Boot failure after Update 2026-05-27 (no swap)
I am a bit late here, haven’t used my PC and then haven’t had time to look into this. I have big problems. Earlier failed boots I could solve with ChatGPT and it was both times Nvidia related but this time I am stuck.
  • Boot failed after GRUB with the ASUS logo shown
  • Cannot open TTY CTRL + ALT + F2/F3
  • I have tried booting with just one monitor, not mouse / keyboard
  • Monitors use different frequency
  • Tried variants of sudo mhwd -f -i pci video-nvidia after first removing the driver (chroot)
inxi -zv8c0 --filter
tty: ttyname error: No such device
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
    avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_KDE_2421 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: KDE Plasma v: ERR-101 tk: Qt v: N/A wm: kwin_x11 dm: N/A Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
  Mobo: ASUSTeK model: TUF GAMING Z790-PLUS WIFI v: Rev 1.xx serial: <filter> part-nu: SKU
    uuid: 1ef6dcc2-8ec7-1be4-e66a-e89c25dab731 Firmware: UEFI vendor: American Megatrends v: 1836
    date: 04/16/2026
  System RAM: total: 64 GiB available: 62.49 GiB used: 3.47 GiB (5.6%)
  Array-1: capacity: 256 GiB slots: 4 modules: 4 EC: None max-module-size: 64 GiB note: est.
  Device-1: Controller0-DIMM0 type: DDR5 detail: synchronous size: 16 GiB speed: 4000 MT/s volts:
    curr: 1.1 min: 1.1 max: 1.999 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF560C36-16 serial: <filter>
  Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 16 GiB speed: 4000 MT/s volts:
    part-no: KF560C30-16 serial: <filter>
  Device-3: Controller1-DIMM0 type: DDR5 detail: synchronous size: 16 GiB speed: 4000 MT/s volts:
  Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 16 GiB speed: 4000 MT/s volts:
  Slot: 0 type: PCIe gen: 5 status: in use length: long volts: 3.3 bus-ID: 00:01.0 children:
    1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1 class-ID: 0403 type: audio
  Slot: 1 type: PCIe gen: 3 status: available length: short volts: 3.3 bus-ID: 00:1c.0
  Slot: 2 type: PCIe gen: 3 status: unavailable length: short volts: 3.3 bus-ID: N/A
  Slot: 3 type: PCIe gen: 4 status: unavailable length: long volts: 3.3 bus-ID: N/A
  Slot: 4 type: PCIe gen: 4 status: available length: short volts: 3.3 bus-ID: 00:1d.0
  Slot: 5 type: N/A status: in use info: M.2 length: short volts: 3.3 bus-ID: 00:06.0 children:
    1: 02:00.0 class-ID: 0108 type: mass-storage
  Slot: 6 type: N/A status: in use info: M.2 length: short volts: 3.3 bus-ID: 00:1b.4 children:
    1: 05:00.0 class-ID: 0108 type: mass-storage
  Slot: 7 type: N/A status: available info: M.2 length: short volts: 3.3 bus-ID: 00:1a.0
  Slot: 8 type: N/A status: unavailable info: M.2 length: short volts: 3.3 bus-ID: N/A
  Slot: 9 type: N/A status: unavailable info: M.2 length: short volts: 3.3 bus-ID: N/A
  Info: model: 12th Gen Intel Core i5-12600K socket: LGA1700 bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF)
    family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x3E
  Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2 st: 4 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB L2: 9.5 MiB
    desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
  Speed (MHz): avg: 800 min/max: 800/4900:3600 base/boost: 4500/8500 scaling:
    driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz cores: 1: 800 2: 800
    3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 bogomips: 118000
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_lbr
    arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts clflush clflushopt clwb cmov constant_tsc
    cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
    flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce
    md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; RSB filling;
    PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: NVIDIA GB203 [GeForce RTX 5070 Ti] vendor: Micro-Star MSI driver: N/A
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2c05 class-ID: 0300
  Display: server: X.org v: 1.21.1.22 with: Xwayland v: 24.1.11 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: N/A display-ID: :0
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
    inactive: gbm,wayland,x11
  API: OpenGL v: 4.6 vendor: mesa v: 26.1.1-arch1.2 note: incomplete (EGL sourced)
    renderer: llvmpipe (LLVM 22.1.5 256 bits)
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
    gpu: nvidia-settings,nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
  Device-2: NVIDIA GB203 High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 5
    speed: 32 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22e9 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-3: PipeWire v: 1.6.5 status: n/a (root, process) with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel 700 Series CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7a70
    class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:125c class-ID: 0200
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0033 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
    discoverable: no pairing: no class-ID: 6c0104
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6 port: N/A
    bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 9.15 TiB used: 1.13 TiB (12.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with Heatsink 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO with Heatsink 1TB
    serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000DM004-2U9188 size: 7.28 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter>
    fw-rev: 0001
  ID-4: /dev/sdb maj-min: 8:16 vendor: Lexar model: USB Flash Drive size: 57.62 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: SSD serial: <filter> fw-rev: 1100
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 537.64 GiB (58.7%) fs: ext4
    block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:3 label: N/A
    uuid: f2605f27-70ad-4098-a067-586aeb135ac2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 328 KiB (0.1%) fs: vfat
    block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:2 label: N/A uuid: 75FD-97E9
  ID-3: /mnt/nvme_disk2 raw-size: 931.51 GiB size: 915.82 GiB (98.31%) used: 614.76 GiB (67.1%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p1 maj-min: 259:4 label: N/A
    uuid: ac190fa5-2c03-4e27-a350-feb7e715d730
  ID-1: /dev/sda1 maj-min: 8:1 size: 7.28 TiB fs: ext4 label: storage
    uuid: 2780bb03-4e19-4be4-94b7-572cb64e649d
  ID-2: /dev/sdb1 maj-min: 8:17 size: 4.03 GiB fs: N/A label: MANJARO_KDE_2421
    uuid: 2024-12-16-11-21-39-00
  ID-3: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: N/A label: MISO_EFI uuid: 97A3-D79B
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 16 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-2:2 info: ASUSTek AURA LED Controller type: HID driver: hid-generic,usbhid
    interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 16mA
    chip-ID: 0b05:19af class-ID: 0300 serial: <filter>
  Hub-2: 1-6:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 174c:2074 class-ID: 0900
  Hub-3: 1-6.1:5 info: Realtek RTL 8153 USB 3.0 hub with gigabit ethernet ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA chip-ID: 0bda:5401 class-ID: 0900
  Device-1: 1-6.3:6 info: SteelSeries ApS Rival 710 Gaming Mouse type: HID,mouse
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 200mA chip-ID: 1038:1730 class-ID: 0300
  Device-2: 1-6.4:7 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0 type: keyboard,HID
    driver: microsoft,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 045e:00db class-ID: 0300
  Device-3: 1-14:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 8087:0033
    class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s (2.33 GiB/s) lanes: 2
    mode: 3.2 gen-2x2 chip-ID: 1d6b:0003 class-ID: 0900
  Device-1: 2-7:2 info: Lexar USB Flash Drive type: mass storage driver: usb-storage
    interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 504mA
    chip-ID: 21c4:0cd1 class-ID: 0806 serial: <filter>
  Hub-5: 2-9:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 8mA chip-ID: 174c:3074 class-ID: 0900
  Hub-6: 2-9.1:4 info: Realtek USB3.0 Hub ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 96mA chip-ID: 0bda:0401 class-ID: 0900
  System Temperatures: cpu: 37.8 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1626 libs: 457 tools: pamac,yay pm: flatpak pkgs: 0
    1: https: //mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https: //mirror.23m.com/manjaro/stable/$repo/$arch
    3: http: //ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    4: https: //mirror.netcologne.de/manjaro/stable/$repo/$arch
    5: https: //ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    6: https: //ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    7: https: //ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    8: https: //ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 347
  1: cpu: 53.6% command: kwin_x11 pid: 1499 mem: 373.9 MiB (0.5%)
  2: cpu: 14.5% command: firefox pid: 2701 mem: 523.3 MiB (0.8%)
  3: cpu: 8.0% command: firefox pid: 2886 mem: 260.9 MiB (0.4%)
  4: cpu: 7.5% command: Xorg pid: 1319 mem: 141.6 MiB (0.2%)
  5: cpu: 5.5% command: plasmashell pid: 1618 mem: 568.9 MiB (0.8%)
  Memory top: 5 of 347
  1: mem: 568.9 MiB (0.8%) command: plasmashell pid: 1618 cpu: 5.5%
  2: mem: 523.3 MiB (0.8%) command: firefox pid: 2701 cpu: 14.5%
  3: mem: 373.9 MiB (0.5%) command: kwin_x11 pid: 1499 cpu: 53.6%
  4: mem: 300.5 MiB (0.4%) command: firefox pid: 2857 cpu: 2.0%
  5: mem: 260.9 MiB (0.4%) command: firefox pid: 2886 cpu: 8.0%
  Processes: 347 Power: uptime: 10m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 24.95 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 260
  Compilers: clang: 22.1.5 gcc: 16.1.1 Client: systemd inxi: 3.3.40
[2026-05-28T19:51:35+0300] [PAMAC] synchronizing package lists
[2026-05-28T19:51:47+0300] [PAMAC] synchronizing package lists
[2026-05-28T19:53:14+0300] [ALPM] running '00-timeshift-autosnap.hook'...
[2026-05-28T19:53:14+0300] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2026-05-28T19:53:14+0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2026-05-28T19:53:14+0300] [ALPM] running 'firefox-pre.hook'...
[2026-05-28T19:53:14+0300] [ALPM] running 'thunderbird-pre.hook'...
[2026-05-28T19:53:14+0300] [ALPM] transaction started
[2026-05-28T19:53:14+0300] [ALPM] upgraded alsa-card-profiles (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:14+0300] [ALPM] upgraded amd-ucode (20260410-1 -> 20260519-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded iana-etc (20260425-1 -> 20260511-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded aom (3.14.0-1 -> 3.14.1-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded util-linux-libs (2.42-1 -> 2.42.1-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded krb5 (1.21.3-2 -> 1.22.2-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded at-spi2-core (2.60.3-1 -> 2.60.4-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded libedit (20251016_3.1-1 -> 20260512_3.1-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded bind (9.20.22-1 -> 9.20.23-1)
[2026-05-28T19:53:14+0300] [ALPM] upgraded mesa (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-28T19:53:15+0300] [ALPM] upgraded cef (147.0.10-1 -> 147.0.14-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded cmake (4.3.2-1 -> 4.3.3-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded libstemmer (3.0.1-1 -> 3.1.0-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded dbeaver (26.0.4-1 -> 26.0.5-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded device-mapper (2.03.40-1 -> 2.03.41-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded util-linux (2.42-1 -> 2.42.1-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded fakeroot (1.38-1 -> 1.38.1-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded libopenmpt (0.8.6-1 -> 0.8.7-1)
[2026-05-28T19:53:15+0300] [ALPM] upgraded vapoursynth (75-2 -> 75-3)
[2026-05-28T19:53:15+0300] [ALPM] upgraded libusb (1.0.29-1 -> 1.0.30-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded firefox (151.0-1 -> 151.0.2-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded ghostscript (10.07.0-1 -> 10.07.1-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded gpgme (2.0.1-3 -> 2.1.0-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded gpgmepp (2.0.0-2 -> 2.1.0-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded gssdp (1.6.4-1 -> 1.6.5-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libpipewire (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded pipewire (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded pipewire-audio (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded pipewire-session-manager (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded gst-plugin-pipewire (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded gupnp (1:1.6.9-1 -> 1:1.6.10-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded kcolorpicker (0.3.1-5 -> 0.3.1-6)
[2026-05-28T19:53:16+0300] [ALPM] upgraded kimageannotator (0.7.2-1 -> 0.7.2-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded qt6-declarative (6.11.1-1 -> 6.11.1-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded kirigami-addons (1.12.0-1 -> 1.12.1-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded openexr (3.4.11-1 -> 3.4.12-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded kquickimageeditor (0.6.1-1 -> 0.6.1-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-krb5 (1.21.3-1 -> 1.22.2-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-libpipewire (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-libusb (1.0.29-1 -> 1.0.30-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-nettle (4.0-1 -> 4.0-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-mesa (1:26.0.6-1 -> 1:26.1.1-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-util-linux (2.42-1 -> 2.42.1-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded lib32-pipewire (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libxmlb (0.3.26-1 -> 0.3.27-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libadwaita (1:1.9.0-1 -> 1:1.9.1-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libde265 (1.0.18-1 -> 1.0.19-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libgme (0.6.4-2 -> 0.6.5-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libheif (1.21.2-2 -> 1.22.0-2)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libqalculate (5.10.0-1 -> 5.11.0-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded libva-intel-driver (2.4.1-6 -> 2.4.1-7)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-whence (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-amdgpu (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-atheros (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-broadcom (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-cirrus (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-intel (20260410-1 -> 20260519-1)
[2026-05-28T19:53:16+0300] [ALPM] upgraded linux-firmware-mediatek (20260410-1 -> 20260519-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux-firmware-nvidia (20260410-1 -> 20260519-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux-firmware-other (20260410-1 -> 20260519-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux-firmware-radeon (20260410-1 -> 20260519-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux-firmware-realtek (20260410-1 -> 20260519-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux612 (6.12.90-1 -> 6.12.91-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux612-nvidia-open (595.71.05-8 -> 595.71.05-9)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux66 (6.6.140-1 -> 6.6.141-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded linux66-nvidia-open (595.71.05-6 -> 595.71.05-7)
[2026-05-28T19:53:17+0300] [ALPM] upgraded lvm2 (2.03.40-1 -> 2.03.41-1)
[2026-05-28T19:53:17+0300] [ALPM] upgraded zsh-theme-powerlevel10k (1.20.15-1 -> 1:1.20.15-1)
[2026-05-28T19:53:17+0300] [ALPM] warning: directory permissions differ on /root/, filesystem: 755  package: 750
[2026-05-28T19:53:17+0300] [ALPM] upgraded manjaro-zsh-config (0.26-3 -> 0.26-4)
[2026-05-28T19:53:18+0300] [ALPM] upgraded meson (1.11.1-1 -> 1.11.1-3)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-html-parser (3.83-2 -> 3.85-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-http-daemon (6.16-6 -> 6.17-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-www-robotrules (6.02-16 -> 6.03-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-xml-parser (2.58-1 -> 2.59-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-certifi (2026.04.22-1 -> 2026.05.20-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-idna (3.15-1 -> 3.16-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded mhwd-nvidia-580xx (580.159.03-1 -> 580.159.04-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded opentimelineio (0.18.1-2 -> 0.18.1-3)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-file-mimeinfo (0.36-1 -> 0.37-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded perl-xml-libxml (2.0210-4 -> 2.0212-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded pipewire-alsa (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:18+0300] [ALPM] upgraded pipewire-pulse (1:1.6.5-1 -> 1:1.6.5-2)
[2026-05-28T19:53:18+0300] [ALPM] upgraded puzzles (20260410.06e37f1-1 -> 20260523.7ad37c6-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-cachetools (7.1.2-1 -> 7.1.4-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-greenlet (3.5.0-1 -> 3.5.1-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-more-itertools (11.0.2-1 -> 11.1.0-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-gevent (26.4.0-1 -> 26.5.0-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-lxml (6.1.0-1 -> 6.1.1-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-numpy (2.4.5-1 -> 2.4.6-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded python-soupsieve (2.8.3-1 -> 2.8.4-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qcoro (0.13.0-1 -> 0.13.0-2)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-translations (5.15.18-1 -> 5.15.19-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-base (5.15.18+kde+r109-2 -> 5.15.19+kde+r96-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-declarative (5.15.18+kde+r23-1 -> 5.15.19+kde+r23-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-graphicaleffects (5.15.18-1 -> 5.15.19-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-multimedia (5.15.18+kde+r2-1 -> 5.15.19+kde+r2-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-quickcontrols (5.15.18-1 -> 5.15.19-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-quickcontrols2 (5.15.18+kde+r5-1 -> 5.15.19+kde+r5-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-speech (5.15.18+kde+r1-1 -> 5.15.19+kde+r1-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-svg (5.15.18+kde+r5-1 -> 5.15.19+kde+r5-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-wayland (5.15.18+kde+r55-1 -> 5.15.19+kde+r55-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded qt5-x11extras (5.15.18-1 -> 5.15.19-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded rclone (1.74.1-1 -> 1.74.2-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded ripgrep (15.1.0-2 -> 15.1.0-3)
[2026-05-28T19:53:18+0300] [ALPM] upgraded rsync (3.4.2-1 -> 3.4.3-1)
[2026-05-28T19:53:18+0300] [ALPM] upgraded sddm (0.21.0-6 -> 0.21.0-7)
[2026-05-28T19:53:19+0300] [ALPM] upgraded signal-desktop (8.11.0-1 -> 8.12.0-1)
[2026-05-28T19:53:19+0300] [ALPM-SCRIPTLET] ==> NOTE: Custom flags should be put directly in: ~/.config/signal-desktop-flags.conf
[2026-05-28T19:53:19+0300] [ALPM] upgraded signon-ui (0.17+20231016-3 -> 0.17+20231016-4)
[2026-05-28T19:53:19+0300] [ALPM] upgraded steam-devices (1.0.0.85-6 -> 1.0.0.85-7)
[2026-05-28T19:53:19+0300] [ALPM] upgraded steam (1.0.0.85-6 -> 1.0.0.85-7)
[2026-05-28T19:53:19+0300] [ALPM] upgraded thunderbird (150.0.2-1 -> 151.0-1)
[2026-05-28T19:53:19+0300] [ALPM] upgraded vim-runtime (9.2.0450-1 -> 9.2.0511-1)
[2026-05-28T19:53:19+0300] [ALPM] upgraded vim (9.2.0450-1 -> 9.2.0511-1)
[2026-05-28T19:53:19+0300] [ALPM] upgraded vulkan-mesa-implicit-layers (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-28T19:53:19+0300] [ALPM] upgraded vulkan-mesa-layers (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-28T19:53:19+0300] [ALPM] upgraded vulkan-nouveau (1:26.0.6-1 -> 1:26.1.1-2)
[2026-05-28T19:53:19+0300] [ALPM] upgraded wget (1.25.0-4 -> 1.25.0-5)
[2026-05-28T19:53:19+0300] [ALPM] upgraded xfsprogs (7.0.0-1 -> 7.0.1-1)
[2026-05-28T19:53:19+0300] [ALPM] transaction completed
[2026-05-28T19:53:20+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2026-05-28T19:53:20+0300] [ALPM] running '21-systemd-tmpfiles.hook'...
[2026-05-28T19:53:20+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-05-28T19:53:21+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2026-05-28T19:53:21+0300] [ALPM] running '30-update-mime-database.hook'...
[2026-05-28T19:53:21+0300] [ALPM] running '35-systemd-enqueue-marked.hook'...
[2026-05-28T19:53:21+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-05-28T19:53:22+0300] [ALPM] running '35-systemd-update.hook'...
[2026-05-28T19:53:22+0300] [ALPM] running '60-depmod.hook'...
[2026-05-28T19:53:23+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-05-28T19:53:24+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-05-28T19:53:24+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-05-28T19:53:24+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-05-28T19:53:24+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-05-28T19:53:24+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-05-28T19:53:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-05-28T19:53:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-05-28T19:53:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-05-28T19:53:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-05-28T19:53:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-05-28T19:53:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-05-28T19:53:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-05-28T19:53:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-05-28T19:53:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-05-28T19:53:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-05-28T19:53:32+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-05-28T19:53:33+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-05-28T19:53:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-05-28T19:53:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-05-28T19:53:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-05-28T19:53:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-05-28T19:53:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-05-28T19:53:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-05-28T19:53:39+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-05-28T19:53:39+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-05-28T19:53:40+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-05-28T19:53:40+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-05-28T19:53:40+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-05-28T19:53:40+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-05-28T19:53:41+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-05-28T19:53:41+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-05-28T19:53:41+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-05-28T19:53:41+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-05-28T19:53:41+0300] [ALPM] running '99-update-grub.hook'...
[2026-05-28T19:53:42+0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2026-05-28T19:53:42+0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2026-05-28T19:53:42+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.12-x86_64
[2026-05-28T19:53:42+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
[2026-05-28T19:53:43+0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.6-x86_64
[2026-05-28T19:53:43+0300] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
[2026-05-28T19:53:43+0300] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2026-05-28T19:53:43+0300] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] Root filesystem isn't btrfs
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2026-05-28T19:53:44+0300] [ALPM-SCRIPTLET] done
[2026-05-28T19:53:44+0300] [ALPM] running 'dbeaver.hook'...
[2026-05-28T19:53:44+0300] [ALPM] running 'dbus-reload.hook'...
[2026-05-28T19:53:44+0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2026-05-28T19:53:44+0300] [ALPM] running 'firefox-post.hook'...
[2026-05-28T19:53:44+0300] [ALPM] running 'glib-compile-schemas.hook'...
[2026-05-28T19:53:45+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2026-05-28T19:53:45+0300] [ALPM] running 'pacnew-checker.hook'...
[2026-05-28T19:53:45+0300] [ALPM] running 'texinfo-install.hook'...
[2026-05-28T19:53:45+0300] [ALPM] running 'thunderbird-post.hook'...
[2026-05-28T19:53:45+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T18:54:08+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -Rs nvidia-utils nvidia-settings lib32-nvidia-utils'
[2026-06-02T18:55:37+0300] [PACMAN] Running 'pacman -Syyu'
[2026-06-02T18:55:37+0300] [PACMAN] synchronizing package lists
[2026-06-02T18:55:38+0300] [PACMAN] starting full system upgrade
[2026-06-02T19:10:29+0300] [PACMAN] Running 'pacman -Syyu'
[2026-06-02T19:10:29+0300] [PACMAN] synchronizing package lists
[2026-06-02T19:10:30+0300] [PACMAN] starting full system upgrade
[2026-06-02T19:14:09+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -Rs nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:14:09+0300] [ALPM] transaction started
[2026-06-02T19:14:10+0300] [ALPM] removed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:14:10+0300] [ALPM] removed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:14:10+0300] [ALPM] removed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2026-06-02T19:14:10+0300] [ALPM] removed nvidia-settings (595.71.05-1)
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
[2026-06-02T19:14:10+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
[2026-06-02T19:14:10+0300] [ALPM] removed nvidia-utils (595.71.05-2)
[2026-06-02T19:14:10+0300] [ALPM] removed egl-x11 (1.0.5-1)
[2026-06-02T19:14:10+0300] [ALPM] removed egl-wayland2 (1.0.1-1)
[2026-06-02T19:14:10+0300] [ALPM] removed egl-wayland (4:1.1.21-1)
[2026-06-02T19:14:10+0300] [ALPM] removed egl-gbm (1.1.3-1)
[2026-06-02T19:14:10+0300] [ALPM] removed eglexternalplatform (1.2.1-1)
[2026-06-02T19:14:11+0300] [ALPM] transaction completed
[2026-06-02T19:14:11+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:14:11+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:14:11+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:14:11+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:14:11+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:14:14+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:14:14+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:14:18+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:14:18+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:14:18+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:14:18+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:14:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:14:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:14:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:14:26+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:14:26+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:14:26+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:14:26+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:14:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:14:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:14:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:14:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:14:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:14:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:14:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:14:37+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:14:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:14:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:14:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:14:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:14:38+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:14:38+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:14:39+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:14:39+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:14:39+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:14:39+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:14:39+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:14:40+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / --needed -Sy nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:14:40+0300] [PACMAN] synchronizing package lists
[2026-06-02T19:14:41+0300] [ALPM] transaction started
[2026-06-02T19:14:41+0300] [ALPM] installed eglexternalplatform (1.2.1-1)
[2026-06-02T19:14:41+0300] [ALPM] installed egl-wayland (4:1.1.21-1)
[2026-06-02T19:14:41+0300] [ALPM] installed egl-wayland2 (1.0.1-1)
[2026-06-02T19:14:41+0300] [ALPM] installed egl-gbm (1.1.3-1)
[2026-06-02T19:14:41+0300] [ALPM] installed egl-x11 (1.0.5-1)
[2026-06-02T19:14:42+0300] [ALPM] installed nvidia-utils (595.71.05-2)
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' -> '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' -> '/usr/lib/systemd/system/nvidia-suspend.service'.
[2026-06-02T19:14:42+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service' -> '/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service'.
[2026-06-02T19:14:42+0300] [ALPM] installed nvidia-settings (595.71.05-1)
[2026-06-02T19:14:42+0300] [ALPM] installed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:14:42+0300] [ALPM] installed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:14:42+0300] [ALPM] installed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:14:42+0300] [ALPM] transaction completed
[2026-06-02T19:14:42+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2026-06-02T19:14:42+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:14:43+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:14:43+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:14:43+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:14:43+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:14:44+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:14:44+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:14:44+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:14:44+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:14:44+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:14:44+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:14:45+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:14:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:14:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:14:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:14:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:14:55+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:14:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:14:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:14:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:14:57+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:14:58+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:15:01+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:15:01+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:15:02+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:15:02+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:15:09+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:15:09+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:15:09+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:15:09+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:15:09+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:15:10+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:15:10+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:15:10+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:15:10+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -D --asexplicit nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:24:47+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -Rs nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:24:47+0300] [ALPM] transaction started
[2026-06-02T19:24:47+0300] [ALPM] removed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:24:48+0300] [ALPM] removed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:24:48+0300] [ALPM] removed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2026-06-02T19:24:48+0300] [ALPM] removed nvidia-settings (595.71.05-1)
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service'.
[2026-06-02T19:24:48+0300] [ALPM] removed nvidia-utils (595.71.05-2)
[2026-06-02T19:24:48+0300] [ALPM] removed egl-x11 (1.0.5-1)
[2026-06-02T19:24:48+0300] [ALPM] removed egl-wayland2 (1.0.1-1)
[2026-06-02T19:24:48+0300] [ALPM] removed egl-wayland (4:1.1.21-1)
[2026-06-02T19:24:48+0300] [ALPM] removed egl-gbm (1.1.3-1)
[2026-06-02T19:24:48+0300] [ALPM] removed eglexternalplatform (1.2.1-1)
[2026-06-02T19:24:48+0300] [ALPM] transaction completed
[2026-06-02T19:24:48+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:24:48+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:24:48+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:24:48+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:24:49+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:24:51+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:24:52+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:24:55+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:24:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:24:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:24:56+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:25:02+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:25:03+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:25:03+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:25:03+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:25:03+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:25:04+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:25:05+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:25:07+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:25:07+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:25:07+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:25:07+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:25:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:25:14+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:25:14+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:25:14+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:25:14+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:25:14+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:25:14+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:25:14+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:25:15+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / --needed -Sy nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:25:15+0300] [PACMAN] synchronizing package lists
[2026-06-02T19:25:16+0300] [ALPM] transaction started
[2026-06-02T19:25:16+0300] [ALPM] installed eglexternalplatform (1.2.1-1)
[2026-06-02T19:25:16+0300] [ALPM] installed egl-wayland (4:1.1.21-1)
[2026-06-02T19:25:16+0300] [ALPM] installed egl-wayland2 (1.0.1-1)
[2026-06-02T19:25:16+0300] [ALPM] installed egl-gbm (1.1.3-1)
[2026-06-02T19:25:16+0300] [ALPM] installed egl-x11 (1.0.5-1)
[2026-06-02T19:25:17+0300] [ALPM] installed nvidia-utils (595.71.05-2)
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' -> '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' -> '/usr/lib/systemd/system/nvidia-suspend.service'.
[2026-06-02T19:25:17+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service' -> '/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service'.
[2026-06-02T19:25:17+0300] [ALPM] installed nvidia-settings (595.71.05-1)
[2026-06-02T19:25:17+0300] [ALPM] installed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:25:17+0300] [ALPM] installed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:25:17+0300] [ALPM] installed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:25:17+0300] [ALPM] transaction completed
[2026-06-02T19:25:17+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2026-06-02T19:25:18+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:25:18+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:25:18+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:25:18+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:25:18+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:25:19+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:25:19+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:25:19+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:25:19+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:25:19+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:25:19+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:25:20+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:25:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:25:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:25:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:25:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:25:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:25:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:25:30+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:25:30+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:25:30+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:25:30+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:25:30+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:25:31+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:25:34+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:25:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:25:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:25:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:25:40+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:25:41+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:25:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:25:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:25:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:25:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:25:42+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:25:42+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:25:42+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:25:42+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:25:42+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:25:42+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:25:42+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:25:42+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -D --asexplicit nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:29:30+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -Rs nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:29:30+0300] [ALPM] transaction started
[2026-06-02T19:29:30+0300] [ALPM] removed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:29:30+0300] [ALPM] removed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:29:30+0300] [ALPM] removed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2026-06-02T19:29:30+0300] [ALPM] removed nvidia-settings (595.71.05-1)
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service'.
[2026-06-02T19:29:30+0300] [ALPM] removed nvidia-utils (595.71.05-2)
[2026-06-02T19:29:30+0300] [ALPM] removed egl-x11 (1.0.5-1)
[2026-06-02T19:29:30+0300] [ALPM] removed egl-wayland2 (1.0.1-1)
[2026-06-02T19:29:30+0300] [ALPM] removed egl-wayland (4:1.1.21-1)
[2026-06-02T19:29:30+0300] [ALPM] removed egl-gbm (1.1.3-1)
[2026-06-02T19:29:30+0300] [ALPM] removed eglexternalplatform (1.2.1-1)
[2026-06-02T19:29:30+0300] [ALPM] transaction completed
[2026-06-02T19:29:30+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:29:30+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:29:30+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:29:30+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:29:30+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:29:32+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:29:32+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:29:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:29:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:29:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:29:35+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:29:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:29:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:29:42+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:29:42+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:29:42+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:29:42+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:29:42+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:29:43+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:29:46+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:29:47+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:29:47+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:29:47+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:29:52+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:29:52+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:29:52+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:29:53+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:29:53+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:29:53+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:29:53+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:29:54+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:29:54+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:29:54+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:29:54+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:29:54+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:29:54+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:29:58+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / --needed -Sy nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-02T19:29:58+0300] [PACMAN] synchronizing package lists
[2026-06-02T19:29:59+0300] [ALPM] transaction started
[2026-06-02T19:29:59+0300] [ALPM] installed eglexternalplatform (1.2.1-1)
[2026-06-02T19:29:59+0300] [ALPM] installed egl-wayland (4:1.1.21-1)
[2026-06-02T19:29:59+0300] [ALPM] installed egl-wayland2 (1.0.1-1)
[2026-06-02T19:29:59+0300] [ALPM] installed egl-gbm (1.1.3-1)
[2026-06-02T19:29:59+0300] [ALPM] installed egl-x11 (1.0.5-1)
[2026-06-02T19:30:00+0300] [ALPM] installed nvidia-utils (595.71.05-2)
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' -> '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' -> '/usr/lib/systemd/system/nvidia-suspend.service'.
[2026-06-02T19:30:00+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service' -> '/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service'.
[2026-06-02T19:30:00+0300] [ALPM] installed nvidia-settings (595.71.05-1)
[2026-06-02T19:30:00+0300] [ALPM] installed lib32-nvidia-utils (595.71.05-1)
[2026-06-02T19:30:01+0300] [ALPM] installed linux612-nvidia-open (595.71.05-9)
[2026-06-02T19:30:01+0300] [ALPM] installed linux66-nvidia-open (595.71.05-7)
[2026-06-02T19:30:01+0300] [ALPM] transaction completed
[2026-06-02T19:30:01+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2026-06-02T19:30:01+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-02T19:30:01+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:30:01+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-02T19:30:01+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-02T19:30:01+0300] [ALPM] running '60-depmod.hook'...
[2026-06-02T19:30:02+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-02T19:30:02+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-02T19:30:02+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:30:02+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-02T19:30:02+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-02T19:30:02+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:30:03+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:30:06+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:30:06+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:30:06+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:30:06+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:30:11+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:30:12+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:30:12+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:30:12+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:30:12+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-02T19:30:13+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-02T19:30:14+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-02T19:30:17+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-02T19:30:17+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-02T19:30:17+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-02T19:30:17+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-02T19:30:22+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-02T19:30:22+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-02T19:30:22+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-02T19:30:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-02T19:30:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-02T19:30:23+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-02T19:30:24+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-02T19:30:24+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-02T19:30:24+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-02T19:30:24+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-02T19:30:24+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-02T19:30:24+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-02T19:30:24+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-02T19:30:24+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -D --asexplicit nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-03T15:10:11+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -Rs nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-03T15:10:11+0300] [ALPM] transaction started
[2026-06-03T15:10:11+0300] [ALPM] removed linux66-nvidia-open (595.71.05-7)
[2026-06-03T15:10:11+0300] [ALPM] removed linux612-nvidia-open (595.71.05-9)
[2026-06-03T15:10:11+0300] [ALPM] removed lib32-nvidia-utils (595.71.05-1)
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid...
[2026-06-03T15:10:12+0300] [ALPM] removed nvidia-settings (595.71.05-1)
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service'.
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service'.
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service'.
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service'.
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service'.
[2026-06-03T15:10:12+0300] [ALPM-SCRIPTLET] Removed '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service'.
[2026-06-03T15:10:12+0300] [ALPM] removed nvidia-utils (595.71.05-2)
[2026-06-03T15:10:12+0300] [ALPM] removed egl-x11 (1.0.5-1)
[2026-06-03T15:10:12+0300] [ALPM] removed egl-wayland2 (1.0.1-1)
[2026-06-03T15:10:12+0300] [ALPM] removed egl-wayland (4:1.1.21-1)
[2026-06-03T15:10:12+0300] [ALPM] removed egl-gbm (1.1.3-1)
[2026-06-03T15:10:12+0300] [ALPM] removed eglexternalplatform (1.2.1-1)
[2026-06-03T15:10:12+0300] [ALPM] transaction completed
[2026-06-03T15:10:12+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-03T15:10:13+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-03T15:10:13+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-03T15:10:13+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-03T15:10:13+0300] [ALPM] running '60-depmod.hook'...
[2026-06-03T15:10:16+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-03T15:10:16+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-03T15:10:20+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-03T15:10:20+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-03T15:10:20+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-03T15:10:20+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-03T15:10:27+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-03T15:10:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-03T15:10:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-03T15:10:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-03T15:10:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-03T15:10:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-03T15:10:30+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-03T15:10:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-03T15:10:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-03T15:10:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-03T15:10:33+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-03T15:10:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-03T15:10:37+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-03T15:10:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-03T15:10:38+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-03T15:10:38+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-03T15:10:38+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-03T15:11:19+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / --needed -Sy nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-03T15:11:19+0300] [PACMAN] synchronizing package lists
[2026-06-03T15:11:21+0300] [ALPM] transaction started
[2026-06-03T15:11:21+0300] [ALPM] installed eglexternalplatform (1.2.1-1)
[2026-06-03T15:11:21+0300] [ALPM] installed egl-wayland (4:1.1.21-1)
[2026-06-03T15:11:21+0300] [ALPM] installed egl-wayland2 (1.0.1-1)
[2026-06-03T15:11:21+0300] [ALPM] installed egl-gbm (1.1.3-1)
[2026-06-03T15:11:21+0300] [ALPM] installed egl-x11 (1.0.5-1)
[2026-06-03T15:11:22+0300] [ALPM] installed nvidia-utils (595.71.05-2)
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' -> '/usr/lib/systemd/system/nvidia-resume.service'.
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' -> '/usr/lib/systemd/system/nvidia-hibernate.service'.
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' -> '/usr/lib/systemd/system/nvidia-suspend.service'.
[2026-06-03T15:11:22+0300] [ALPM-SCRIPTLET] Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service' -> '/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service'.
[2026-06-03T15:11:22+0300] [ALPM] installed nvidia-settings (595.71.05-1)
[2026-06-03T15:11:22+0300] [ALPM] installed lib32-nvidia-utils (595.71.05-1)
[2026-06-03T15:11:23+0300] [ALPM] installed linux612-nvidia-open (595.71.05-9)
[2026-06-03T15:11:23+0300] [ALPM] installed linux66-nvidia-open (595.71.05-7)
[2026-06-03T15:11:23+0300] [ALPM] transaction completed
[2026-06-03T15:11:23+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2026-06-03T15:11:23+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2026-06-03T15:11:23+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-03T15:11:23+0300] [ALPM] running '35-systemd-udev-reload.hook'...
[2026-06-03T15:11:23+0300] [ALPM] running '35-systemd-update.hook'...
[2026-06-03T15:11:23+0300] [ALPM] running '60-depmod.hook'...
[2026-06-03T15:11:25+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.12.91-1-MANJARO'
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-03T15:11:25+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-03T15:11:28+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-03T15:11:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-03T15:11:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-03T15:11:29+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-03T15:11:36+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-03T15:11:36+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-03T15:11:36+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-03T15:11:36+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET] ==> Starting build: '6.6.141-1-MANJARO'
[2026-06-03T15:11:37+0300] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2026-06-03T15:11:38+0300] [ALPM-SCRIPTLET]   -> Running build hook: [systemd]
[2026-06-03T15:11:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2026-06-03T15:11:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [microcode]
[2026-06-03T15:11:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2026-06-03T15:11:41+0300] [ALPM-SCRIPTLET]   -> Running build hook: [kms]
[2026-06-03T15:11:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2026-06-03T15:11:48+0300] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2026-06-03T15:11:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [sd-vconsole]
[2026-06-03T15:11:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2026-06-03T15:11:48+0300] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET]   -> Early uncompressed CPIO image generation successful
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2026-06-03T15:11:49+0300] [ALPM] running 'dbus-reload.hook'...
[2026-06-03T15:11:49+0300] [ALPM-SCRIPTLET]   Skipped: Running in chroot.
[2026-06-03T15:11:49+0300] [ALPM] running 'update-desktop-database.hook'...
[2026-06-03T15:11:49+0300] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /etc/pacman.conf --root / -D --asexplicit nvidia-utils nvidia-settings lib32-nvidia-utils linux612-nvidia-open linux66-nvidia-open'
[2026-06-03T18:32:30+0300] [PACMAN] Running 'pacman -Sy'
[2026-06-03T18:32:30+0300] [PACMAN] synchronizing package lists
[2026-06-03T18:32:36+0300] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2026-06-03T18:32:36+0300] [PACMAN] synchronizing package lists
[2026-06-03T18:47:23+0300] [PACMAN] Running 'pacman -Syyu'
[2026-06-03T18:47:23+0300] [PACMAN] synchronizing package lists
[2026-06-03T18:47:23+0300] [PACMAN] starting full system upgrade
Hi @retired – Welcome back.
Your post has been moved to a dedicated topic. :eyes:
A little housekeeping:
For future reference, the general rule for Support categories is one thread per topic per user, irrespective of how similar the issue might seem to be to another topic.
Thank you for adding your inxi output – this is often useful for those wishing to help – however, the “12’s” contaminating the output make the information difficult to read. :point_left:
These “12’s” are unfortunately generated when running inxi in a chroot environment – there is a workaround, as described in the Mini-HowTo (added below) – please edit your post and replace the inxi content with output generated by the revised inxi command noted in the Mini-HowTo.
inxi -zv8 (short-form)
Your privacy is respected
Thanks for the help, initial post now updated.
I’m not using Nvidia hardware, so my expertise here is limited but clearly no graphic driver is installed. Have you tried to install the free version in chroot environment? Just to get the system booting again.
I removed the quiet splash from the GRUB init and saw that it started hanging with the text A start job is running for /swapfile (<time taken> / no limit).
So with some AI help I was told to add systemd.swap=0 noresume to the GRUB init and volà I am now booted into my Manjaro. Now I guess I have to remove that swap and add a new one.
I will also remove quiet splash from here on.
I ran that as chroot. I wonder if that can affect the results. I have no idea. Now, logged in I get these results:
> nvidia-smi
Thu Jun  4 10:27:47 2026
| NVIDIA-SMI 595.71.05              Driver Version: 595.71.05      CUDA Version: 13.2     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  NVIDIA GeForce RTX 5070 Ti     Off |   00000000:01:00.0  On |                  N/A |
|  0%   42C    P8             25W /  300W |     731MiB /  16303MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A            1444      G   /usr/lib/Xorg                            22MiB |
|    0   N/A  N/A            1567      G   /usr/bin/ksecretd                         3MiB |
|    0   N/A  N/A            1604      G   /usr/bin/kwin_wayland                    45MiB |
|    0   N/A  N/A            1692      G   /usr/bin/Xwayland                         4MiB |
|    0   N/A  N/A            1734      G   /usr/bin/ksmserver                        3MiB |
|    0   N/A  N/A            1736      G   /usr/bin/kded6                            3MiB |
|    0   N/A  N/A            1757      G   /usr/bin/plasmashell                    135MiB |
|    0   N/A  N/A            1818      G   /usr/bin/kaccess                          3MiB |
|    0   N/A  N/A            1819      G   ...it-kde-authentication-agent-1          3MiB |
|    0   N/A  N/A            1921      G   /usr/bin/kdeconnectd                      3MiB |
|    0   N/A  N/A            1993      G   /usr/bin/pamac-tray-plasma                3MiB |
|    0   N/A  N/A            2063      G   /usr/lib/xdg-desktop-portal-kde           3MiB |
|    0   N/A  N/A            2129      G   /usr/lib/electron39/electron             26MiB |
|    0   N/A  N/A            2217      G   /usr/lib/firefox/firefox                210MiB |
|    0   N/A  N/A            5538      G   /usr/bin/kate                             3MiB |
|    0   N/A  N/A            5700      G   /usr/bin/konsole                          3MiB |
Out of curiosity, since swap isn’t really required to run a system, why does it freeze versus skipping over.
Most welcome.
Note that when using the short form of an inxi command, the filter is implied by including z. The --filter parameter should be used only with the long form variety of the command. :eyes:
Upon system startup, the system checks whether the swap partition contains a system state saved during hibernation.
In this case, the contents of the swap partition must be loaded into RAM. And—just like that—if this data is corrupted, the boot process grinds to a halt.
:footprints:
This could be a case. However in the given case we have
This looks like there wasn’t any swap to begin with. The system has 64 GB of RAM and some users don’t create a swap partition if they think there is enough RAM. Anyway, thinking about it, even in case of hibernation and then corruption of the data, one wouldn’t try repeatedly to load something that can’t be loaded making the system unbootable :thinking:
  • Temporarily adding this to GRUB helps systemd.swap=0 noresume, can boot into Manjaro
  • Removed and re-created swapfile and problem still persists
sudo swapoff -a
sudo rm /swapfile
sudo fallocate -l 32G /swapfile
sudo chmod 600 /swapfile
sudo mkswap /swapfile
sudo swapon --show
fstab:
/swapfile  swap  swap  defaults   0 0
> sudo swapon --all --verbose
swapon: /swapfile: found signature [pagesize=4096, signature=swap]
swapon: /swapfile: pagesize=4096, swapsize=34359738368, devsize=34359738368
swapon /swapfile
In this and every other case, I would strongly advise replacing the swap file with a dedicated swap partition. :footprints:
Okay, I was thinking about it too. Problem is I have no un-allocated space in either the SSDs or the HDD. Got crap everywhere.
Those commands differ from what’s on the Swap - ArchWiki page.
These are the commands you probably should be running according to the above page:
sudo swapoff -a
sudo rm /swapfile
sudo mkswap -U clear --size 32G --file /swapfile
sudo swapon /swapfile
I had no issues setting up swap on my system a few months ago using those commands (except I made a smaller /swapfile as I use zswap to compress swap in RAM):
❯ swapon
NAME      TYPE SIZE USED PRIO
/swapfile file   8G   0B   -1
Also, I use the systemd swap unit mentioned on the above page instead of fstab:
/etc/systemd/system/swapfile.swap
[Swap]
What=/swapfile
[Install]
WantedBy=swap.target
So swap was very easy to enable by running:
systemctl enable swapfile.swap
You could try with a smaller swap file. 8 GB should be plenty. Or don’t use swap temporarily until you can create a 8 GB swap partition. (For hibernation 32 GB would be too small i think).
  • Temporarily added this to GRUB in the menu (key “e”) systemd.swap=0 noresume made it possible to boot into Manjaro
  • Using GParted I shrank the primary partion on my secondary SSD
  • Created a swap partition following https://wiki.manjaro.org/index.php?title=Swap
  • Deleted old /swapfile entry from fstab and /etc/default/grub
  • Created GRUB config(?) again using sudo grub-mkconfig -o /boot/grub/grub.cfg
