Hey everyone,
I recently installed Manjaro again and now wanted to suspend my computer.
However, what I’ve noticed is that the computer never goes to sleep (like it does on Windows) but instead it shows the OEM screen of my motherboard and then boots right back into the login manager of Manjaro.
Is this a common issue or did I forget to turn something on?
Specs:
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=88548ddb-bee4-4038-8fe9-c216d7a40bbe rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 nvidia-drm.modeset=1
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Desktop System: Micro-Star product: MS-7D25 v: 1.0 serial: N/A
Mobo: Micro-Star model: PRO Z690-A DDR4(MS-7D25) v: 1.0 serial: <filter>
UEFI: American Megatrends LLC. v: 1.10 date: 12/13/2021
Device-1: hidpp_battery_0 model: Logitech G502 X LIGHTSPEED serial: <filter>
charge: 80% rechargeable: yes status: discharging
System RAM: total: 64 GiB available: 62.6 GiB used: 3.68 GiB (5.9%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Controller0-DIMMA1 type: DDR4 detail: synchronous size: 16 GiB
speed: 3600 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: KF3600C16D4/16GX serial: <filter>
Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 16 GiB
Device-3: Controller1-DIMMB1 type: DDR4 detail: synchronous size: 16 GiB
Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 16 GiB
Info: model: 12th Gen Intel Core i7-12700K socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake gen: core 12 level: v3 note: check
built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151)
stepping: 2 microcode: 0x32
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 833 high: 1487 min/max: 800/4900:5000:3800
base/boost: 3564/8500 scaling: driver: intel_pstate governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800 9: 800 10: 792 11: 800 12: 800 13: 800 14: 1487
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 144440
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq
pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep
smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1
xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915 v: kernel
ports: active: none empty: DP-4, DP-5, HDMI-A-2, HDMI-A-3, HDMI-A-4, HDMI-A-5
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 545.29.06
alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current (as of
2023-11; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2488 class-ID: 0300
Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Dell S3423DWC
serial: <filter> built: 2023 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 640x480
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-4: Audient EVO4 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1:5 chip-ID: 2708:0006
class-ID: fe01
Device-5: Samson Q2U handheld mic with XLR
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.2:7 chip-ID: 17a0:0304 class-ID: 0300
Device-6: SteelSeries ApS Arctis 7+
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.3.1.1.4:16 chip-ID: 1038:220e class-ID: 0300
API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.0 status: n/a (root, process) with:
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0bda:8771
Local Storage: total: 4.1 TiB used: 39.77 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QEXP7 temp: 41.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung
fw-rev: 4B2QEXM7 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 122.99 GiB size: 120.5 GiB (97.98%) used: 39.74 GiB (33.0%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:8 label: N/A
uuid: 88548ddb-bee4-4038-8fe9-c216d7a40bbe
used: 26.7 MiB (27.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:4 label: N/A uuid: 08FA-247B
ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:6 size: 353.03 GiB fs: ntfs label: N/A
uuid: 1ABCFAE4BCFAB979
ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 815 MiB fs: ntfs label: N/A
uuid: 622418B424188D63
ID-4: /dev/nvme1n1p1 maj-min: 259:9 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-5: /dev/nvme1n1p2 maj-min: 259:10 size: 1.82 TiB fs: ntfs
label: M2 SSD 2TB uuid: 3AC0BA4BC0BA0CDF
ID-6: /dev/nvme2n1p1 maj-min: 259:1 size: 1.82 TiB fs: ntfs
label: M2 SSD 2TB 2 uuid: 0470FCEF70FCE876
Device-1: 1-2:2 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d25 class-ID: 0300
serial: <filter>
Hub-2: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.1:5 info: Audient EVO4 type: audio driver: snd-usb-audio
interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 2708:0006 class-ID: fe01
Device-2: 1-5.2:7 info: Samson Q2U handheld mic with XLR type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Hub-3: 1-5.3:8 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Hub-4: 1-5.3.1:12 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Hub-5: 1-5.3.1.1:13 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
Device-1: 1-5.3.1.1.1:14 info: Logitech PowerPlay Wireless Charging System
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
chip-ID: 046d:c53a class-ID: 0300
Device-2: 1-5.3.1.1.2:15 info: Keychron V1 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0310 class-ID: 0300
Device-3: 1-5.3.1.1.4:16 info: SteelSeries ApS Arctis 7+ type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
Device-4: 1-5.3.4:11 info: Realtek HID Device type: HID
chip-ID: 0bda:1100 class-ID: 0300
Device-5: 1-8:4 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Hub-6: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-13.2:9 info: NZXT USB Device type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2007 class-ID: 0300
serial: <filter>
Device-2: 1-13.3:10 info: NZXT USB Device type: HID
driver: nzxt-smart2,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1e71:2010 class-ID: 0300
serial: <filter>
Hub-7: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 430 Uptime: 0m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1427
pm: pacman pkgs: 1419 libs: 341 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 8 Shell: Sudo (sudo) v: 1.9.15p4 default: Bash v: 5.2.21
running-in: kitty inxi: 3.3.31
