Boot log errors are they a problem?
Below are listed what the system called fatal errors. Better minds than mine, I hope, can tell me if there is any thing of concern.
DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000007b000000-0x000000007f7fffff], contact BIO
tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4>
Apr 25 19:19:33 inspiron15 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4>
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee0000000040110a
Apr 25 19:19:33 inspiron15 kernel: fbcon: Taking over console
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ffc0 MISC 7880010086
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1682414369 SOCKET 0 APIC 0 microcode f0
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: Machine check events logged
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee0000000040110a
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 47880010086
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ee0000000040110a
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff40 MISC 7880010086
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 9: ee0000000040110a
Apr 25 19:19:33 inspiron15 kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff00 MISC 3880010086
Apr 25 19:19:32 inspiron15 systemd-vconsole-setup[353]: /usr/bin/loadkeys failed with exit status 1.
Apr 25 19:19:35 inspiron15 kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
pr 25 19:19:36 inspiron15 kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Apr 25 19:19:36 inspiron15 kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
These 2 errors above repeat a number of time through out the boot up.
Apr 25 19:19:41 inspiron15 lightdm[1031]: gkr-pam: couldn't unlock the login keyring.
Apr 25 20:00:07 inspiron15 systemd-coredump[5564]: Failed to connect to coredump service: Connection refused
Apr 25 20:00:08 inspiron15 pulseaudio[1147]: Error opening PCM device front:0: No such file or directory
lines 2410-2442/2442 (END)
In general yes they are a problem. Specifically, are you having problems? What you should do is copy the message and paste into your favorite search engine and see what they mean and if they can be fixed and how.
@fbt89 thanks I did run sysbench [outputs below] and use the machine, up time 24 hours.
After boot all applications appear to be running fine.
I am replacing window$ for a family member who does not want to spend any money on the laptop.
If I have missed some thing please let me know.
sysbench cpu run
Running the test with following options:
Number of threads: 1
Initializing random number generator from current time
Prime numbers limit: 10000
Initializing worker threads...
Threads started!
CPU speed:
    events per second:  1326.76
General statistics:
    total time:                          10.0005s
    total number of events:              13270
Latency (ms):
         min:                                    0.75
         avg:                                    0.75
         max:                                    1.16
         95th percentile:                        0.78
         sum:                                 9998.79
Threads fairness:
    events (avg/stddev):           13270.0000/0.00
    execution time (avg/stddev):   9.9988/0.00
sysbench memory run
Running memory speed test with the following options:
  block size: 1KiB
  total size: 102400MiB
  operation: write
  scope: global
Threads started!
Total operations: 68862005 (6885257.61 per second)
67248.05 MiB transferred (6723.88 MiB/sec)
General statistics:
    total time:                          10.0001s
    total number of events:              68862005
Latency (ms):
         min:                                    0.00
         avg:                                    0.00
         max:                                    0.10
         95th percentile:                        0.00
         sum:                                 4667.36
Threads fairness:
    events (avg/stddev):           68862005.0000/0.00
    execution time (avg/stddev):   4.6674/0.00
sysbench --test=fileio --file-test-mode=seqwr run
Extra file open flags: (none)
128 files, 16MiB each
2GiB total file size
Block size 16KiB
Periodic FSYNC enabled, calling fsync() each 100 requests.
Calling fsync() at the end of test, Enabled.
Using synchronous I/O mode
Doing sequential write (creation) test
Threads started!
File operations:
    reads/s:                      0.00
    writes/s:                     1020.19
    fsyncs/s:                     1306.84
Throughput:
    read, MiB/s:                  0.00
    written, MiB/s:               15.94
General statistics:
    total time:                          10.0948s
    total number of events:              23366
Latency (ms):
         min:                                    0.01
         avg:                                    0.43
         max:                                  180.00
         95th percentile:                        0.15
         sum:                                10005.33
Threads fairness:
    events (avg/stddev):           23366.0000/0.00
    execution time (avg/stddev):   10.0053/0.00
