/boot is not mounted by default
mount
#1
In Manjaro ARM minimal edition (18.09) the /boot partition isn’t mounted by default. When running a full system upgrade, it can cause problems, like this one:
#2
Can you put what is in your /etc/fstab. You should have a line like
UUID=<the uuid of the boot partition>        /boot        <boot partition format>        defaults        0        2
If you don’t have that line, it could explain the problem.
