bryonp
27 September 2023 01:31
1
Im really not too smart with this and not sure if Im in the right place.
When I boot it goes to a black screen with a large arrow curser and thats it…its moveable around a black screen and thats all it does.
This was a working system for over a year?? I dont know what to do? Please help
Welcome to the forum!
Please read the following posts…
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to f…
cscs
27 September 2023 01:39
3
You may be able to initiate certain things even in that state … maybe keyboard shortcuts for a launcher or something similar.
If not … then you may make use of TTY … or even chroot using another medium if needed.
When we have problems gaining access to our systems it is difficult to gather information, let alone fix any problems. Here we will cover common causes and solutions to ‘manjaro wont boot’.
TTY
If your desktop does not load properly then you might still be able to use most, if not all, functionality by dropping to a non-graphical TTY.
By default your system will have multiple TTYs, with each corresponding to an Fx key. Your desktop is assigned to one as well - most often F1.
You can chang…
