while trying out new installation of Fedora 35, I have the problem of the boot menu not showing fedora; grub has no problem seeing it and " parted -l " shows the partiton, and when I run the system menu and change to the drive in it , fedora starts , in fact is what I’m using right now; I always though that if an entry is on grub it would automatically be on grub.cfg but is not ; this is the output from " parted -l "
Model: ATA ADATA SU800 (scsi)
Disk /dev/sdb: 128GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 64.0GB 64.0GB primary ext4
2 64.0GB 65.1GB 1074MB primary ext4 boot
3 65.1GB 128GB 62.9GB primary btrfs
and fedora installer created entries sdb2 and sdb3; can someone please write the way it needs to be place in grub.cfg so I can edit the file
