inxi -zav7
output:
Kernel: 6.1.23-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4fd7d272-baca-407c-8825-a3b4846ce09f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: G3 3579 v: N/A
Mobo: Dell model: 0M5H57 v: A07 serial: <superuser required> UEFI: Dell
v: 1.10.0 date: 05/23/2019
ID-1: BAT0 charge: 11.7 Wh (100.0%) condition: 11.7/56.0 Wh (21.0%)
volts: 17.1 min: 15.2 model: Samsung SDI DELL W7NKD96 type: Li-ion
serial: <filter> status: full
RAM: total: 15.47 GiB used: 10.58 GiB (68.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1115 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 989 3: 1123 4: 936
5: 1159 6: 2200 7: 1130 8: 1161 9: 1076 10: 936 11: 1071 12: 800
bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:6a06 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 81
size: 600x330mm (23.62x12.99") diag: 685mm (26.96") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.1.23-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.03 TiB used: 544.6 GiB (51.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC501A NVMe 128GB size: 119.24 GiB block-size: physical: 512 B
rev: 80001101 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0D scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 28.4 GiB (24.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 4fd7d272-baca-407c-8825-a3b4846ce09f
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 66E5-D55F
ID-3: /run/media/eingird/6300c1fd-9c08-4f0f-8682-8f90e1432e75
raw-size: 473.21 GiB size: 464.72 GiB (98.21%) used: 136.08 GiB (29.3%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 6300c1fd-9c08-4f0f-8682-8f90e1432e75
ID-4: /run/media/eingird/ec26c78b-20bc-47f1-b2d5-33a92d92c9b6
raw-size: 458.3 GiB size: 450.04 GiB (98.20%) used: 380.12 GiB (84.5%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: ec26c78b-20bc-47f1-b2d5-33a92d92c9b6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: BY Tech Usb Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 258a:0016 class-ID: 0300
Device-2: 1-3:3 info: MosArt ASUS CERBERUS FORTUS type: Mouse,HID
power: 100mA chip-ID: 062a:8244 class-ID: 0300
Device-3: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
Device-4: 1-6:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 1-14:6 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 55.0 C pch: 60.0 C mobo: N/A
Processes: 302 Uptime: 4h 31m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1191 pm: pacman pkgs: 1177 libs: 331 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 14 Shell: Bash v: 5.1.16 running-in: code
inxi: 3.3.26
journalctl -b-1 -p4 --no-pager
output:
кві 14 09:02:01 eingird-g33579 kernel: x86/cpu: SGX disabled by BIOS.
кві 14 09:02:01 eingird-g33579 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
кві 14 09:02:01 eingird-g33579 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
кві 14 09:02:01 eingird-g33579 kernel: #7 #8 #9 #10 #11
кві 14 09:02:01 eingird-g33579 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
кві 14 09:02:01 eingird-g33579 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20220331/psparse-529)
кві 14 09:02:01 eingird-g33579 kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20220331/uteval-68)
кві 14 09:02:01 eingird-g33579 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20220331/psparse-529)
кві 14 09:02:01 eingird-g33579 kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20220331/uteval-68)
кві 14 09:02:01 eingird-g33579 kernel: blacklist: Problem blacklisting hash (-13)
кві 14 09:02:01 eingird-g33579 kernel: i8042: Warning: Keylock active
кві 14 09:02:01 eingird-g33579 systemd-journald[370]: File /var/log/journal/a81356b836474e83abc3acec2a37e92e/system.journal corrupted or uncleanly shut down, renaming and replacing.
кві 14 09:02:01 eingird-g33579 kernel: wmi_bus wmi_bus-PNP0C14:05: WQBC data block query control method not found
кві 14 09:02:02 eingird-g33579 kernel: nvidia: loading out-of-tree module taints kernel.
кві 14 09:02:02 eingird-g33579 kernel: nvidia: module license 'NVIDIA' taints kernel.
кві 14 09:02:02 eingird-g33579 kernel: Disabling lock debugging due to kernel taint
кві 14 09:02:03 eingird-g33579 kernel: psmouse serio1: synaptics: Unable to query device: -5
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
кві 14 09:02:03 eingird-g33579 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
кві 14 09:02:03 eingird-g33579 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 530.41.03 Thu Mar 16 19:48:20 UTC 2023
кві 14 09:02:03 eingird-g33579 kernel: thermal thermal_zone7: failed to read out thermal zone (-61)
кві 14 09:02:04 eingird-g33579 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: src/plugin.c:plugin_init() Failed to init vcp plugin
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: src/plugin.c:plugin_init() Failed to init mcp plugin
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
кві 14 09:02:05 eingird-g33579 bluetoothd[725]: src/plugin.c:plugin_init() Failed to init bap plugin
кві 14 09:02:06 eingird-g33579 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
кві 14 09:02:06 eingird-g33579 bluetoothd[725]: Failed to set mode: Failed (0x03)
кві 14 09:02:08 eingird-g33579 kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
кві 14 09:02:10 eingird-g33579 kernel: kauditd_printk_skb: 26 callbacks suppressed
I was using Manjaro with XFCE DE, and for some reason, after I tried to reboot the system, I got a “Timed out waiting for device disk/by-uuid/” error and couldn’t launch the system. Then I found that this might be caused by the way I was mounting a drive, so I looked for a similar problem on a forum and tried a suggested solution, but I didn’t succeed. So I decided, “Okay, I don’t have that much time to fix this in the right way, I will just save important files on a second drive and install a new system from my USB drive - Manjaro with KDE DE.”
Previously, my assumption was that something was wrong with devices that I connect to a laptopl (mouse, keyboard, etc.), however now I do not think so, as for now one of the most probable things I think might be causing this is nvidia drivers
I also found out that the reason might be in incorrect way of turning the laptop off, I usually use shutdown 20
, or just press and hold power off button. So, I’ve tried to do it using the GUI, and it looks like if I turn it off in that way it then boots normally.
