MB   ntfs                                       hidden, diag
Model: ATA ST4000DM000-1CD1 (scsi)
Disk /dev/sdc: 4001GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
 1      1049kB  4001GB  4001GB  ext4         storage2
Model: ATA KINGSTON SA400S3 (scsi)
Disk /dev/sdd: 480GB
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  480GB  480GB  primary  ntfs
Model: ATA ST31500541AS (scsi)
Disk /dev/sde: 1500GB
Disk Flags:
 1      1049kB  1500GB  1500GB  primary  ext4
Model: Lexar USB Flash Drive (scsi)
Disk /dev/sdi: 32.0GB
Disk Flags:
 2      3103MB  3107MB  4194kB  primary               esp
blkid
/dev/sda2: UUID="cef85e92-9280-44af-a839-d03387fd97de" TYPE="swap" PARTUUID="77428456-bc89-4e8e-8804-4d908ad93bc3"
/dev/sda3: UUID="ef097c30-9d55-4044-8fe6-bbfbab62e2f8" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="f7b6bde7-7698-2b48-80c9-ef0eec8bfbbb"
/dev/sdb1: UUID="3A44-BAA1" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="75f19ab2-f5c3-49b7-997b-6f76096e30de"
/dev/sdb3: BLOCK_SIZE="512" UUID="2A4E57144E56D7E1" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="375ca82d-bcba-49da-8356-fd9b5a3a03b6"
/dev/sdb4: BLOCK_SIZE="512" UUID="40660D6E660D65CE" TYPE="ntfs" PARTUUID="8515a63d-c45b-4496-9fe9-dc438447f513"
/dev/sdc1: UUID="7c93022f-a023-4bb5-8936-ed35280af2b5" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="storage2" PARTUUID="5119a315-dca5-40bb-bdd7-d56b2f2c9be6"
/dev/sdd1: LABEL="Games" BLOCK_SIZE="512" UUID="42383B0B0009D112" TYPE="ntfs" PARTUUID="e479c673-01"
/dev/sde1: LABEL="Storage3" UUID="a5d19aca-d1e7-4c5f-850b-d7ff92454be0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="0d39669e-01"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/sdi1: BLOCK_SIZE="2048" UUID="2020-12-07-13-36-18-00" LABEL="MANJARO_KDE_202" TYPE="iso9660"
/dev/sdi2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="EC08-A711" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdb2: PARTLABEL="Microsoft reserved partition" PARTUUID="79dc6e96-a27b-4ab9-b605-f7c3322f26ba"
I would love to say i know 100% how to verify both OSs are in UEFI but i do not. Windows for sure is and to the best of my knowledge manjaro was as well. BTW “~~~” WINNING
Here are my comments:
In your case I would check if a fresher firmware is available for your motherboard.
When you installed Manjaro did you choose the proprietary drivers?
It seems your OS are on different drives which is good. On your Manjaro EFI I miss the boot flag:
Change this and you should assign the disk sda as boot device in your firmware to see if you can boot into Manjaro. If this does not work I would try to restore the boot loader into sda1. Make sure Secure boot is disabled in your firmware, as well.
I am on my latest firmware. Check
Yes i did use proprietary drivers, they seem to work better. What is the advantage of FOSS drivers?
I will dig around on how to change that flag and report back. Thanks so much for the help.
Secure boot is already disabled
Results of manjaro-chroot -a
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: special device /dev/disk/by-uuid/D894-250B does not exist.
 --> mount: [/mnt/run/media/games]
fuse: failed to access mountpoint /mnt/run/media/games: No such file or directory
nano /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=ef097c30-9d55-4044-8fe6-bbfbab62e2f8 /              ext4    defaults,noatime 0 1
UUID=D894-250B                            /boot/efi      vfat    umask=0077 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
UUID=42383B0B0009D112                    /run/media/games     ntfs-3g    user,exec         0 0
Something looks wrong with your /dev/sda1. As long as you have not just truncated the output of sudo blkid it’s missing there. On the other hand it’s shown from parted -l. Also not good is this:
Just double check please by re-entering sudo blkid. Compare the UUID of /dev/sda1 with your /etc/fstab. if the partition /dev/sda1 is borked you could re-create it and try to re-install the grub bootloader.
Hi, @1slotrk
To verify if your Manjaro is in EFI mode:
test -d /sys/firmware/efi && echo efi || echo bios
@Wollie, this is my EFI partition seen by parted -l:
1 1049kB 211MB 210MB fat32 msftdata
My system also does not have the boot flag and despite this it works normally… :thinking:
Alrighty, got manjaro to boot back up. I’m in it now. But for some reason the bootloader did not pop up as it normally does. (apparently i can’t embed photos)
https://photos.app.goo.gl/qD2K8k8danyLAVXe6
That is the boot selection screen. Notice UEFI OS and manjaro!!! If i boot from the UEFI OS then it drops me to the grub rescue. If i boot from the manjaro one, i boot straight into manjaro.
FYI the UUID i had listed in fstab was incorrect. Apparently grub had written itself to the hard drive that my old windows install was on. I’m very interested to know why.
