Booting and installing on Nvidia hybrid bumblebee laptop
There is a subset of laptops that will not boot without these intervening steps even with the live media, maybe they are all bumbleb ee..
If anyone has a list of effected systems it would be nice. I know in involves Nvidia chipped systems.
Basically
  1. Boot live media by passing kernel parameter systemd.mask=mhwd-live.service that should get you to live session
  2. Now before you start the install from the live session change the lines at the end of the file /lib/calamares/modules/mhwdcfg/main.py to match below
def run():
    """ Configure the hardware """
    mhwd = MhwdController()
    # return mhwd.run()
    return None # <- Add this and comment the above line
  1. Now run the installer and it should work. Reboot your system and proceed.
Pay attention -- After the reboot you need to do the next steps, you may need to write it down.
  1. Add the following kernel flags at the Grub boot menu otherwise the system won’t boot:
    acpi_osi=! acpi_osi="Windows 2009"
  2. Test system after boot to see if it is working see the first command below
$ systemctl status bumblebeed
optirun -b none nvidia-settings -c :8
You should see the nvidia-settings showing your dedicated GPU.
Now make it Permenant: >>>>>> Do not skip this Last step
Don't forget to add acpi_osi=! acpi_osi=\"Windows 2009\" to your GRUB_CMDLINE_LINUX_DEFAULT in the file /etc/default/grub
And then at the terminal run
sudo update-grub
Look also, you will see other suggestions such as "Windows 2015" etc... I have not tested them but if someone else has verified it works then go with whatever works for your laptop.
Manjaro crashes after installation
How To Install NVIDIA Drivers
Freezes when probing system on Clevo N850HK1
Nvidia "Prime Profiles" Not Show
Hardware Detection Issue
Manjaro freezes at Boot at “Started TLP system startup/shutdown” and after fixing it while installing
External display issues Nvidia
live usb install stalling -mismatch no-free & free drivers
Options for Nvidia Optimus graphics
Bumblebee is not able to activate NVIDIA GPU
Unable to boot after nvidia-prime-select install
Problemas para Suspender e Hibernar
No gaming for me
Low screen resolution after installing nvidia driver
Live USB not booting on XPS 15 9560
Advice for installing Architect on ASUS laptop
System crashes on reboot or poweroff
X1 extreme i5, so far I could not get bumblebee to work
Failed to install manjaro kde openbox gnome
Manjaro Live USB not booting right way
No more Login screen and xorg got deleted after uninstalling libinput drivers
Shutdown problems, desktop freezing
Did anyone installed drivers for Nvidia GTX1070?
Hardware configuration hangs out
HDMI port not recognized on Acer Nitro V
Manjaro KDE works perfectly live but freezes once installed
NVIDIA driver not working properly (+ poor rendering performance in Chrome)
Can't detect HDMI cable for another monitor when using bumblebee
I3 Manjaro - unable to detect secondary monitor
Acer V5 573G Default PrtScSysRq Screenshot Error
After install video-nvidia manjaro can't boot
Manjaro mate first installation
Manjaro mate installation problems
Blank Screen after login in gaming laptop with Nvidia GPU
ACPI Error clevo
[LG Gram 15ub470] Live USB won't boot past GRUB menu
Terminal crashing when trying to update nvidia drivers + other issues
Integrated graphics laptop - any walkthrough for non-technical users?
