Problem:
Recently, whenever I reboot my desktop, it hangs at “A start job is running for One-Shot Network Time Service” forever. It had been working fine until this happened.
What I was doing before:
During the previous session, I had installed Olive and Audacity, but have since uninstalled them using the TTY. I also remember running an empty update (nothing was there to update). Later on, I restarted to boot into Windows, and I noticed the problem when I attempted to come back to manjaro.
What I tried:
I tried restarting, and running sudo systemd-sysusers sddm.conf
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=bb02294d-9f39-4d53-b0bc-14b000535759 ro apparmor=1
security=apparmor resume=UUID=ed342346-4d79-4a4b-9c52-f507e0fa2d5e
udev.log_priority=3
Console: tty 3 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 0805 date: 07/01/2020
RAM: total: 31.31 GiB used: 827.1 MiB (2.6%)
Info: 8-Core model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 4 MiB bogomips: 124609
Speed: 2194 MHz min/max: 2200/3900 MHz boost: enabled Core speeds (MHz):
1: 2194 2: 2194 3: 2189 4: 2194 5: 2192 6: 2194 7: 2191 8: 2189 9: 2194
10: 2196 11: 2194 12: 2193 13: 2193 14: 2194 15: 2189 16: 2190
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit
smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
conditional, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI driver: N/A
alternate: nouveau bus-ID: 07:00.0 chip-ID: 10de:2484 class-ID: 0300
Display: server: X.org 1.20.11 driver: loaded: nvidia tty: 128x48
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 09:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-4.4:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp9s0f3u4u4 state: down mac: <filter>
Local Storage: total: 2.3 TiB used: 117.45 GiB (5.0%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: STORAGE
size: 29.81 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
rev: 1404 scheme: MBR
ID-1: / raw-size: 215.21 GiB size: 210.83 GiB (97.97%)
used: 117.42 GiB (55.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: bb02294d-9f39-4d53-b0bc-14b000535759
used: 25.6 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 2193-20BB
ID-1: swap-1 type: partition size: 34.44 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: ed342346-4d79-4a4b-9c52-f507e0fa2d5e
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 215.8 GiB fs: ntfs label: N/A
uuid: 52CE5D03CE5CE0B1
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-4: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: N/A
uuid: 585096A450968880
ID-5: /dev/sdc1 maj-min: 8:33 size: 2.75 GiB fs: iso9660
label: MANJARO_KDE_2106 uuid: 2021-06-07-20-00-03-00
ID-6: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 4A3E-5D6C
Device-1: 1-3:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 1-7.1:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7.2:6 info: Corsair Commander PRO type: HID
driver: corsair-cpro,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip-ID: 1b1c:0c10 class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: SINO WEALTH Mechanical Keyboard type: Keyboard
power: 500mA chip-ID: 258a:0090 class-ID: 0301
Hub-6: 3-4:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-7: 3-4.1:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-4.1.2:5 info: Genesys Logic microSD Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 98mA chip-ID: 05e3:0751 class-ID: 0806
Device-2: 3-4.1.4:6 info: Genesys Logic microSD Card Reader
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-9: 4-4:2 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0626 class-ID: 0900
Device-1: 4-4.4:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 47.6 C mobo: 0 C
Fan Speeds (RPM): fan-2: 1087 fan-3: 1044
Processes: 281 Uptime: N/A wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1651 pacman: 1648 lib: 480
flatpak: 0 snap: 3 Shell: Bash (login) v: 5.1.8 running-in: tty 3
inxi: 3.3.04
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Wed 2021-03-17 02:35:12 AST, ends at Wed 2021-06-09 18:01:09 AST. --
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 1.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 2.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 3.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 4.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 5.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 6.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 7.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 8.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 9.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: __common_interrupt: 10.55 No irq handler for vector
Mar 17 02:35:12 nonamejr245 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Mar 17 02:35:12 nonamejr245 kernel: kvm: disabled by bios
Mar 17 02:35:13 nonamejr245 kernel: kvm: disabled by bios
Mar 17 02:35:14 nonamejr245 kernel: kvm: disabled by bios
Mar 17 02:36:02 nonamejr245 pulseaudio[1510]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mar 17 02:43:19 nonamejr245 pulseaudio[1510]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
Mar 17 02:43:19 nonamejr245 pulseaudio[1510]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
Mar 17 02:43:19 nonamejr245 pulseaudio[1510]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
Mar 17 03:23:19 nonamejr245 pipewire[15045]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
Mar 17 03:36:49 nonamejr245 ksmserver[1453]: kscreenlocker: Could not establish screen lock
Mar 17 05:10:25 nonamejr245 sudo[29385]: pam_unix(sudo:auth): conversation failed
Mar 17 05:10:25 nonamejr245 sudo[29385]: pam_unix(sudo:auth): auth could not identify password for [deontev]
I am a noob, so any help would be greatly appreciated.
