BOOT EFI How To Restore?
Hi,
How to restore my efi boot ? I did a debian (Boot0003 debian) install on usb key, no issue with the key.
Now I have to select in the bios the disc to boot, the manjaro boot screen appears, I select the wished manjaro linux and then a blinking underscore appears on the top left, I have to wait a long time before the os boot… I’m not a power user, thanks for your help in advance :slight_smile:
[nls@lap ~]$ sudo parted -l
Model: ATA SanDisk SDSSDH3 (scsi)
Disk /dev/sda: 1000GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      1049kB  316MB   315MB   fat32                 boot, esp
 3      316MB   8704MB  8389MB  linux-swap(v1)        swap
 2      8704MB  218GB   210GB   ext4
 4      218GB   1000GB  782GB                         msftdata
[nls@lap ~]$ sudo efibootmgr -v
[sudo] password for nls:
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0003,0000,0001,2001,2002,2003
Boot0000* EFI Hard Drive (SanDisk SDSSDH3 1T00) PciRoot(0x0)/Pci(0x17,0x0)/Sata(0,0,0)/HD(1,GPT,6d22d5f3-2723-994b-9d6d-4f6d02f53ba7,0x800,0x96000)RC
      dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 17 / 03 12 0a 00 00 00 00 00 00 00 / 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 60 09 00 00 00 00 00 f3 d5 22 6d 23 27 4b 99 9d 6d 4f 6d 02 f5 3b a7 02 02 / 7f ff 04 00
    data: 52 43
Boot0001* Windows Boot Manager  HD(2,GPT,076a76a0-929a-42cd-bfae-050e49cd7b70,0x202fff,0x31800)/\EFI\Microsoft\Boot\bootmgfw.efi57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d0000006f000100000010000000040000007fff0400
      dp: 04 01 2a 00 02 00 00 00 ff 2f 20 00 00 00 00 00 00 18 03 00 00 00 00 00 a0 76 6a 07 9a 92 cd 42 bf ae 05 0e 49 cd 7b 70 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 4d 00 69 00 63 00 72 00 6f 00 73 00 6f 00 66 00 74 00 5c 00 42 00 6f 00 6f 00 74 00 5c 00 62 00 6f 00 6f 00 74 00 6d 00 67 00 66 00 77 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
    data: 57 49 4e 44 4f 57 53 00 01 00 00 00 88 00 00 00 78 00 00 00 42 00 43 00 44 00 4f 00 42 00 4a 00 45 00 43 00 54 00 3d 00 7b 00 39 00 64 00 65 00 61 00 38 00 36 00 32 00 63 00 2d 00 35 00 63 00 64 00 64 00 2d 00 34 00 65 00 37 00 30 00 2d 00 61 00 63 00 63 00 31 00 2d 00 66 00 33 00 32 00 62 00 33 00 34 00 34 00 64 00 34 00 37 00 39 00 35 00 7d 00 00 00 6f 00 01 00 00 00 10 00 00 00 04 00 00 00 7f ff 04 00
Boot0003  debian        HD(2,GPT,076a76a0-929a-42cd-bfae-050e49cd7b70,0x202fff,0x31800)/\EFI\debian\shimx64.efi
      dp: 04 01 2a 00 02 00 00 00 ff 2f 20 00 00 00 00 00 00 18 03 00 00 00 00 00 a0 76 6a 07 9a 92 cd 42 bf ae 05 0e 49 cd 7b 70 02 02 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 64 00 65 00 62 00 69 00 61 00 6e 00 5c 00 73 00 68 00 69 00 6d 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot2001* EFI USB Device        RC
      dp: 7f ff 04 00
    data: 52 43
Boot2002* EFI DVD/CDROM RC
      dp: 7f ff 04 00
    data: 52 43
Boot2003* EFI Network   RC
      dp: 7f ff 04 00
    data: 52 43
[nls@lap ~]$
[nls@lap ~]$ inxi  -F
  Host: lap Kernel: 6.6.34-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
  Type: Laptop System: Notebook product: NJ50_70CU v: N/A
    serial: <superuser required>
  Mobo: Notebook model: NJ50_70CU serial: <superuser required> UEFI: INSYDE
    v: 1.07.11 date: 10/24/2019
  Info: quad core model: Intel Core i7-10510U bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 809 min/max: 400/4900 cores: 1: 800 2: 800 3: 800 4: 758
    5: 800 6: 800 7: 800 8: 920
  Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
    resolution: 1920x1080
You should look her :
GRUB/Restore the GRUB Bootloader 2
and
https://wiki.archlinux.org/title/GRUB
Thanks for your reply and the tips links.
What I did ? I booted an own Manjaro iso image, did a new boot efi install, keep the other /wished partitions (available during the install process for each partition, nice feature :-), I deleted the boot efi partition, created a new one, and installed it.
Result ? A booting OS as wished, that’s all. The easiest way to repair a boot/efi with a GUI, without reinstalling the entire OS, but just the boot.
I firstly would remove plymouth, to see where it stuck.
I don’t understand why you reinstall Manjaro when you only want to restore your EFI.
You can also use Timeshift, when you have a snapshot… if you don’t want to use install-grub or grub-install.
