when installing i’ve chosen windows boot partition and set flags and boot/efi after installation it goes directly to manjaro and show no grub menu. can’t choose windows or kernel.if i want to boot to windows, i have to chose from from bios boot menu option.
my mb is asus and secure boot settings is Other OS. if i choose UEFI got a message for unauthorized access.
how can i fix this
some necessary information
sudo parted -l
Model: PNY CS3030 500GB SSD (nvme)
Disk /dev/nvme0n1: 500GB
Partition Table: gpt
Disk Flags:
efibootmgr
important note:
manjaro boot is boot0012 and windows is boot0014 both name windows boot manager. dont know why.
BootCurrent: 0012
Timeout: 1 seconds
BootOrder: 0012,0014,0013,0015,0016,0017
Boot0003 Hard Drive
Boot0011 CD/DVD Drive
Boot0012* Windows Boot Manager
Boot0013* UEFI OS
Boot0014* Windows Boot Manager
Boot0015* UEFI OS
Boot0016* Hard Drive
Boot0017* CD/DVD Drive
est -d /sys/firmware/efi && echo efi || echo bios
efi
sudo update-grub
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
It's output will be used to detect bootable binaries on them and create new boot entries.
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
GNU nano 5.6.1 /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=Menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=2c56b73d-e77d-4910-8d7d-caa54541b850 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
GRUB_DISABLE_OS_PROBER=false
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
done
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_GFXMODE=auto
Maybe the problem is in the last line, which does not appear to me. I don’t have UEFI systems, but it looks like it could be adding the entry to some UEFI boot menu.
I think this is your problem if you formatted this the windows boot info will have gone.
IMHO it is bad to use windows esp partition as one day on a windows update it could trash your manjaro boot loader!
