I forced restarted and it now got stuck at only the first line.
Upon looking for various answers I learned a few things:
Ctrl+Alt+F2 opens up a terminal. (NEWBIE, pardon me :D)
Restarted after updating PACMAN sudo pacman -Syu. DIdn’t help
Then I ran a command kstart5 plasmashell, which showed an error
qt.qpa.xcb: couldnot connect to display
qt.qpa.plugins: couldn’t load the Qt platform plugin “xcb” in “” even though it was found.
There were some more lines…regarding reinstalling may fix it etc etc.
Then as suggested in the forum post somewhere, I reinstalled xorg-servers and all its dependencies.
Didn’t fix anything.
Reinstalled libxcb as mentioned in the forum. – didn’t fix anything.
If someone can help out on this, would be really grateful. I don’t really want to reinstall linux and potentially learn something while fixing this issue
EDIT:
Tried xrandr and throws error = Cant open display
I was normally using the laptop. From what I can remember, I only installed virtscreen to link my laptop with ipad screen. it didnt work as it couldnt find second virtual screen.
Now it seems to me that manjaro isnt able to locate my screen/display.
