I installed Manjaro to my VIM3 emmc using the krescue process and all was working fine. I booted the VIM3 today and all I get is a corrupt boot screen. I cannot move beyond this screen. It consists of multiple colour stripes with noise.
looks like it is failing to start the kernel. Did you update the system ?
if you have a uart cable then you can share the uart logs for me to understand your issue better. Without logs, I won’t be able to help much.
Hi spikerguy, I did update the system. I don’t have a uart cable. Are you suggesting that the update caused the issue?
Yes that’s the only possibility as you said it was working before.
