I don’t know if it’s a problem, but:
My harddisk size is 500 GB. The filesystem says: 416 GiB free of 453 GiB
The files I keep on my disk are no more than 1GB. And Manjaro (acc. Google) takes around 20-30 GB .
What’s going on with the rest of the space?
My system lags a lot. It worked super smooth with Mint Cinnamon, but it lags real bad now.
This is because you haven’t “uninstalled” ubuntu (even I don’t think there’s a way to do it), instead just removed the files and installed Manjaro over it.
Enter these commands to remove ubuntu entry:
sudo su Enter the password.
find /boot/efi -name ubuntu -exec rm -r {} +
Don’t know why it is showing like that.
Maybe, not sure, you have swapfile reserving some amount of space. Open system monitor and check for swap memory.
It depends on the desktop environment. I assume that yours is KDE Plasma, which consumes more CPU and memory than Cinnamon.
EFI directory is simply a directory it has nothing to do with boot options.
You have to remove the boot entry using efibootmgr command.
What efibootmgr does is clearing out the boot option from your motherboard.
So even if you would wipe that whole disk it would still shop up.
UEFI entries are stored on a memory chip.
