EDIT: I’m now back with a functioning dgpu but my igpu still doesn’t seem to display anything, i think it might still be an issue with the nvidia driver since the ‘mesa’ drivers are still installed under the package manager, renamed thread to match current problem, see reply for solution to dgpu issues, disregard earlier original post, keeping for context
after the newest update I thought I had properly installed the ‘new’ drivers for both my intel igpu and nvidia dgpu, but upon a restart the igpu (which is the one connected to my display) shows a black screen but the 1660 super i have functioned normally until i thought to remove the nvidia drivers to see if they were causing the issue but that just ended up with the same problem on that card
so now i have two gpus both displaying nothing and scrolling past similar issues hasn’t helped much since the list of commands they give don’t function with, at the very least, my version of mhwd although that might be an issue of kernel parameters, I should mention that the BIOS, grub menu and shutdown / reboot text display perfectly fine, it’s just the desktop that’s not displaying, and I have a live usb that I’ve been trying / failing to troubleshoot the issue with
thank you for your time
