Anyone been able to successfully bond
the ethernet and wifi devices, which uses a wifi AP with a WPA2 passphrase?
So far i’ve been able to connect to my wifi using Networkmanager
+ iwd
and a systemd
network config.
But it doesn’t work when i bond the wifi device somehow…
If needed i can provide the bond configs and/or the network configs that i currently have disabled…
(I have already read the arch wiki pages related to these topics)
Hi @TriMoon,
Although I’ve never done it personally, this is a subject that interests me and I’ve found this that might help:
Thanks but thats almost the same info as i did by reading all the other stuff
The diff though is that i want to use iwd
instead of wpa_supplicant
(Don’t remember if it worked using wpa_supplicant
will keep trying…
Also just found this:
Edit:
And maybe, just maybe this helps:
https://wiki.archlinux.org/title/Wireless_bonding
Else:
At least for the moment.
Thanks reading and trying that page about nmcli
right now.
Although after i re-enabled NetworkManager
it overwrote my iwd
config file for the wifi-AP, but ahh well we will see.
First going to try to get NetworkManager
keep up my wifi connection without bonding, will try the bonded setup later.
Thanks so far
I had made a tar
file with my current config but am unable to upload it in this thread, see Allowed upload file extensions - #7 by TriMoon and What to use to backup files, preserving ACLs?
Maybe i will post it off-site someday if needed.
PS:
- This config is still not working when bonded, but allows me to choose bonding or not using a kernel cmdline at boot-up
- Plus i dropped
iwd
and use wpa_supplicant
again as it somehow is way faster and less error-prone to associate.
- Disabled
NetworkManager
because it conflicts with systemd-networkd
, which means i dont have the toolbar icon anylonger in KDE with it’s nice features, ahh well
I decided to post the archive here as base64 encoded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Hmm, for those interested in helping:
$ cd $(mktemp -d)
$ echo "$TriMoons_base64_string" | base64 -d - | tar -xf - --zstd
$ find . # or use tree command
For decompressing the archive i would suggest to use the command shown at the link i gave earlier
But yes thanks for the de-base64 command
How massively long are your config files that you need to compress and paste is here in b64?
Please just post the necessary snippets here in code tags.
