/boot/efi doesn't look like an efi partition
Hi, I am dual booting manjaro with windows 10 in UEFI mode, two days ago I reinstalled windows and I lost grub, now I am trying to recover it by creating a new efi partition with flags boot and esp, when I try to install grub after mounting the partition on /boot/efi:
it says
/boot/efi doesn’t look like efi partition
I tried
sudo mkdir EFI
in /boot/efi it says
file exists.
ls /boot/efi
replies nothing. what should I do please help. should I reinstall?
Have tried this tutorial first?
Are you trying these commands from LiveCD?
Give some info as listed in the linked tutorial.
Yes I am trying on livecd and based on this tutorial Using livecd v17.0.1 as grub to boot OS with broken bootloader.
Did you get to boot your installation then?
If yes then post these info:
efibootmgr -v
sudo parted -l
sudo blkid
findmnt -s
findmnt /boot/efi
