Greetings!
I have upgraded my kernel to 6.1 from 6.0 because 6.0 was EOL and wanted to be a bit up to date. When I boot into Manjaro on the 6.1 kernel, it would boot slower than the 6.0 kernel.
I do have a SATA SSD as my boot drive for my Manjaro install.
When I first startup my laptop, it would show my laptop logo, then it would show a black screen for a few seconds, and it would show my log in screen. The black screen stays for a few seconds longer on kernel 6.1 than 6.0.
Is this normal or is it just my laptop that’s the problem? If you would like more information, please let me know!
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7a0aad6e-4cb5-4be9-8bb0-ab829b6373de rw quiet splash
resume=UUID=0aa27db6-b706-42f2-a5bc-dbc1542ade4d udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire E5-575 v: V1.47
serial: <superuser required>
Mobo: Acer model: Ironman_SK v: V1.47 serial: <superuser required>
UEFI: Insyde v: 1.47 date: 09/06/2018
ID-1: BAT1 charge: 37.3 Wh (80.2%) condition: 46.5/62.2 Wh (74.8%)
volts: 11.8 min: 11.1 model: PANASONIC AS16B5J type: Li-ion serial: <filter>
status: discharging
RAM: total: 3.7 GiB used: 2.63 GiB (71.0%)
Info: model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1500 high: 2400 min/max: 400/2400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2400 2: 2400 3: 600 4: 600
bogomips: 19204
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Acer Incorporated ALI Aspire E5-575G
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5916 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b571 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d2 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Aspire E5-575G driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
vendor: Acer Incorporated ALI Aspire E5-575G driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-5:2 chip-ID: 04ca:3015 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 465.76 GiB used: 18.9 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
type: SSD serial: <filter> rev: 20RL scheme: GPT
Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XA11
dev-links: cdrom
ID-1: / raw-size: 54 GiB size: 52.85 GiB (97.87%) used: 15.84 GiB (30.0%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: root
uuid: 7a0aad6e-4cb5-4be9-8bb0-ab829b6373de
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: FAEE-CD18
ID-3: /home raw-size: 403.47 GiB size: 396.06 GiB (98.17%)
used: 3 GiB (0.8%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: home
uuid: 88df4b9b-42ce-46c6-8e62-37fe04191213
ID-1: swap-1 type: partition size: 8 GiB used: 67.8 MiB (0.8%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 0aa27db6-b706-42f2-a5bc-dbc1542ade4d
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:3015 class-ID: e001
Device-2: 1-7:3 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b571
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 37.0 C pch: 34.0 C mobo: N/A
Processes: 196 Uptime: 13m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1232 libs: 358 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
systemd-analyze (kernel 6.1)
Startup finished in 2.998s (firmware) + 380ms (loader) + 2.359s (kernel) + 5.272s (userspace) = 11.010s
graphical.target reached after 2.954s in userspace.
