Hi . My english is not good , forgive me if there is any grammar mistakes.
Let me explain the issue , the blur effects in kde while on x11 is not working correctly .
Let me attach a picture , https://imgur.com/jiZyLIq
. The main menu has a blur effects by default . But for me the blur effects is not workng . All the blur effects in kde , ( not only in menu ) is very sharp ( like full of grains ) . I tried messing around with compositor settings but its not working. Iām having this issue on all kde distro.
If i use wayland session , the blur effects working as expected. But wayland not suiting for me . While sharing my screen the screen is sharing as fully inverted . I dont know what to do
While i was messing with compositor settings , i found that if i change the Rendering Backend
to x render
, the blur effects become fully transparent https://imgur.com/nPrXNAA
. I hope you can understand my issue.
This is my inxi
output :-
Kernel: 5.4.144-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: ro root=UUID=df68ec32-c7e5-45cf-8a30-dd853cb988d4
initrd=boot\initramfs-5.4-x86_64.img
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 80CB v: 99.53 serial: <filter> UEFI: Insyde v: F.28
date: 05/17/2019
ID-1: BAT1 charge: 34.4 Wh (100.0%) condition: 34.4/34.4 Wh (100.0%)
volts: 16.6 min: 14.6 model: 131-42-6E HS04041 type: Unknown
serial: <filter> status: Full
RAM: total: 6.74 GiB used: 2.77 GiB (41.2%)
Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030106 cache: L2: 2 MiB bogomips: 17572
Speed: 1781 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
1: 1781 2: 1739 3: 1802 4: 1631
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave
xsaveopt
disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
chip-ID: 1002:9851 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: USB
driver: uvcvideo bus-ID: 3-1.1:3 chip-ID: 05c8:0382 class-ID: 0e02
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.144-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.2.1 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.4.144-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma port: 3100 bus-ID: 02:00.0 chip-ID: 14e4:4365
class-ID: 0280
IF: wlo1 state: dormant mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF-ID-1: enp0s18u1u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: OPPO RMX2193 type: USB driver: rndis_host v: kernel
bus-ID: 1-1.1:5 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Device-2: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Local Storage: total: 931.51 GiB used: 11.96 GiB (1.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUB0N rev: UB00 dev-links: cdrom
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 8.53 GiB (17.4%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: df68ec32-c7e5-45cf-8a30-dd853cb988d4
ID-2: /boot/efi raw-size: 1 GiB size: 1022.6 MiB (99.80%)
used: 123.4 MiB (12.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
label: LINUX_BOOT uuid: 26EB-9915
ID-3: /home raw-size: 75 GiB size: 73.27 GiB (97.69%) used: 3.31 GiB (4.5%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: aadeeae0-0e10-441b-90d3-637edf0ef7c2
ID-1: /dev/sda2 maj-min: 8:2 size: 46 GiB fs: ext4 label: N/A
uuid: 3314ab5a-8de4-454f-a232-eab804bac642
ID-2: /dev/sda5 maj-min: 8:5 size: 381 GiB fs: ntfs label: Gaming
uuid: 6C38EEE738EEAEF0
ID-3: /dev/sda6 maj-min: 8:6 size: 273.9 GiB fs: ntfs label: Others
uuid: B0CAF063CAF0276E
ID-4: /dev/sda7 maj-min: 8:7 size: 4 GiB fs: swap label: N/A
uuid: 4e946f44-e3cf-4d65-a1a4-2ec872e6c4a4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.1:5 info: OPPO RMX2193 type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-1.4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 2-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 2-2:3 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 3-1.1:3
info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 71.6 C mobo: 20.0 C gpu: radeon temp: 71.0 C
Processes: 211 Uptime: 26m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1114 lib: 301 Shell: Zsh v: 5.8
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Waiting for a solution . I know you guys can help me .
