mounted or unmnounted?
Unmounted.
well… it works partly.
After chrooting and mount /dev /sys and /proc the grub-mkconfig command was possible.
[manjaro /]# grub-mkconfig -o boot/grub/grub.cfg
Found background: /usr/share/grub/background.png
Found linux image: /boot/vmlinuz-lts
Found linux image: /boot/vmlinuz-5.4.0-58-generic
Found initrd image: /boot/initrd.img-5.4.0-58-generic
Found linux image: /boot/vmlinuz-5.4.0-56-generic
Found initrd image: /boot/initrd.img-5.4.0-56-generic
Found Alpine Linux v3.13 on /dev/sda2
Found Windows 10 on /dev/sda3
done
Windows works.
What is the “partly” part of it?
- the manjaro entry of grub-mkconfig does not boot and gives an error about “some modules”. I can’t tell it better for now.
- the Alpine entry hangs having detected a USB keybord and USB mouse.
I will do a little reinstall of 2 machines without a shared BOOT partition.
I will have it easier then I hope.
haha
PS:
the lts kernel is the Alpine one btw
Whats about using /etc/grub.d/40_custom for chainloading second linux?
(Standard with Windoofs as second OS)
sounds good.
For Alpine:
menuentry "Alpine Linux" {
set root=(hd0,3)
linux /boot/vmlinuz-hardened root=UUID=8de6973a-4a8c-40ed-b710-c4e2b42d6b7a modules=sd-mod,usb-
storage,ext3 quiet
initrd /boot/initramfs-hardened
How would that be for a Manjaro Linux?
The parts for Manjaro linux should be in /boot/grub/grub.cfg
Chainloading of ONE system is required AFAIK.
(One system is the Big Boss - the other the humble slave)
to add win I would do the following in 40_custom
menuentry "Microsoft Windows Vista/7/8/8.1/10 BIOS/MBR" {
insmod part_msdos
insmod ntfs
insmod ntldr
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 XXXXXXXXXXXXXXXX
ntldr /bootmgr
hd0,msdos1
equivalent sda1
There is one more thing. I have a last issue with grub. Can u tell me, why the custom entry for ALPINE linux is not recognized by grub mkconfig?
Manjaro environment:
[siserhost grub.d]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
Found Windows 10 on /dev/sda4
done
[siserhost grub.d]# awk -F\' '/menuentry / {print $2}' /boot/grub/grub.cfg
Manjaro Linux
Manjaro Linux (Kernel: 5.9.16-1-MANJARO x64)
Manjaro Linux (Kernel: 5.9.16-1-MANJARO x64 - fallback initramfs)
Manjaro Linux (Kernel: 4.19.167-1-MANJARO x64)
Manjaro Linux (Kernel: 4.19.167-1-MANJARO x64 - fallback initramfs)
Windows 10 (on /dev/sda4)
[siserhost grub.d]# nano 40_custom
[siserhost grub.d]# cat 40_custom
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
#echo "Adding Alpine" >&2
#cat << EOF
set root=(hd0,1)
linux vmlinuz-lts root=UUID=c74d472c-858e-478d-ab30-dbd59714bfa5 modules=sd-mod,usb-storage,ext4 quiet
initrd initramfs-lts
set root=(hd0,1)
linux vmlinuz-lts root=/dev/sda2 modules=sd-mod,usb-storage,ext4 quiet
menuentry "Windows 10 AMELIORATED" --class windows --class os {
insmod part_msdos
insmod ntfs
insmod ntldr
search --no-floppy --fs0uid --set=root --hint-bios=hd0,msdos3
ntldr /bootmgr
EOF
[siserhost grub.d]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 223.6G 0 disk
├─sda1 8:1 0 1G 0 part
├─sda2 8:2 0 8G 0 part /mnt/alpine
├─sda3 8:3 0 100G 0 part /
└─sda4 8:4 0 114.6G 0 part
sdb 8:16 0 558.9G 0 disk
├─sdb1 8:17 0 32G 0 part
├─sdb2 8:18 0 16G 0 part [SWAP]
├─sdb3 8:19 0 100G 0 part /mnt/share
└─sdb4 8:20 0 410.9G 0 part /mnt/lbry
sr0 11:0 1 1024M 0 rom
[siserhost grub.d]#
mount /dev/sda1 boot/
[siserhost boot]# ls
boot extlinux.conf initramfs-lts ldlinux.sys libutil.c32 mboot.c32 System.map-lts vmlinuz-lts
config-lts extlinux.conf.multiboot ldlinux.c32 libcom32.c32 lost+found menu.c32 vesamenu.c32
That is normal. Its only the output, the command will work nevertheless.
SOLVED
This is a proper entry for Grub2:
cat /etc/grub.d/40_custom
#!/bin/sh
exec tail -n +3 $0
insmod part_msdos
insmod ntfs
insmod ntldr
search --no-floppy --fs-uuid 06C8CA483EAF8327 --set=root --hint-bios=hd0,msdos3
ntldr (hd0,msdos3)/bootmgr
EOF
This not: (on some systems):
if [ "${grub_platform}" == "pc" ]; then
insmod part_msdos
insmod ntfs
insmod ntldr
ntldr /bootmgr
fi
… because the “ntldr (hd0,msdos3)/bootmgr” part is important and os-prober cant be trusted to get it right either.
Good documentation once again gave Gentoo: wiki/GRUB2#Installation
(and you of course*)
Thanks to you@all for helping !
B
