Boot vmlinuz not found
So I followed a guide on how to fix my boot issue after some updates.
Not only did this not fix the issue but I now have nothing in the kernal menu. My 2 installed kernals have vanished from the list.
Soooo what do I do now aside from cry?
Chroot again and install a kernel manually
pacman -S linux618
mkinitcpio -P
update-grub
Thank you for your reply, and while it did seem to do something and to your credit there is now a 6.18 option…
It will not boot. Sitting on a black screen currently.
Ideas?
Update: It’s in “TTY4” but I don’t have anything more than [pcname@pc ~]$
You also need to resume the upgrade the got interrupted.
And this is all in the manjaro-chroot.
You should also install kernels with the Manjaro tool:
 sudo mhwd-kernel -i linux618
# And you can remove others with -r
I don’t use pamac. But this always suffices for official packages.
sudo pacman -Syu
If that doesn’t work..
sudo pacman-mirrors -f && sudo pacman -Syyu
Can i do that in TTY or do I need chroot through my install drive for that?
Yes, you have to do that in the terminal.
You boot the live image, and manjaro-chroot into your root. Unfortunately, it’s the only easiest way.
Mhwd says command not found
Inside the chroot?
Should be:
/usr/bin/mhwd-kernel
Manjaro-chroot -a
(Mounts dev/sdb3)
Fuse: failed to mount /media: no such directory
Sudo mhwd-kernal -i linux618
Sudo: mhwd-kernal: command not found
Possibly due to the incorrect spelling of kernel? Try:
You caught my stupid, I did indeed flub that one. Will update when 194 updates go through
Thank you everyone for being patient with me, im not very good at the whole “linux” backdoor magic codes as much as I was with windows, but im overjoyed to see my desktop again.
Cheers <3
