Hey, I’ve made my bootable USB with Ventoy, but when I try and boot or enter bios or do anything before the monitor doesnt show anything. Obviously it works as normal once its finished booting, but I can’t see any options when I load up. Normally there would be the boot up animation, with the ‘Press F12 for boot options’, and show the loading animations, but the screen just doesnt show
You don’t need to use screenshots for pasting console text here. Just type three backticks (`) followed by a newline, paste the command output, and type another newline with three backticks.
That said, maybe the theme isn’t called “manjaro”. Have you tried the name “bootsplash-theme-manjaro”?
I did all of that, installed the theme and that worked, but when I reboot still no display. I did the sudo bootsplash-manager --set manjaro and it worked, but the display didn’t
