Boots into tty after update
After system updates my computer boots straight to tty. Logging in there and typing exec xfce4 starts the DE, and everything works fine (so it seems). I’d like to get it back to booting to a graphical login screen if possible.
Hi @Ermac ,
Can you show the output of:
systemctl status lightdm.service
startxfce4 would also work,
from TTY,
when the display manager (lightdm) would not work for some reason.
There was nothing in an update that could have caused lightdm to fail :man_shrugging:
Perhaps it’s something related to Nvidia graphics in your system?
inxi -zv8
could help to clarify
output:
○ lightdm.service - Light Display Manager
     Loaded: loaded (/usr/lib/systemd/system/lightdm.service; disabled; preset:>
     Active: inactive (dead)
       Docs: man:lightdm(1)
edit - no nvidia card, just intel integrated graphics.
The lightdm service is disabled.
To enable do:
systemctl enable lightdm.service
Reboot.
Got this. This computer sat for a while without updates, at least a few months. Not an ideal situation, I know. Thanks for the help trying to get it back up to speed.
Failed to enable unit: File '/etc/systemd/system/display-manager.service' already exists and is a symlink to /usr/lib/systemd/system/lightdm-plymouth.service
probably much longer
That service doesn’t exist here, for me.
even this:
doesn’t exist here
but that could be due to the fact that I have removed plymouth
@Ermac
Did you install a plymouth theme/service?
Can you give full output of
Because it could give hints we don’t see now.
Same output as above. plymouth and plymouth-theme-manjaro-elegant packages are installed.
To fix the error the link should be removed.
When you use lightdm, try the next.
First, check what’s actually there:
ls -la /etc/systemd/system/display-manager.service
Then remove the stale symlink and re-enable properly:
sudo rm /etc/systemd/system/display-manager.service
sudo systemctl enable lightdm.service
In case of plymouth
sudo systemctl enable lightdm-plymouth.service
Thank you! The ls command confirmed it was a symlink; the next two commands were successful and lightdm was back on reboot.
Very much appreciate the patience and speedy replies. :slightly_smiling_face:
Great it worked out!
One small request for next time: when we ask for the output of a command, please paste the full output in your reply — it makes troubleshooting a lot easier and faster for everyone. Much appreciated, and happy to help you again!
