I have manjaro kde 21.04 installed on raspberry pi. kde connect dont show any device on system or other system.I have wireless earphone which connect normally but when I try to connect android device, mobile couldn’t find my device and when try to connect from pi mobile device, it recognizes pi only as wireless earphones.
So you want to access your phone from the Raspberry Pi using KDE Connect?
yes I was but couldn’t so I used usb cable. But now I even cant connect with bluetooth. Not sure if this is after resent update or there is any issue with settings.
