Hi,
I had Manjaro-stable installed on my laptop for a few months with no problems, but this morning it got stuck in boot. (Not sure how I could extract logs or anything to post here).
I figured I can edit the boot config to get a more verbose output, thus I see it got stuck on
“A start job is running for /dev/mapper/luks-625… ( 60min / no limit)” forever.
Although my drive/partition is encrypted, it’s luks-7… , and the boot process seems to pass the mount and file system check. Hence I’m not sure what luks-625… is about.
I think in my previous session, I’ve gone to hibernate.
I’m not sure how to progress from here, to fix it or even just figure out what’s causing the problem.
Any help is appreciated.
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_202 quiet systemd.show_status=1
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81BR v: Lenovo ideapad 720S-13ARR
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 720S-13ARR
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: 6KCN28WW date: 12/19/2017
ID-1: BAT0 charge: 20.7 Wh condition: 42.1/48.0 Wh (88%) volts: 7.3/7.7
model: LGC 11 L16L4PB3 type: Li-poly serial: <filter> status: Discharging
RAM: total: 7.39 GiB used: 3.04 GiB (41.1%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: N/A microcode: 8101004 L2 cache: 2048 KiB bogomips: 31959
Speed: 1369 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1369 2: 1367 3: 1368 4: 1366 5: 1455 6: 1367 7: 1485 8: 1426
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm lbrv lm mca mce
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:15dd
Device-2: Chicony EasyCamera type: USB driver: uvcvideo bus ID: 3-1:2
chip ID: 04f2:b5da serial: <filter>
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: amdgpu note: display driver n/a - try sudo/root display ID: 0
resolution: <xdpyinfo missing>
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.39.0
5.9.11-3-MANJARO LLVM 11.0.0)
v: 4.6 Mesa 20.2.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
bus ID: 01:00.0 chip ID: 10ec:c821
Local Storage: total: 933.39 GiB used: 139.90 GiB (15.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000L2
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 2L1QEXA7 scheme: GPT
ID-2: /dev/sda type: USB vendor: Transcend model: TS240GESD240C
size: 223.57 GiB block size: physical: 512 B logical: 512 B serial: <filter>
scheme: GPT
ID-3: /dev/sdb type: USB vendor: SanDisk model: USB 3.2Gen1 size: 232.88 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
scheme: MBR
ID-1: / raw size: N/A size: 5.54 GiB used: 173.0 MiB (3.0%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-2: /run/media/manjaro/f3f54b77-9bf0-4786-8e12-fc2ac4e09a85
raw size: 214.47 GiB size: 210.05 GiB (97.94%) used: 139.73 GiB (66.5%)
fs: ext4 dev: /dev/dm-0 label: N/A
uuid: f3f54b77-9bf0-4786-8e12-fc2ac4e09a85
ID-1: /dev/dm-1 size: 8.80 GiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p1 size: 260.0 MiB fs: vfat label: SYSTEM_DRV
uuid: 1454-5BD5
ID-3: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-4: /dev/nvme0n1p3 size: 450.69 GiB fs: ntfs label: Windows
uuid: F0AA5530AA54F496
ID-5: /dev/nvme0n1p4 size: 25.00 GiB fs: ntfs label: LENOVO
uuid: 509EFA239EFA0170
ID-6: /dev/nvme0n1p5 size: 1000.0 MiB fs: ntfs label: WINRE_DRV
uuid: 804E56EC4E56DA8C
ID-7: /dev/sda1 size: 300.0 MiB fs: vfat label: NO_LABEL uuid: A997-6409
ID-8: /dev/sda2 size: 214.47 GiB fs: crypto_luks label: N/A
uuid: 7e0e7abe-765b-485b-ba23-83e5a4752e78
ID-9: /dev/sda3 size: 8.80 GiB fs: crypto_luks label: N/A
uuid: 625e151f-145f-48fc-8e17-41ec6c5db013
ID-10: /dev/sdb1 size: 2.62 GiB fs: iso9660 label: MANJARO_GNOME_202
uuid: 2020-12-03-10-06-11-00
ID-11: /dev/sdb2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: 7239-C206
Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-1: 2-1:2 info: Transcend StoreJet Transcend type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 10 Gb/s chip ID: 2174:2000
serial: <filter>
Device-2: 2-2:3 info: SanDisk Ultra Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s chip ID: 0781:5583
serial: <filter>
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-1:2 info: Chicony EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b5da serial: <filter>
Hub: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608
Device-1: 3-2.1:4 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 0bda:c024
serial: <filter>
Device-2: 3-2.2:5 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 06cb:0081 serial: <filter>
Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 56.2 C mobo: N/A gpu: amdgpu temp: 56.0 C
Processes: 297 Uptime: 1h 25m Init: systemd v: 246 Compilers: gcc: N/A
Packages: pacman: 1246 lib: 321 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.08 ```
