sorry…
no such device: /miso/manjaro.iso
file /miso/manjaro.iso not found
no server is specified
you need to load the kernel first
sorry…
Have you done this?
Yes, I have…
final summary:
with all the information in
https://forum.manjaro.org/t/howto-boot-manjaro-iso-directly-with-grub/15892
plus all the help here in the topic and some private troubleshooting with @bedna I still failed to get it going. Maybe it is just not possible. I will mark @linux-aarhus answer as solution, since that was his take from the beginning anyway.
I will have a look at ventoy. Maybe that will lead to a satisfying solution. Thanks to everybody, who tried to help!
I did play around a little as well.
It definitely works when the system is not encrypted!
With an encrypted system and the same configuration, the initrd cannot find the iso file - this is likely due to the fact, that the /
file system of the real system, where the iso is stored, only becomes available after the switch root.
Perhaps when the initrd is configured differently?
But I don’t think so.
I see:
running hook [miso]
running hook [miso_loop_mnt]
device did not show up after 30 seconds -
and back in the emergency shell of the initrd …
Thanks for trying!
Without any question…
Like I wrote, it is far out of my league, but my guess is, that it can only be solved through a proper GRUB config (if it is even possible…)
Since we are still at the stage of the bootloader, I don’t see, why any other configuration (except the GRUB config) in my running system would have any effect on what I was trying. Or is the initrd of my running OS fixed for all GRUB menu entries?
