Hello, I had a problem today where my computer would not boot after I entered the encyption password it went to a black screen and sat there forever.
So, I tried holding down shift to get into the grub, but that didn’t work, so I tried to restore it with a live disk but, it actually started working again after I tried to mount the encypted manjaro system on the live disk (Which did not work) and restarted my computer a couple of times.
I am wonddering why there was a problem in the first place.
Here are the journalctl errors. I am wondering what the errors are from around the time I stopped using my computer yesterday to when it started working again today.
Feb 14 15:17:28 noah-82dq knshandler[6139]: kf.newstuff.core: Could not determine type of archive file ' "/tmp/wtboQy-KDE Plasma Scenery 76.png" '
Feb 14 15:18:15 noah-82dq knshandler[6210]: kf.newstuff.core: Command ' "sddmthemeinstaller -i /tmp/Kde-Story-Light-Blur.zip" ' failed with code 255
Feb 14 16:21:35 noah-82dq pulseaudio[1602]: Failed to find a working profile.
Feb 14 16:21:35 noah-82dq pulseaudio[1602]: Failed to load module "module-alsa-card" (argument: "device_id="2" name="usb-motorola_moto_g_7__ZY225DQVPZ-00" card_name="alsa_card.usb-motorola_moto_g_7__ZY225DQVPZ-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
-- Boot 5b03dd54ad3a4e6d8b9df259c3413806 --
Feb 15 06:13:46 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot 263271a550b64747bfebc29bec2a6bb0 --
Feb 15 06:23:49 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot 9a2846e2780b4959bc33115ed8bbcd1c --
Feb 15 06:31:16 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot a75f774e166d4ae39851bfa6111cfcf8 --
Feb 15 06:33:59 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot fd4d8c01a87e4c3ea5549a2991ca9f1f --
Feb 15 06:36:20 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Feb 15 06:36:20 noah-82dq kernel: snd_pci_acp3x 0000:03:00.5: Invalid ACP audio mode : 0
Feb 15 06:36:32 noah-82dq kernel: xhci_hcd 0000:03:00.4: xHCI host controller not responding, assume dead
Feb 15 06:36:32 noah-82dq kernel: xhci_hcd 0000:03:00.4: HC died; cleaning up
Feb 15 06:36:32 noah-82dq kernel: Bluetooth: hci0: Failed to send headers (-110)
Feb 15 06:36:49 noah-82dq kernel: watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [systemd-udevd:357]
-- Boot b53d27c4c6f643ba9bbcda1a8882858b --
Feb 15 06:40:06 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Feb 15 06:40:06 noah-82dq kernel: snd_pci_acp3x 0000:03:00.5: Invalid ACP audio mode : 0
-- Boot aa26b5771dfe4c3eaf3f0da369de64eb --
Feb 15 06:41:28 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot 06991f6cace641739424f3fb43a38a3e --
Feb 15 06:46:38 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot ae98173f922a441899e02812e187b6e6 --
Feb 15 06:57:35 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot ad7f9b068a55499385af48ee14e92829 --
Feb 15 06:58:26 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot e4a2417613794f5290d767824aa36910 --
Feb 15 07:00:20 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
-- Boot 66abc8410d834d8aa76a3c5c0ae41608 --
Feb 15 07:42:16 noah-82dq kernel: pci 0000:00:00.2: AMD-Vi: Unable to read/write to IOMMU perf counter.
Feb 15 07:42:16 noah-82dq kernel: snd_pci_acp3x 0000:03:00.5: Invalid ACP audio mode : 0
Feb 15 07:42:17 noah-82dq systemd-backlight[961]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Feb 15 07:42:17 noah-82dq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Feb 15 07:42:17 noah-82dq systemd-backlight[963]: amdgpu_bl0: Failed to write system 'brightness' attribute: No such device or address
Feb 15 07:42:18 noah-82dq systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
Feb 15 07:42:20 noah-82dq systemd[1]: Failed to start Service for snap application anbox.container-manager.
Feb 15 07:42:22 noah-82dq python[1886]: backintime (noah/1): ERROR: Back In Time is not configured!
Feb 15 07:42:26 noah-82dq systemd-coredump[2186]: Process 1612 (baloo_file) of user 1000 dumped core.
Stack trace of thread 2184:
#0 0x00007fb27e5f6396 n/a (liblmdb.so + 0x4396)
#1 0x00007fb27e5f8efe n/a (liblmdb.so + 0x6efe)
#2 0x00007fb27e5f9644 n/a (liblmdb.so + 0x7644)
#3 0x00007fb27e5f9c50 mdb_get (liblmdb.so + 0x7c50)
#4 0x00007fb27fad2355 _ZN5Baloo12IdFilenameDB3getEy (libKF5BalooEngine.so.5 + 0x15355)
#5 0x00007fb27facc3ac _ZNK5Baloo13DocumentUrlDB3getEy (libKF5BalooEngine.so.5 + 0xf3ac)
#6 0x00007fb27fadd135 _ZNK5Baloo11Transaction11documentUrlEy (libKF5BalooEngine.so.5 + 0x20135)
#7 0x000055759f6d6e94 n/a (baloo_file + 0x1de94)
#8 0x00007fb27fae45af _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x275af)
#9 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#10 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#11 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#12 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#13 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#14 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#15 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#16 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#17 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#18 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#19 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#20 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#21 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#22 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#23 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#24 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#25 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#26 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#27 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#28 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#29 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#30 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#31 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#32 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#33 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#34 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#35 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#36 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#37 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#38 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#39 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#40 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#41 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#42 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#43 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#44 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#45 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#46 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#47 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#48 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#49 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#50 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#51 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#52 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#53 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#54 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#55 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#56 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#57 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#58 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#59 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#60 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#61 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#62 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
#63 0x00007fb27fae4607 _ZN5Baloo16WriteTransaction17removeRecursivelyEyRKSt8functionIFbyEE (libKF5BalooEngine.so.5 + 0x27607)
Stack trace of thread 1629:
#0 0x00007fb27f16b47f __poll (libc.so.6 + 0xf447f)
#1 0x00007fb27ddfebbf n/a (libglib-2.0.so.0 + 0xa6bbf)
#2 0x00007fb27dda93a1 g_main_context_iteration (libglib-2.0.so.0 + 0x513a1)
#3 0x00007fb27f8746e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#4 0x00007fb27f81a3fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#5 0x00007fb27f632d22 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd22)
#6 0x00007fb27fb08098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007fb27f633f0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007fb27e668299 start_thread (libpthread.so.0 + 0x9299)
#9 0x00007fb27f176153 __clone (libc.so.6 + 0xff153)
Stack trace of thread 1612:
#5 0x00007fb27f822894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#6 0x000055759f6c62b4 n/a (baloo_file + 0xd2b4)
#7 0x00007fb27f09eb25 __libc_start_main (libc.so.6 + 0x27b25)
#8 0x000055759f6c64be n/a (baloo_file + 0xd4be)
Stack trace of thread 1630:
#0 0x00007fb27f16dcf3 pselect (libc.so.6 + 0xf6cf3)
#1 0x00007fb27d840524 n/a (libusbmuxd-2.0.so.6 + 0x2524)
#2 0x00007fb27d8418a9 n/a (libusbmuxd-2.0.so.6 + 0x38a9)
#3 0x00007fb27e668299 start_thread (libpthread.so.0 + 0x9299)
#4 0x00007fb27f176153 __clone (libc.so.6 + 0xff153)
