this is the output from the inxi command (I took off Audio, Network and bluetooth):
Host: manjaro Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2116 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Dell G15 5515 v: 1.4.0
serial: <superuser required> Chassis: type: 10 v: 1.4.0
Mobo: Dell model: 066VKM v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 07/20/2021
ID-1: BAT1 charge: 86.0 Wh (100.0%) condition: 86.0/86.0 Wh (100.0%)
volts: 13.1 min: 11.4 model: Simplo 0x46,0x39,0x35,0x41,0x0B,0x0A,0x0005
type: Li-ion serial: 0005 status: Full
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB
bogomips: 102241
Speed: 1197 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
1: 1197 2: 1197 3: 1197 4: 1197 5: 1197 6: 1195 7: 1450 8: 1197 9: 1197
10: 1197 11: 1197 12: 1197 13: 1396 14: 1397 15: 1197 16: 1197
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:2560 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.4x7.5")
s-diag: 391mm (15.4")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Local Storage: total: 1.4 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: A-Data model: IM2P33F3A NVMe 512GB
lanes: 4 type: SSD serial: DL402J32Y6NK rev: 92103061 temp: 29.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 953.87 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: 2L3929A8KKLR rev: 3.2.F.2A scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB model: USB DISK 2.0 size: 7.21 GiB
block-size: physical: 512 B logical: 512 B type: N/A
serial: 07086B96441C4C69 rev: PMAP scheme: MBR
Message: No partition data found.
Message: No sensor data found. Is lm-sensors configured?
Processes: 359 Uptime: 4m wakeups: 302 Memory: 62.66 GiB
used: 3.01 GiB (4.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1229 lib: 331 flatpak: 0 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.07
this from parted -l:
Model: USB DISK 2.0 (scsi)
Disk /dev/sda: 7745MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 3475MB 3479MB 4194kB primary esp
Model: IM2P33F3A NVMe ADATA 512GB (nvme)
Disk /dev/nvme0n1: 512GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 158MB 157MB fat32 EFI system partition boot, esp
2 158MB 293MB 134MB Microsoft reserved partition msftres
3 293MB 493GB 492GB Basic data partition msftdata
4 493GB 494GB 1038MB ntfs hidden, diag
5 494GB 511GB 16.9GB ntfs hidden, diag
6 511GB 512GB 1452MB ntfs hidden, diag
I wanto to install Manjaro in this ssd:
Model: XPG GAMMIX S70 BLADE (nvme)
Disk /dev/nvme1n1: 1024GB
Disk Flags:
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 1015GB 1014GB ext4 root
3 1015GB 1024GB 9449MB linux-swap(v1) swap
This is test -d:
test -d /sys/firmware/efi && echo efi || echo bios
efi
and finally, efibootmgr:
Timeout: 0 seconds
BootOrder: 0005,0000,0001
Boot0000* EFI PXE 0 for IPv4 (60-18-95-34-37-66) PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/MAC(601895343766,0)/IPv4(0.0.0.00.0.0.0,0,0)RC
Boot0001* EFI PXE 0 for IPv6 (60-18-95-34-37-66) PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/MAC(601895343766,0)/IPv6([::]:<->[::]:,0,0)RC
Boot0005* Windows Boot Manager HD(1,GPT,0a6b0f22-02f6-4aee-88b0-8d3c24b2b12a,0x800,0x4b000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.
O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}....................
sorry for the amount of info…
