Just installed Manjaro, and did and update and rebooted. I am clueless. This is the message I get.
Mount New root: mount 2 system call fail structure needs cleaning
You are now being dropped into an emergency shell
Sh: can’t access tty: job control turned off
[rootfs ]#
I have not idea what this means. Thank you ahead of time for any help you can give me. This is on a dual boot laptop Dell Inspiron 14 5000 2 in1 AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx 2.10 GHz
That means that the file system is broken and fsck could not easily repair it on boot time.
If it is spinning HDD, I would assume here badblocks, just where the partition is located. So rather a physical problem.
