Boot error vmlinuz-4.18 not found,
Good afternoon,
During updating packages my system froze and later on restart, I got the message boot error vmlinuz-4.18*86_64 not found.
I have tried booting through live cd and tried previous solution in this forum. However I get the following output.
[manjaro ~]# manjaro-chroot -a
==> Detected systems:
 --> 0) ManjaroLinux
==> Select system to mount [0-0] :
0
==> ERROR: You can't mount 0!
Can you please help?
Do I need to reinstall Manjaro?
Any help is much appreciated. P.S. I am a newbie and not versatile with commandline/ terminal.
Kind regards.
I could use chroot and then got this message.
[manjaro ~]# mhwd-kernel -li
Currently running: 4.19.28-1-MANJARO (linux419)
   * linux419
[manjaro ~]# mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
[manjaro ~]# ls/etc/mkintcpio.d/*.preset
-bash: ls/etc/mkintcpio.d/*.preset: No such file or directory
Hello @ash
There was an really old bug, where you need to type 1 instead of 0. Could it be possible that you boot an really old ISO image?
EDIT:
This should be correct:
ls /etc/mkinitcpio.d/linux*
In general you do the following:
rm /etc/mkinitcpio.d/linux418.preset
mkinitcpio -P
update-grub
Tip: When pasting terminal output on Discourse forums, one can either…
  • Use the Preformatted text </> toolbar button.
  • Add three backticks ` above and below the text (Markdown):
    type or paste code here
  • Use HTML:
    <pre><code>
    </pre></code>
I’ve done it for you this time. :wink:
Sorry about that. Many thanks Yochanan.
[manjaro@manjaro ~]$ mhwd-kernel -li
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
   * linux419
[manjaro@manjaro ~]$ -Sy
bash: -Sy: command not found
[manjaro@manjaro ~]$ sudo mhwd-kernel -i linux510
Error: Please make sure if the given kernel(s) exist(s).
available kernels:
[manjaro@manjaro ~]$ sudo mhwd-kernel -i linux419
Error: You can't reinstall your current kernel. Please use 'pacman -Syu' instead to update.
[manjaro@manjaro ~]$ pacman -Syu
error: you cannot perform this operation unless you are root.
[manjaro@manjaro ~]$ Sudo pacman _Syu
bash: Sudo: command not found
[manjaro@manjaro ~]$ Sudo su
[manjaro@manjaro ~]$ su pacman -Syu
su: invalid option -- 'S'
Try 'su --help' for more information.
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
            [command]
usage: sudo [-AbEHknPS] [-C num] [-g group] [-h host] [-p prompt] [-T timeout]
            [-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-C num] [-g group] [-h host] [-p prompt] [-T timeout]
            [-u user] file ...
[manjaro@manjaro ~]$ sudo pacman -Syu
 core                     170.7 KiB  2032K/s 00:00 [######################] 100%
 extra                   1915.6 KiB  4.49M/s 00:00 [######################] 100%
 community                  6.7 MiB  8.25M/s 00:01 [######################] 100%
 multilib                 176.1 KiB  8.60M/s 00:00 [######################] 100%
:: Some packages should be upgraded first...
resolving dependencies...
Packages (3) archlinux-keyring-20211028-1  manjaro-keyring-20210910-2
             manjaro-system-20210612-1
Total Download Size:   1.12 MiB
Total Installed Size:  1.53 MiB
Net Upgrade Size:      0.44 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 archlinux-keyring-2...   979.1 KiB  4.10M/s 00:00 [######################] 100%
 manjaro-keyring-202...   141.6 KiB  6.91M/s 00:00 [######################] 100%
 manjaro-system-2021...    22.9 KiB  0.00B/s 00:00 [######################] 100%
(3/3) checking keys in keyring                     [######################] 100%
downloading required keys...
error: key "6D42BDD116E0068F" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
:: Replace intel-tbb with extra/tbb? [Y/n] Y
:: Replace jack with extra/jack2? [Y/n] y
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] y
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] y
:: Replace libdmx with extra/xorgproto-transfer? [Y/n] y
:: Replace libmagick with extra/imagemagick? [Y/n] y
:: Replace libutil-linux with core/util-linux-libs? [Y/n] y
:: Replace libwbclient with extra/smbclient? [Y/n] y
:: Replace manjaro-xfce-gtk3-settings with community/manjaro-xfce-settings? [Y/n] y
warning: mhwd-nvidia: local (1:418.43-1) is newer than extra (495.44-4)
:: Replace pamac with extra/pamac-gtk? [Y/n] y
:: Replace pygobject-devel with extra/python-gobject? [Y/n] y
:: Replace python-dbus with extra/dbus-python? [Y/n] y
:: Replace python-dbus-common with extra/dbus-python? [Y/n] y
:: Replace python-xdg with extra/python-pyxdg? [Y/n] y
:: Replace steam-devices with community/game-devices-udev? [Y/n] y
:: Replace xdg-desktop-portal-gtk with extra/xdg-desktop-portal-gnome? [Y/n] y
:: There are 2 providers available for libgdk-3.so=0-64:
:: Repository extra
   1) gtk3
:: Repository community
   2) gtk3-typeahead
Enter a number (default=1): 1
:: gtk3 and gtk3-classic are in conflict (gtk3-print-backends). Remove gtk3-classic? [y/N] y
:: python-pyqt5 and pyqt5-common are in conflict. Remove pyqt5-common? [y/N] y
:: removing gtk3-classic breaks dependency 'gtk3-classic>=3.24.5' required by lib32-gtk3-classic
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace intel-tbb with extra/tbb? [Y/n] y
:: Repository extra
   1) gtk3
   2) gtk3-typeahead
Enter a number (default=1): 2
:: gtk3-typeahead and gtk3-classic are in conflict (gtk3). Remove gtk3-classic? [y/N] y
[manjaro@manjaro ~]$ sudo su-
sudo: su-: command not found
[manjaro@manjaro ~]$ manjaro -chroot -a
bash: manjaro: command not found
[manjaro@manjaro ~]$ sudo su -
 --> 0) ManjaroLinux
0
[manjaro ~]# ^C
[manjaro ~]# sudo manjaro-chroot
==> ERROR: Can't create chroot on non-directory
[manjaro ~]# sudo manjaro-chroot -dev/nvme0n1p7
usage: manjaro-chroot -a [or] manjaro-chroot chroot-dir [command]
    -a             Automount detected linux system
    -h             Print this help message
    -q             Query settings and pretend
    If 'command' is unspecified, manjaro-chroot will launch /bin/sh.
    If 'automount' is true, manjaro-chroot will launch /bin/bash
    and .
[manjaro ~]# mhdd-kernel -li
-bash: mhdd-kernel: command not found
   * linux419
[manjaro ~]# ^C
[manjaro ~]# sudo pacman-mirrors -f && sudo pacman -Syyu
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.978 Indonesia      : https://mirror.deace.id/manjaro/
  1.006 Indonesia      : http://mirror.deace.id/manjaro/
  ..... China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
::ERROR _ssl.c:1039: The handshake operation timed out 'https://mirrors.sjtug.sjtu.edu.cn/manjaro/'
  0.254 Switzerland    : https://mirror.init7.net/manjaro/
  0.160 Switzerland    : http://mirror.init7.net/manjaro/
  1.849 New_Zealand    : http://manjaro.mirrors.theom.nz/
  1.128 Philippines    : http://mirror.rise.ph/manjaro/
  ..... Philippines    : ftp://mirror.rise.ph/manjaro/
  2.833 Chile          : https://mirror.ufro.cl/manjaro/
  1.208 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  0.918 United_States  : https://mirrors.gigenet.com/manjaro/
  0.521 United_States  : http://mirrors.gigenet.com/manjaro/
  0.241 Netherlands    : http://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.602 Netherlands    : ftp://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.701 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  1.029 Canada         : https://muug.ca/mirror/manjaro/
  0.702 Canada         : http://muug.ca/mirror/manjaro/
  0.161 France         : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.261 France         : ftp://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.367 Netherlands    : https://mirror.koddos.net/manjaro/
  ..... China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
::ERROR _ssl.c:1039: The handshake operation timed out 'https://mirrors.tuna.tsinghua.edu.cn/manjaro/'
  1.812 Brazil         : https://manjaro.c3sl.ufpr.br/
  0.380 Poland         : http://ftp.vectranet.pl/manjaro/
  0.651 Poland         : ftp://ftp.vectranet.pl/manjaro/
  0.476 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.292 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  0.410 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.599 Netherlands    : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.589 Ukraine        : https://fastmirror.pp.ua/manjaro/
  0.285 Ukraine        : http://fastmirror.pp.ua/manjaro/
  1.446 Bangladesh     : http://mirror.xeonbd.com/manjaro/
  0.806 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  1.251 India          : https://mirrors.piconets.webwerks.in/manjaro-mirror/
  0.670 India          : http://mirrors.piconets.webwerks.in/manjaro-mirror/
  ..... Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  3.284 China          : https://mirrors.ustc.edu.cn/manjaro/
  1.454 Pakistan       : https://repo.inara.pk/manjaro/
  0.827 Pakistan       : http://repo.inara.pk/manjaro/
  0.148 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/re
  ..... Indonesia      : http://kartolo.sby.datautama.net.id/manjaro/
  2.071 Uruguay        : https://manjaro.repo.cure.edu.uy/
  1.171 Uruguay        : http://manjaro.repo.cure.edu.uy/
  0.407 Australia      : https://manjaro.lucassymons.net/
  0.791 Poland         : https://repo.skni.umcs.pl/manjaro/
  0.348 Poland         : http://repo.skni.umcs.pl/manjaro/
  0.403 Ukraine        : http://mirrors.colocall.net/manjaro/
  ..... Ukraine        : ftp://mirrors.colocall.net/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.colocall.net/manjaro/'
  0.310 Switzerland    : https://manjaro.osmir.ch/
  0.237 Switzerland    : http://manjaro.osmir.ch/
  0.812 Georgia        : https://repos.silknet.com/manjaro/
  0.470 Georgia        : http://repos.silknet.com/manjaro/
  0.282 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  0.610 Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
  0.587 Georgia        : http://manjaro.grena.ge/
  0.306 Sweden         : https://mirror.zetup.net/manjaro/
  0.815 Canada         : https://mirror.0xem.ma/manjaro/
  0.625 Canada         : http://mirror.0xem.ma/manjaro/
  0.763 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  0.227 Belgium        : http://ftp.belnet.be/mirrors/manjaro/repos/
  0.490 Belgium        : ftp://ftp.belnet.be/mirrors/manjaro/repos/
  1.274 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.275 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.486 Sweden         : ftp://ftp.lysator.liu.se/pub/manjaro/
  1.173 South_Africa   : http://mirror.is.co.za/mirrors/manjaro.org/
  0.778 Canada         : https://osmirror.org/manjaro/
  0.162 United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/
  0.093 United_Kingdom : http://mirrors.gethosted.online/manjaro/repos/
  ..... South_Africa   : http://manjaro.mirror.ac.za/
  1.539 Chile          : https://mirror1.cl.netactuate.com/manjaro/
  1.407 Chile          : http://mirror1.cl.netactuate.com/manjaro/
  ..... Chile          : ftp://mirror1.cl.netactuate.com/manjaro/
  0.820 Greece         : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.583 Greece         : http://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  ..... Greece         : ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/'
  1.057 United_States  : https://repo.ialab.dsu.edu/manjaro/
  0.878 United_States  : http://repo.ialab.dsu.edu/manjaro/
  ..... China          : https://mirror.nju.edu.cn/manjaro/
::ERROR _ssl.c:1039: The handshake operation timed out 'https://mirror.nju.edu.cn/manjaro/'
  ..... China          : http://mirror.nju.edu.cn/manjaro/
::ERROR TIMEOUT 'http://mirror.nju.edu.cn/manjaro/'
  0.434 Bulgaria       : https://mirror.telepoint.bg/manjaro/
  0.290 Bulgaria       : http://mirror.telepoint.bg/manjaro/
  ..... Bulgaria       : ftps://mirror.telepoint.bg/manjaro/
::ERROR unknown url type: ftps 'ftps://mirror.telepoint.bg/manjaro/'
  0.116 Global         : https://mirrors.manjaro.org/repo/
  0.100 Global         : http://mirrors.manjaro.org/repo/
  0.455 Iceland        : https://mirrors.opensource.is/manjaro/
  0.454 Iceland        : http://mirrors.opensource.is/manjaro/
  ..... Iceland        : ftp://mirrors.opensource.is/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.opensource.is/manjaro/'
  0.278 Austria        : http://mirror.easyname.at/manjaro/
  0.500 Austria        : ftp://mirror.easyname.at/manjaro/
  0.290 Germany        : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.447 Germany        : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.732 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  0.181 Belgium        : https://mirror.futureweb.be/manjaro/
  0.121 Belgium        : http://mirror.futureweb.be/manjaro/
  0.699 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.396 Spain          : http://ftp.caliu.cat/pub/distribucions/manjaro/
  0.446 Italy          : https://manjaro.mirror.garr.it/manjaro/
  1.463 Chile          : http://manjaro.dcc.uchile.cl/
  0.964 Russia         : https://mirror.truenetwork.ru/manjaro/
  0.515 Russia         : http://mirror.truenetwork.ru/manjaro/
  0.338 Denmark        : https://mirrors.dotsrc.org/manjaro/
  0.302 Czech          : https://mirror.dkm.cz/manjaro/
  0.192 Germany        : https://manjaro.moson.eu/
  0.149 Germany        : http://manjaro.moson.eu/
  0.545 Portugal       : http://ftp.dei.uc.pt/pub/linux/manjaro/
  2.465 Australia      : https://mirror.aarnet.edu.au/pub/manjaro/
  1.734 Australia      : http://mirror.aarnet.edu.au/pub/manjaro/
  0.301 Germany        : https://mirror.alpix.eu/manjaro/
  0.102 United_Kingdom : http://manjaro.mirrors.uk2.net/
  0.432 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.352 Germany        : https://mirror.moson.org/manjaro/
  0.159 Germany        : http://mirror.moson.org/manjaro/
  0.181 Netherlands    : https://manjaro.mirrors.lavatech.top/
  0.109 Netherlands    : http://manjaro.mirrors.lavatech.top/
  0.226 Germany        : https://mirror.23m.com/manjaro/
  ..... Finland        : https://manjaro.kyberorg.fi/
  0.248 Finland        : http://manjaro.kyberorg.fi/
  2.665 Singapore      : https://download.nus.edu.sg/mirror/manjaro/
  1.164 Singapore      : http://ossmirror.mycloud.services/os/linux/manjaro/
  0.229 Germany        : https://mirror.netcologne.de/manjaro/
  0.278 Germany        : https://ftp.gwdg.de/pub/linux/manjaro/
  0.188 Germany        : http://ftp.gwdg.de/pub/linux/manjaro/
  0.634 Germany        : ftp://ftp.gwdg.de/pub/linux/manjaro/
  0.853 Global         : https://mirrors.fossho.st/manjaro/
  0.066 Global         : http://mirrors.fossho.st/manjaro/
  1.379 Thailand       : https://mirror.kku.ac.th/manjaro/
  1.070 Thailand       : http://mirror.kku.ac.th/manjaro/
  ..... Thailand       : ftp://mirror.kku.ac.th/manjaro/
  1.367 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  0.812 Kenya          : http://manjaro.mirror.liquidtelecom.com/
  0.756 Iran           : https://mirror.bardia.tech/manjaro/
  1.175 Iran           : http://mirror.bardia.tech/manjaro/
  0.932 United_States  : https://mirror.clarkson.edu/manjaro/
  0.164 United_Kingdom : https://mirror.cyberhost.uk/sites/manjaro/
  0.610 Belarus        : http://mirror.datacenter.by/pub/mirrors/manjaro/
  0.512 Bulgaria       : http://manjaro.telecoms.bg/
  0.352 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  0.495 Sweden         : https://ftpmirror1.infania.net/mirror/manjaro/
  0.249 Sweden         : http://ftpmirror1.infania.net/mirror/manjaro/
  0.504 Sweden         : ftp://ftpmirror1.infania.net/mirror/manjaro/
  0.650 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  1.345 United_States  : https://mirrors.sonic.net/manjaro/
::INFO Writing mirror list
::Global          : https://mirrors.fossho.st/manjaro/stable
::United_Kingdom  : https://mirrors.gethosted.online/manjaro/repos/stable
::Global          : https://mirrors.manjaro.org/repo/stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable
::Netherlands     : https://manjaro.mirrors.lavatech.top/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/sta
::Germany         : https://manjaro.moson.eu/stable
::Germany         : https://mirror.moson.org/manjaro/stable
::Switzerland     : https://mirror.init7.net/manjaro/stable
::United_Kingdom  : https://mirror.cyberhost.uk/sites/manjaro/stable
::Germany         : https://mirror.23m.com/manjaro/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Switzerland     : https://manjaro.osmir.ch/stable
::Finland         : https://manjaro.kyberorg.fi/stable
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Ukraine         : https://fastmirror.pp.ua/manjaro/stable
::Bulgaria        : https://mirror.telepoint.bg/manjaro/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Czech           : https://mirror.dkm.cz/manjaro/stable
::Sweden          : https://mirror.zetup.net/manjaro/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Poland          : https://repo.skni.umcs.pl/manjaro/stable
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/stable
::Netherlands     : https://mirror.koddos.net/manjaro/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::Australia       : https://manjaro.lucassymons.net/stable
::Bulgaria        : https://mirrors.netix.net/manjaro/stable
::Italy           : https://manjaro.mirror.garr.it/manjaro/stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Georgia         : https://repos.silknet.com/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::Belgium         : http://ftp.belnet.be/mirrors/manjaro/repos/stable
::Austria         : http://mirror.easyname.at/manjaro/stable
::Sweden          : https://ftpmirror1.infania.net/mirror/manjaro/stable
::Bulgaria        : http://manjaro.telecoms.bg/stable
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::United_States   : https://mirrors.gigenet.com/manjaro/stable
::Portugal        : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::Georgia         : http://manjaro.grena.ge/stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::Netherlands     : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Canada          : https://mirror.0xem.ma/manjaro/stable
::Germany         : https://ftp.gwdg.de/pub/linux/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::Poland          : http://ftp.vectranet.pl/manjaro/stable
::India           : https://mirrors.piconets.webwerks.in/manjaro-mirror/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Canada          : https://muug.ca/mirror/manjaro/stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Canada          : https://osmirror.org/manjaro/stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::Pakistan        : https://repo.inara.pk/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::United_States   : https://mirror.clarkson.edu/manjaro/stable
::Indonesia       : https://mirror.deace.id/manjaro/stable
::Singapore       : http://ossmirror.mycloud.services/os/linux/manjaro/stable
::Uruguay         : https://manjaro.repo.cure.edu.uy/stable
::South_Africa    : http://mirror.is.co.za/mirrors/manjaro.org/stable
::Iran            : https://mirror.bardia.tech/manjaro/stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::United_States   : https://mirrors.sonic.net/manjaro/stable
::Bangladesh      : http://mirror.xeonbd.com/manjaro/stable
::Chile           : http://manjaro.dcc.uchile.cl/stable
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Thailand        : https://mirror.kku.ac.th/manjaro/stable
::Chile           : https://mirror1.cl.netactuate.com/manjaro/stable
::Philippines     : http://mirror.rise.ph/manjaro/stable
::Singapore       : https://download.nus.edu.sg/mirror/manjaro/stable
::Chile           : https://mirror.ufro.cl/manjaro/stable
::Indonesia       : http://kartolo.sby.datautama.net.id/manjaro/stable
::China           : https://mirrors.ustc.edu.cn/manjaro/stable
::South_Africa    : http://manjaro.mirror.ac.za/stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::Ukraine         : http://mirrors.colocall.net/manjaro/stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::China           : http://mirror.nju.edu.cn/manjaro/stable
::Iceland         : https://mirrors.opensource.is/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
 core                     170.7 KiB  5.05M/s 00:00 [######################] 100%
 extra                   1915.6 KiB  9.04M/s 00:00 [######################] 100%
 community                  6.7 MiB  8.87M/s 00:01 [######################] 100%
 multilib                 176.1 KiB  10.1M/s 00:00 [######################] 100%
:: Repository extra
   1) gtk3
   2) gtk3-typeahead
[manjaro ~]# ^C
[manjaro ~]#
Hope it is okay this time , Sorry once again @megavolt, @ Yochanan!
@ash
Ok well I see… let’s start from the beginning:
  1. Close the terminal and start a new one.
  2. Run this to enter the chroot environment (no sudo su required):
manjaro-chroot -a
  1. type 1 if it asks, instead of 0. (old bug from an old ISO)
  2. Then you should be in chroot.
  3. Then check what presets are there:
ls /etc/mkinitcpio.d/*
  1. Remove the presets for kernel 4.18:
  1. Update the linux images:
mkinitcpio -P
  1. Update the grub boot menu:
update-grub
  1. Type this to exit:
sync && exit
Many thanks @megavolt!
[manjaro@manjaro ~]$ manjaro-chroot -a
 --> 0) ManjaroLinux
1
==> Mounting (ManjaroLinux) [/dev/nvme0n1p7]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
 --> mount: [/mnt/home]
[manjaro /]# ls /etc/mkinitcpio.d/*
/etc/mkinitcpio.d/linux419.preset.pacsave
[manjaro /]# rm /etc/mkinitcpio.d/linux418.preset
rm: cannot remove '/etc/mkinitcpio.d/linux418.preset': No such file or directory
[manjaro /]# rm /etc/mkinitcpio.d/linux419.preset
rm: cannot remove '/etc/mkinitcpio.d/linux419.preset': No such file or directory
[manjaro /]# mkinitcpio -P
==> ERROR: No presets found in /etc/mkinitcpio.d
[manjaro /]#
Sorry, still stuck. :weary:
Seems you have no kernel installed at all?
Please run (inside the chroot):
  1. Do a full upgrade:
pacman -Syyuu
  1. Show available and installed kernel:
mhwd-kernel -l && mhwd-kernel -li
Thanks @megavolt.
[manjaro /]# pacman -Syyuu
error: failed to synchronize all databases (unable to lock database)
[manjaro /]# mhwd -l && mhwd -li
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1c82) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2021.11.04               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.04               false            PCI
          video-nvidia            2021.11.04               false            PCI
    video-nvidia-470xx            2021.11.04               false            PCI
    video-nvidia-390xx            2021.11.04               false            PCI
> 0000:00:02.0 (0300:8086:3e91) Display controller Intel Corporation:
Remove the lock file:
rm /var/lib/pacman/db.lck
Run again:
pacman -Syyuu
Sorry again, you must be getting frustrated…
[manjaro /]# rm /var/lib/pacman/db.lck
 core                  170.7 KiB   742 KiB/s 00:00 [######################] 100%
 extra                1915.6 KiB  7.57 MiB/s 00:00 [######################] 100%
 community               6.7 MiB  7.20 MiB/s 00:01 [######################] 100%
 multilib              176.1 KiB  3.66 MiB/s 00:00 [######################] 100%
error: could not open file /var/lib/pacman/local/wine-6.21-1/desc: No such file or directory
Packages (18) libxcvt-0.1.1-1  webkit2gtk-4.1-2.34.1-2
              xf86-input-elographics-1.4.2-3  xf86-input-evdev-2.10.6-3
              xf86-input-libinput-1.2.0-2  xf86-input-void-1.4.1-6
              xf86-video-amdgpu-21.0.0-2
              xf86-video-ati-1:19.1.0.r9.g5eba006e-1
              xf86-video-intel-1:2.99.917+916+g31486f40-2
              xf86-video-nouveau-1.0.17-2  xfce4-sensors-plugin-1.4.2-1
              xfce4-whiskermenu-plugin-2.6.2-1  xfwm4-4.16.1-3
              xorg-server-21.1.1-3.1  xorg-server-common-21.1.1-3  yay-11.0.2-1
              yelp-41.1-1  zim-0.74.2-1
Total Installed Size:  132.65 MiB
Net Upgrade Size:      104.17 MiB
 webkit2gtk-4.1-2.34.1-2-x86_64 is up to date
 yay-11.0.2-1-x86_64 is up to date
 zim-0.74.2-1-any is up to date
 xorg-server-21.1.1-3.1-x86_64 is up to date
 yelp-41.1-1-x86_64 is up to date
 xf86-video-intel-1:2.99.917+916+g31486f40-2-x86_64 is up to date
 xfwm4-4.16.1-3-x86_64 is up to date
 xfce4-whiskermenu-plugin-2.6.2-1-x86_64 is up to date
 xfce4-sensors-plugin-1.4.2-1-x86_64 is up to date
 xf86-video-ati-1:19.1.0.r9.g5eba006e-1-x86_64 is up to date
 xf86-video-nouveau-1.0.17-2-x86_64 is up to date
 xf86-video-amdgpu-21.0.0-2-x86_64 is up to date
 xf86-input-libinput-1.2.0-2-x86_64 is up to date
 xf86-input-evdev-2.10.6-3-x86_64 is up to date
 xorg-server-common-21.1.1-3-x86_64 is up to date
 xf86-input-elographics-1.4.2-3-x86_64 is up to date
 libxcvt-0.1.1-1-x86_64 is up to date
 xf86-input-void-1.4.1-6-x86_64 is up to date
(18/18) checking keys in keyring                   [######################] 100%
(18/18) checking package integrity                 [######################] 100%
(18/18) loading package files                      [######################] 100%
(18/18) checking for file conflicts                [######################] 100%
error: failed to commit transaction (conflicting files)
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCClass.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCContext.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCException.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCValue.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCVirtualMachine.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/JSCWeakValue.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/annotation-glossary.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/ch01.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/home.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/index-all.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/index.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/jsc-glib-4.0-JSCOptions.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/jsc-glib-4.0-JSCVersion.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/jsc-glib-4.0.devhelp2 exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/left-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/left.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/right-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/right.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/style.css exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/up-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/jsc-glib-4.0/up.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitApplicationInfo.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitAuthenticationRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitAutomationSession.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitBackForwardList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitBackForwardListItem.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitColorChooserRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitConsoleMessage.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitContextMenu.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitContextMenuItem.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitCookieManager.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitDeviceInfoPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitDownload.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitEditorState.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitFaviconDatabase.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitFileChooserRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitFindController.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitFormSubmissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitFrame.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitGeolocationPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitHitTestResult.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitInputMethodContext.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitInstallMissingMediaPluginsPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitMediaKeySystemPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitNavigationAction.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitNavigationPolicyDecision.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitNetworkProxySettings.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitNotificationPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitOptionMenu.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitOptionMenuItem.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitPlugin.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitPointerLockPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitPolicyDecision.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitPrintOperation.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitResponsePolicyDecision.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitScriptWorld.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitSecurityManager.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitSecurityOrigin.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitSettings.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitURIRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitURIResponse.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitURISchemeRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitUserContentFilterStore.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitUserContentManager.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitUserMediaPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitUserMessage.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebContext.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebEditor.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebExtension.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebHitTestResult.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebInspector.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebPage.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebResource.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebView.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebsiteData.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebsiteDataAccessPermissionRequest.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWebsiteDataManager.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/WebKitWindowProperties.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/annotation-glossary.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/ch01.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/ch02.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/ch03.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/home.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/index-all.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/index.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/left-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/left.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/right-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/right.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/style.css exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/up-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/up.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-Geolocation-manager.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-The-title-for-the-notification..html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-The-title-of-the-custom-widget..html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-WebKitError.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-WebKitURIUtilities.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-WebKitUserContent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0-WebKitVersion.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkit2gtk-4.0/webkit2gtk-4.0.devhelp2 exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMAttr.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMBlob.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCDATASection.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCSSRule.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCSSRuleList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCSSStyleDeclaration.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCSSStyleSheet.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCSSValue.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMCharacterData.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMComment.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDOMImplementation.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDOMSelection.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDOMTokenList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDOMWindow.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDocument.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDocumentFragment.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMDocumentType.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMEvent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMFile.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMFileList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLAnchorElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLAppletElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLAreaElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLBRElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLBaseElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLBodyElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLButtonElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLCanvasElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLCollection.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLDListElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLDirectoryElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLDivElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLDocument.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLEmbedElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLFieldSetElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLFontElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLFormElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLFrameElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLFrameSetElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLHRElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLHeadElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLHeadingElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLHtmlElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLIFrameElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLImageElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLInputElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLLIElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLLabelElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLLegendElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLLinkElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLMapElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLMarqueeElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLMenuElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLMetaElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLModElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLOListElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLObjectElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLOptGroupElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLOptionElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLOptionsCollection.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLParagraphElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLParamElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLPreElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLQuoteElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLScriptElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLSelectElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLStyleElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableCaptionElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableCellElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableColElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableRowElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTableSectionElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTextAreaElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLTitleElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMHTMLUListElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMKeyboardEvent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMMediaList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMMouseEvent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMNamedNodeMap.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMNode.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMNodeIterator.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMNodeList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMObject.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMProcessingInstruction.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMRange.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMStyleSheet.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMStyleSheetList.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMText.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMTreeWalker.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMUIEvent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMWheelEvent.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMXPathExpression.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/WebKitDOMXPathResult.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/annotation-glossary.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/ch01.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/home.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/index-all.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/index.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/left-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/left.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/right-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/right.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/style.css exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/up-insensitive.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/up.png exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0-WebKitDOMEntityReference.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0-WebKitDOMEventTarget.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0-WebKitDOMHTMLBaseFontElement.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0-WebKitDOMNodeFilter.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0-WebKitDOMXPathNSResolver.html exists in filesystem
webkit2gtk-4.1: /usr/share/gtk-doc/html/webkitdomgtk-4.0/webkitdomgtk-4.0.devhelp2 exists in filesystem
No problem, as long as you go further, I will also :wink:
That needs some overwriting:
pacman -Syyuu --overwrite=/usr/*
Now I think I seem to know the problem. This happened during update of wine and winetricks.
[manjaro /]# mhwd-kernel -l && mhwd-kernel -li
available kernels:
   * linux414
   * linux419
   * linux44
   * linux49
   * linux510
   * linux513
   * linux514
   * linux515
   * linux516
   * linux54
   * linux510-rt
   * linux515-rt
   * linux419
Overwriting user worked!
[manjaro /]# pacman -Syyuu --overwrite=/usr/*
 core                  170.7 KiB   683 KiB/s 00:00 [######################] 100%
 extra                1915.6 KiB  6.68 MiB/s 00:00 [######################] 100%
 community               6.7 MiB  8.54 MiB/s 00:01 [######################] 100%
 multilib              176.1 KiB  4.00 MiB/s 00:00 [######################] 100%
(18/18) checking available disk space              [######################] 100%
( 1/18) upgrading xf86-input-elographics           [######################] 100%
( 2/18) upgrading xf86-input-evdev                 [######################] 100%
( 3/18) upgrading xf86-input-libinput              [######################] 100%
( 4/18) upgrading xf86-input-void                  [######################] 100%
( 5/18) upgrading xf86-video-amdgpu                [######################] 100%
( 6/18) upgrading xf86-video-ati                   [######################] 100%
( 7/18) upgrading xf86-video-intel                 [######################] 100%
( 8/18) upgrading xf86-video-nouveau               [######################] 100%
( 9/18) upgrading xfce4-sensors-plugin             [######################] 100%
(10/18) upgrading xfce4-whiskermenu-plugin         [######################] 100%
(11/18) upgrading xfwm4                            [######################] 100%
(12/18) upgrading xorg-server-common               [######################] 100%
(13/18) installing libxcvt                         [######################] 100%
(14/18) upgrading xorg-server                      [######################] 100%
(15/18) upgrading yay                              [######################] 100%
(16/18) installing webkit2gtk-4.1                  [######################] 100%
Optional dependencies for webkit2gtk-4.1
    geoclue: Geolocation support [installed]
    gst-plugins-good: media decoding [installed]
    gst-plugins-bad: media decoding [installed]
    gst-libav: nonfree media decoding [installed]
(17/18) upgrading yelp                             [######################] 100%
(18/18) upgrading zim                              [######################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Compiling GSettings XML schema files...
(3/5) Updating icon theme caches...
(4/5) Updating the desktop file MIME type cache...
(5/5) Updating the MIME type database...
available kernels:
   * linux414
   * linux419
   * linux44
   * linux49
   * linux510
   * linux513
   * linux514
   * linux515
   * linux516
   * linux54
   * linux510-rt
   * linux515-rt
   * linux419
Well thats another symptom… I believe you did a upgrade and it crashed at a point…?
Yes, it was during package update that it froze.
Good now we delete this bad database folder:
rm -Rf /var/lib/pacman/local/wine-6.21-1/
and run again:
pacman -Sy
Then mhwd-kernel should work…
Thanks, once again :pray:
available kernels:
   * linux414
   * linux419
   * linux44
   * linux49
   * linux510
   * linux513
   * linux514
   * linux515
   * linux516
   * linux54
   * linux510-rt
   * linux515-rt
   * linux419
Do I need to update it now? to Linux515/ 516…
Now reinstall it again:
mhwd-kernel -r linux419
Better would be using kernel 5.4 or 5.10, which are also LTS (Long Term Support)…
mhwd-kernel -i linux54
But it depends on your hardware, which I don’t know.
[manjaro /]# mhwd-kernel -r linux419
Error: You can't remove your current kernel.
Should I just install 54 first and then remove old one?
Thanks again.
