Booting to blank screen yet again after update
System:    Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.4
Machine:   Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
           UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery:   ID-1: BAT0 charge: 51.1 Wh (97.0%) condition: 52.7/60.0 Wh (87.8%) volts: 16.2
           min: 15.4 model: Celxpert L19C4PC0 status: Discharging
CPU:       Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
           arch: Zen 2 rev: 1 cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92657
           Speed: 1480 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1480
           2: 1483 3: 1397 4: 1396 5: 1397 6: 1397 7: 1397 8: 1397 9: 3324 10: 3345 11: 1470
           12: 1481 13: 1482 14: 1479 15: 1397 16: 1397
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
           v: 460.80 bus-ID: 01:00.0
           Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
           Display: server: X.org 1.20.11 driver: loaded: amdgpu,nvidia
           OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.36-2-MANJARO LLVM 11.1.0)
           v: 4.6 Mesa 21.0.3 direct render: Yes
Audio:     Device-1: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
           bus-ID: 05:00.5
           Device-2: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus-ID: 05:00.6
           Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.28 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
           driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus-ID: 04:00.0
           IF: wlp4s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
           Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives:    Local Storage: total: 476.94 GiB used: 298.87 GiB (62.7%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
           temp: 36.9 C
Partition: ID-1: / size: 459.79 GiB used: 298.87 GiB (65.0%) fs: ext4 dev: /dev/nvme0n1p1
Swap:      ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 62.1 C mobo: 0 C gpu: amdgpu temp: 35.0 C
Info:      Processes: 385 Uptime: 2m Memory: 15.08 GiB used: 2.94 GiB (19.5%) Init: systemd
           Compilers: gcc: 10.2.0 Packages: 1477 Client: shell wrapper v: 5.1.8-release
           inxi: 3.3.04
It seems like every update this happens. In the previous update this problem returned and it was suggested that I take the kernel down to 5.10 (I was using 5.11 at the time). So used 5.10 and it worked, but now after the latest update the problem is back again. I’ve even tried to go up to 5.12 and go down to 5.4. The problem still persists.
Any ideas?
