I was using a dual boot of Windows 10 and Pop OS and decided to install Manjaro over the Pop OS partition. During installation, however, I ran into an error which I need help with.
I can’t embed images or any links to the post for some reason so I have typed out the error by hand that I get in the error dialogue box:
Installation Failed
Boost.Python error in job “bootloader”.
Command ‘grub-install --target=x86_-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force’ returned non-zero exit status 1.
Installing for x86_64-efi platform. grub-install: error: cannot copy/boot/grub/x86_64-efi/core.efi'to
/boot/efi/EFI/Manjaro/grubx64.efi’: No space left on device.Traceback:
File “/usr/lib/calamares/modules/bootloader/main.py”, line 476, in run prepare_bootloader(fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”. line 448, in prepare_bootloader install_grub(efi_directory, fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”, line 310, in install_grub check_target_env_call([libcalamares.job.configuration[“grubInstall”],
File " < string >",line 5, in < module >
There are no spaces in the last line but I had to add them because the quotes were making the words inside the brackets disappear. I apologise for that.
I am a newbie so I don’t understand what’s wrong. Any help is appreciated.
