When running the sudo dmesg -Hwx command when disconnecting, I get this massive bit of data:
~ sudo dmesg -Hwx
[sudo] password for bryankarlan:
kern :notice: [Feb 8 15:33] Linux version 5.10.7-3-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Fri Jan 15 21:11:34 UTC 2021
kern :info : [ +0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=544910ae-25e2-4f87-a7c8-6e868034c49c ro quiet splash apparmor=1 security=apparmor udev.log_priority=3
kern :info : [ +0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
kern :info : [ +0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
kern :info : [ +0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
kern :info : [ +0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
kern :info : [ +0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘standard’ format.
kern :info : [ +0.000000] BIOS-provided physical RAM map:
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000008dfff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000000008e000-0x000000000008ffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000000090000-0x000000000009ffff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000bffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000040005000-0x000000008ad13fff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ad14000-0x000000008ad52fff] ACPI NVS
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ad53000-0x000000008ad68fff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ad69000-0x000000008ad8efff] ACPI data
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ad8f000-0x000000008ae27fff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ae28000-0x000000008ae8efff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008ae8f000-0x000000008aecdfff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008aece000-0x000000008aefefff] type 20
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008aeff000-0x000000008af8efff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008af8f000-0x000000008affefff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008afff000-0x000000008affffff] usable
kern :info : [ +0.000000] BIOS-e820: [mem 0x000000008b000000-0x000000008f9fffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x00000000e00f8000-0x00000000e00f8fff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x00000000ffe70000-0x00000000ffe9ffff] reserved
kern :info : [ +0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046f5fffff] usable
kern :info : [ +0.000000] NX (Execute Disable) protection: active
kern :info : [ +0.000000] efi: EFI v1.10 by Apple
kern :info : [ +0.000000] efi: ACPI=0x8ad8e000 ACPI 2.0=0x8ad8e014 SMBIOS=0x8ad1b000
kern :info : [ +0.000000] SMBIOS 2.4 present.
kern :info : [ +0.000000] DMI: Apple Inc. MacBookPro10,1/Mac-C3EC7CD22292981F, BIOS 262.0.0.0.0 06/10/2020
kern :info : [ +0.000000] tsc: Fast TSC calibration using PIT
kern :info : [ +0.000000] tsc: Detected 2693.962 MHz processor
kern :debug : [ +0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
kern :debug : [ +0.000003] e820: remove [mem 0x000a0000-0x000fffff] usable
kern :info : [ +0.000008] last_pfn = 0x46f600 max_arch_pfn = 0x400000000
kern :debug : [ +0.000004] MTRR default type: write-back
kern :debug : [ +0.000001] MTRR fixed ranges enabled:
kern :debug : [ +0.000001] 00000-9FFFF write-back
kern :debug : [ +0.000001] A0000-BFFFF uncachable
kern :debug : [ +0.000001] C0000-DFFFF write-protect
kern :debug : [ +0.000001] E0000-FFFFF uncachable
kern :debug : [ +0.000001] MTRR variable ranges enabled:
kern :debug : [ +0.000001] 0 base 0C0000000 mask FC0000000 uncachable
kern :debug : [ +0.000001] 1 base 0A0000000 mask FE0000000 uncachable
kern :debug : [ +0.000001] 2 base 090000000 mask FF0000000 uncachable
kern :debug : [ +0.000001] 3 base 08C000000 mask FFC000000 uncachable
kern :debug : [ +0.000001] 4 base 08B000000 mask FFF000000 uncachable
kern :debug : [ +0.000001] 5 disabled
kern :debug : [ +0.000000] 6 disabled
kern :debug : [ +0.000001] 7 disabled
kern :debug : [ +0.000001] 8 disabled
kern :debug : [ +0.000000] 9 disabled
kern :info : [ +0.000316] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
kern :info : [ +0.000253] last_pfn = 0x8b000 max_arch_pfn = 0x400000000
kern :info : [ +0.020035] check: Scanning 1 areas for low memory corruption
kern :info : [ +0.001402] Secure boot disabled
kern :info : [ +0.000001] RAMDISK: [mem 0x3685f000-0x37426fff]
kern :info : [ +0.000009] ACPI: Early table checksum verification disabled
kern :info : [ +0.000003] ACPI: RSDP 0x000000008AD8E014 000024 (v02 APPLE )
kern :info : [ +0.000004] ACPI: XSDT 0x000000008AD8E1C0 0000B4 (v01 APPLE Apple00 00000000 01000013)
kern :info : [ +0.000006] ACPI: FACP 0x000000008AD8C000 0000F4 (v04 APPLE Apple00 00000000 Loki 0000005F)
kern :info : [ +0.000006] ACPI: DSDT 0x000000008AD82000 004D5C (v01 APPLE MacBookP 00100001 INTL 20100915)
kern :info : [ +0.000004] ACPI: FACS 0x000000008AD1E000 000040
kern :info : [ +0.000003] ACPI: FACS 0x000000008AD1E000 000040
kern :info : [ +0.000003] ACPI: HPET 0x000000008AD8B000 000038 (v01 APPLE Apple00 00000001 Loki 0000005F)
kern :info : [ +0.000003] ACPI: APIC 0x000000008AD8A000 0000BC (v02 APPLE Apple00 00000001 Loki 0000005F)
kern :info : [ +0.000004] ACPI: SBST 0x000000008AD88000 000030 (v01 APPLE Apple00 00000001 Loki 0000005F)
kern :info : [ +0.000003] ACPI: ECDT 0x000000008AD87000 000053 (v01 APPLE Apple00 00000001 Loki 0000005F)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD7F000 00053A (v01 APPLE SataAhci 00001000 INTL 20100915)
kern :info : [ +0.000004] ACPI: SSDT 0x000000008AD7E000 000024 (v01 APPLE SmcDppt 00001000 INTL 20100915)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD79000 000D3E (v01 APPLE UsbPpt 00001000 INTL 20100915)
kern :info : [ +0.000004] ACPI: SSDT 0x000000008AD77000 000159 (v02 APPLE IGHda 00001000 INTL 20100915)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD75000 000032 (v01 APPLE SsdtS3 00001000 INTL 20100915)
kern :info : [ +0.000004] ACPI: SSDT 0x000000008AD73000 0015EB (v02 APPLE SsdtIGPU 00001000 INTL 20100915)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD6E000 0019AA (v01 APPLE TbtPEG11 00001000 INTL 20100915)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD6D000 00071D (v01 PmRef Cpu0Ist 00003000 INTL 20100915)
kern :info : [ +0.000004] ACPI: SSDT 0x000000008AD6C000 000B3D (v01 PmRef CpuPm 00003000 INTL 20100915)
kern :info : [ +0.000003] ACPI: SSDT 0x000000008AD6B000 000315 (v01 PmRef Cpu0Tst 00003000 INTL 20100915)
kern :info : [ +0.000004] ACPI: SSDT 0x000000008AD6A000 00037A (v01 PmRef ApTst 00003000 INTL 20100915)
kern :info : [ +0.000003] ACPI: DMAR 0x000000008AD69000 000088 (v01 APPLE IVB 00000001 AAPL 00000001)
kern :info : [ +0.000004] ACPI: MCFG 0x000000008AD89000 00003C (v01 APPLE Apple00 00000001 Loki 0000005F)
kern :notice: [ +0.000007] ACPI: DMI detected to setup _OSI(“Darwin”): Apple hardware
kern :debug : [ +0.000002] ACPI: Local APIC address 0xfee00000
kern :info : [ +0.000046] No NUMA configuration found
kern :info : [ +0.000001] Faking a node at [mem 0x0000000000000000-0x000000046f5fffff]
kern :info : [ +0.000004] NODE_DATA(0) allocated [mem 0x46f5ef000-0x46f5f2fff]
kern :info : [ +0.027052] Zone ranges:
kern :info : [ +0.000003] DMA [mem 0x0000000000001000-0x0000000000ffffff]
kern :info : [ +0.000002] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
kern :info : [ +0.000001] Normal [mem 0x0000000100000000-0x000000046f5fffff]
kern :info : [ +0.000002] Device empty
kern :info : [ +0.000001] Movable zone start for each node
kern :info : [ +0.000001] Early memory node ranges
kern :info : [ +0.000001] node 0: [mem 0x0000000000001000-0x000000000008dfff]
kern :info : [ +0.000001] node 0: [mem 0x0000000000090000-0x000000000009ffff]
kern :info : [ +0.000001] node 0: [mem 0x0000000000100000-0x000000001fffffff]
kern :info : [ +0.000001] node 0: [mem 0x0000000020200000-0x0000000040003fff]
kern :info : [ +0.000000] node 0: [mem 0x0000000040005000-0x000000008ad13fff]
kern :info : [ +0.000001] node 0: [mem 0x000000008ad53000-0x000000008ad68fff]
kern :info : [ +0.000001] node 0: [mem 0x000000008ad8f000-0x000000008ae27fff]
kern :info : [ +0.000001] node 0: [mem 0x000000008ae8f000-0x000000008aecdfff]
kern :info : [ +0.000001] node 0: [mem 0x000000008aeff000-0x000000008af8efff]
kern :info : [ +0.000000] node 0: [mem 0x000000008afff000-0x000000008affffff]
kern :info : [ +0.000001] node 0: [mem 0x0000000100000000-0x000000046f5fffff]
kern :info : [ +0.000232] Zeroed struct page in unavailable ranges: 24017 pages
kern :info : [ +0.000002] Initmem setup node 0 [mem 0x0000000000001000-0x000000046f5fffff]
kern :debug : [ +0.000001] On node 0 totalpages: 4170287
kern :debug : [ +0.000002] DMA zone: 64 pages used for memmap
kern :debug : [ +0.000000] DMA zone: 26 pages reserved
kern :debug : [ +0.000001] DMA zone: 3997 pages, LIFO batch:0
kern :debug : [ +0.000027] DMA32 zone: 8819 pages used for memmap
kern :debug : [ +0.000001] DMA32 zone: 564370 pages, LIFO batch:63
kern :debug : [ +0.003627] Normal zone: 56280 pages used for memmap
kern :debug : [ +0.000003] Normal zone: 3601920 pages, LIFO batch:63
kern :info : [ +0.024868] Reserving Intel graphics memory at [mem 0x8ba00000-0x8f9fffff]
kern :info : [ +0.010205] Resetting Apple AirPort card (left enabled by EFI)
kern :info : [ +0.000068] ACPI: PM-Timer IO Port: 0x408
kern :info : [ +0.000007] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
kern :info : [ +0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
kern :info : [ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
kern :info : [ +0.000014] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
kern :info : [ +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
kern :info : [ +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
kern :debug : [ +0.000001] ACPI: IRQ0 used by override.
kern :debug : [ +0.000002] ACPI: IRQ9 used by override.
kern :info : [ +0.000002] Using ACPI (MADT) for SMP configuration information
kern :info : [ +0.000001] ACPI: HPET id: 0x8086a201 base: 0xfed00000
kern :info : [ +0.000005] TSC deadline timer available
kern :info : [ +0.000001] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
kern :info : [ +0.000026] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x0008e000-0x0008ffff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000bffff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x000c0000-0x000fffff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x20000000-0x201fffff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x40004000-0x40004fff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x8ad14000-0x8ad52fff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x8ad69000-0x8ad8efff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x8ae28000-0x8ae8efff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x8aece000-0x8aefefff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x8af8f000-0x8affefff]
kern :info : [ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x8b000000-0x8f9fffff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x8fa00000-0xe00f7fff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xe00f8000-0xe00f8fff]
kern :info : [ +0.000000] PM: hibernation: Registered nosave memory: [mem 0xe00f9000-0xfed1bfff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xffe6ffff]
kern :info : [ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xffe70000-0xffe9ffff]
kern :info : [ +0.000000] PM: hibernation: Registered nosave memory: [mem 0xffea0000-0xffffffff]
kern :info : [ +0.000002] [mem 0x8fa00000-0xe00f7fff] available for PCI devices
kern :info : [ +0.000003] Booting paravirtualized kernel on bare hardware
kern :info : [ +0.000003] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
kern :info : [ +0.005050] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
kern :info : [ +0.000207] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
kern :debug : [ +0.000008] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
kern :debug : [ +0.000001] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
kern :info : [ +0.000027] Built 1 zonelists, mobility grouping on. Total pages: 4105098
kern :info : [ +0.000001] Policy zone: Normal
kern :notice: [ +0.000002] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=544910ae-25e2-4f87-a7c8-6e868034c49c ro quiet splash apparmor=1 security=apparmor udev.log_priority=3
kern :info : [ +0.000924] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
kern :info : [ +0.000402] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
kern :info : [ +0.000087] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
kern :info : [ +0.042562] Memory: 16047564K/16681148K available (14344K kernel code, 2065K rwdata, 4832K rodata, 1720K init, 4232K bss, 633324K reserved, 0K cma-reserved)
kern :notice: [ +0.000009] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
kern :info : [ +0.000119] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
kern :info : [ +0.000011] Kernel/User page tables isolation: enabled
kern :info : [ +0.000017] ftrace: allocating 42042 entries in 165 pages
kern :info : [ +0.014711] ftrace: allocated 165 pages with 4 groups
kern :info : [ +0.000101] rcu: Preemptible hierarchical RCU implementation.
kern :info : [ +0.000001] rcu: RCU dyntick-idle grace-period acceleration is enabled.
kern :info : [ +0.000002] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
kern :info : [ +0.000000] rcu: RCU priority boosting: priority 1 delay 500 ms.
kern :info : [ +0.000001] Trampoline variant of Tasks RCU enabled.
kern :info : [ +0.000001] Rude variant of Tasks RCU enabled.
kern :info : [ +0.000001] Tracing variant of Tasks RCU enabled.
kern :info : [ +0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
kern :info : [ +0.000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
kern :info : [ +0.003971] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
kern :info : [ +0.000254] Console: colour dummy device 80x25
kern :info : [ +0.000014] printk: console [tty0] enabled
kern :info : [ +0.000019] ACPI: Core revision 20200925
kern :info : [ +0.000114] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
kern :info : [ +0.000015] APIC: Switch to symmetric I/O mode setup
kern :info : [ +0.000002] DMAR: Host address width 36
kern :info : [ +0.000001] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
kern :info : [ +0.000005] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
kern :info : [ +0.000001] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
kern :info : [ +0.000003] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
kern :info : [ +0.000001] DMAR: RMRR base: 0x0000008b800000 end: 0x0000008f9fffff
kern :info : [ +0.000002] DMAR-IR: IOAPIC id 0 under DRHD base 0xfed91000 IOMMU 1
kern :info : [ +0.000001] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
kern :err : [ +0.000001] DMAR-IR: [Firmware Bug]: ioapic 2 has no mapping iommu, interrupt remapping will be disabled
kern :info : [ +0.000000] DMAR-IR: Not enabling interrupt remapping
kern :warn : [ +0.000002] DMAR-IR: Failed to enable irq remapping. You are vulnerable to irq-injection attacks.
kern :info : [ +0.000072] x2apic: IRQ remapping doesn’t support X2APIC mode
kern :info : [ +0.000450] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
kern :info : [ +0.016126] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26d4f65a81a, max_idle_ns: 440795232217 ns
kern :info : [ +0.000004] Calibrating delay loop (skipped), value calculated using timer frequency… 5390.42 BogoMIPS (lpj=8979873)
kern :info : [ +0.000002] pid_max: default: 32768 minimum: 301
kern :info : [ +0.014373] LSM: Security Framework initializing
kern :info : [ +0.000007] Yama: becoming mindful.
kern :info : [ +0.000022] AppArmor: AppArmor initialized
kern :info : [ +0.000039] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
kern :info : [ +0.000027] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
kern :info : [ +0.000264] mce: CPU0: Thermal monitoring enabled (TM1)
kern :info : [ +0.000011] process: using mwait in idle threads
kern :info : [ +0.000003] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
kern :info : [ +0.000001] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
kern :info : [ +0.000003] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
kern :info : [ +0.000001] Spectre V2 : Mitigation: Full generic retpoline
kern :info : [ +0.000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
kern :info : [ +0.000001] Spectre V2 : Enabling Restricted Speculation for firmware calls
kern :info : [ +0.000001] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
kern :info : [ +0.000001] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
kern :info : [ +0.000001] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
kern :info : [ +0.000002] SRBDS: Vulnerable: No microcode
kern :info : [ +0.000001] MDS: Mitigation: Clear CPU buffers
kern :info : [ +0.000195] Freeing SMP alternatives memory: 36K
kern :info : [ +0.001093] smpboot: CPU0: Intel(R) Core™ i7-3740QM CPU @ 2.70GHz (family: 0x6, model: 0x3a, stepping: 0x9)
kern :info : [ +0.000100] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
kern :info : [ +0.000008] … version: 3
kern :info : [ +0.000001] … bit width: 48
kern :info : [ +0.000000] … generic registers: 4
kern :info : [ +0.000001] … value mask: 0000ffffffffffff
kern :info : [ +0.000001] … max period: 00007fffffffffff
kern :info : [ +0.000000] … fixed-purpose events: 3
kern :info : [ +0.000001] … event mask: 000000070000000f
kern :info : [ +0.000135] rcu: Hierarchical SRCU implementation.
kern :info : [ +0.000368] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
kern :info : [ +0.000000] smp: Bringing up secondary CPUs …
kern :info : [ +0.000000] x86: Booting SMP configuration:
kern :info : [ +0.000000] … node #0, CPUs: #1 #2 #3 #4
kern :warn : [ +0.009670] MDS CPU bug present and SMT on, data leak possible. See MDS - Microarchitectural Data Sampling — The Linux Kernel documentation for more details.
kern :warn : [ +0.000000] #5 #6 #7
kern :info : [ +0.009597] smp: Brought up 1 node, 8 CPUs
kern :info : [ +0.000000] smpboot: Max logical packages: 1
kern :info : [ +0.000000] smpboot: Total of 8 processors activated (43120.36 BogoMIPS)
kern :info : [ +0.001264] devtmpfs: initialized
kern :info : [ +0.000000] x86/mm: Memory block size: 128MB
kern :info : [ +0.000475] PM: Registering ACPI NVS region [mem 0x8ad14000-0x8ad52fff] (258048 bytes)
kern :info : [ +0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
kern :info : [ +0.000000] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
kern :info : [ +0.000000] pinctrl core: initialized pinctrl subsystem
kern :info : [ +0.000000] PM: RTC time: 21:33:52, date: 2021-02-08
kern :info : [ +0.000000] NET: Registered protocol family 16
kern :info : [ +0.000000] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
kern :info : [ +0.000000] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
kern :info : [ +0.000000] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
kern :info : [ +0.000000] audit: initializing netlink subsys (disabled)
kern :notice: [ +0.000000] audit: type=2000 audit(1612820032.053:1): state=initialized audit_enabled=0 res=1
kern :info : [ +0.000000] thermal_sys: Registered thermal governor ‘fair_share’
kern :info : [ +0.000000] thermal_sys: Registered thermal governor ‘bang_bang’
kern :info : [ +0.000000] thermal_sys: Registered thermal governor ‘step_wise’
kern :info : [ +0.000000] thermal_sys: Registered thermal governor ‘user_space’
kern :info : [ +0.000000] thermal_sys: Registered thermal governor ‘power_allocator’
kern :info : [ +0.000000] cpuidle: using governor ladder
kern :info : [ +0.000000] cpuidle: using governor menu
kern :info : [ +0.000000] ACPI: bus type PCI registered
kern :info : [ +0.000000] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
kern :info : [ +0.000000] PCI: MMCONFIG for domain 0000 [bus 00-9b] at [mem 0xe0000000-0xe9bfffff] (base 0xe0000000)
kern :info : [ +0.000000] PCI: not using MMCONFIG
kern :info : [ +0.000000] PCI: Using configuration type 1 for base access
kern :info : [ +0.000000] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
kern :info : [ +0.003222] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
kern :info : [ +0.000000] ACPI: Disabled all _OSI OS vendors
kern :info : [ +0.000000] ACPI: Added _OSI(Module Device)
kern :info : [ +0.000000] ACPI: Added _OSI(Processor Device)
kern :info : [ +0.000000] ACPI: Added _OSI(3.0 _SCP Extensions)
kern :info : [ +0.000000] ACPI: Added _OSI(Processor Aggregator Device)
kern :info : [ +0.000000] ACPI: Added _OSI(Linux-Dell-Video)
kern :info : [ +0.000000] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
kern :info : [ +0.000000] ACPI: Added OSI(Linux-HPI-Hybrid-Graphics)
kern :info : [ +0.000000] ACPI: Added OSI(Darwin)
kern :info : [ +0.005250] ACPI: 12 ACPI AML tables successfully acquired and loaded
kern :info : [ +0.003979] ACPI: EC: EC started
kern :info : [ +0.000001] ACPI: EC: interrupt blocked
kern :info : [ +0.001346] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
kern :info : [ +0.000001] ACPI: EC: Boot ECDT EC used to handle transactions
kern :notice: [ +0.000195] ACPI: BIOS OSI(Darwin) query honored via DMI
kern :notice: [ +0.000381] ACPI: [Firmware Bug]: BIOS OSI(Linux) query ignored
kern :err : [ +0.000185] ACPI Error: Needed type [Reference], found [Integer] 000000009bb405aa (20200925/exresop-66)
kern :err : [ +0.000005] ACPI Error: AE_AML_OPERAND_TYPE, While resolving operands for [Store] (20200925/dswexec-431)
kern :err : [ +0.000004] ACPI Error: Aborting method _PR.CPU0.PDC due to previous error (AE_AML_OPERAND_TYPE) (20200925/psparse-529)
kern :info : [ +0.000342] ACPI: Dynamic OEM Table Load:
kern :info : [ +0.000008] ACPI: SSDT 0xFFFF9325C09A6800 0003A4 (v01 PmRef ApIst 00003000 INTL 20100915)
kern :info : [ +0.000689] ACPI: Dynamic OEM Table Load:
kern :info : [ +0.000005] ACPI: SSDT 0xFFFF9325C100CA00 000119 (v01 PmRef ApCst 00003000 INTL 20100915)
kern :info : [ +0.002265] ACPI: Interpreter enabled
kern :info : [ +0.000019] ACPI: (supports S0 S3 S4 S5)
kern :info : [ +0.000001] ACPI: Using IOAPIC for interrupt routing
kern :info : [ +0.000029] PCI: MMCONFIG for domain 0000 [bus 00-9b] at [mem 0xe0000000-0xe9bfffff] (base 0xe0000000)
kern :info : [ +0.000541] PCI: MMCONFIG at [mem 0xe0000000-0xe9bfffff] reserved in ACPI motherboard resources
kern :info : [ +0.000011] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
kern :info : [ +0.000224] ACPI: Enabled 6 GPEs in block 00 to 3F
kern :info : [ +0.008556] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
kern :info : [ +0.000005] acpi PNP0A08:00: OSC: OS assumes control of [PCIeHotplug SHPCHotplug AER PCIeCapability LTR DPC]
kern :info : [ +0.000013] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-9b] only partially covers this bridge
kern :info : [ +0.000333] PCI host bridge to bus 0000:00
kern :info : [ +0.000002] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
kern :info : [ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
kern :info : [ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0x8fa00000-0xfeafffff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [mem 0xfed40000-0xfed44fff window]
kern :info : [ +0.000001] pci_bus 0000:00: root bus resource [bus 00-ff]
kern :info : [ +0.000015] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
kern :info : [ +0.000099] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
kern :info : [ +0.000039] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000087] pci 0000:00:01.1: [8086:0155] type 01 class 0x060400
kern :info : [ +0.000034] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000095] pci 0000:00:01.2: [8086:0159] type 01 class 0x060400
kern :info : [ +0.000088] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000110] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
kern :info : [ +0.000008] pci 0000:00:02.0: reg 0x10: [mem 0xc1400000-0xc17fffff 64bit]
kern :info : [ +0.000005] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
kern :info : [ +0.000004] pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
kern :info : [ +0.000140] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
kern :info : [ +0.000017] pci 0000:00:14.0: reg 0x10: [mem 0xc1c00000-0xc1c0ffff 64bit]
kern :info : [ +0.000063] pci 0000:00:14.0: PME# supported from D3hot D3cold
kern :info : [ +0.000204] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
kern :info : [ +0.000021] pci 0000:00:16.0: reg 0x10: [mem 0xc1c17100-0xc1c1710f 64bit]
kern :info : [ +0.000076] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000087] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
kern :info : [ +0.000016] pci 0000:00:1a.0: reg 0x10: [mem 0xc1c16c00-0xc1c16fff]
kern :info : [ +0.000084] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000233] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
kern :info : [ +0.000015] pci 0000:00:1b.0: reg 0x10: [mem 0xc1c10000-0xc1c13fff 64bit]
kern :info : [ +0.000074] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000133] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
kern :info : [ +0.000154] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000132] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400
kern :info : [ +0.000152] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000134] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
kern :info : [ +0.000017] pci 0000:00:1d.0: reg 0x10: [mem 0xc1c16800-0xc1c16bff]
kern :info : [ +0.000084] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000193] pci 0000:00:1f.0: [8086:1e57] type 00 class 0x060100
kern :info : [ +0.000190] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
kern :info : [ +0.000012] pci 0000:00:1f.2: reg 0x10: [io 0x3098-0x309f]
kern :info : [ +0.000008] pci 0000:00:1f.2: reg 0x14: [io 0x30bc-0x30bf]
kern :info : [ +0.000008] pci 0000:00:1f.2: reg 0x18: [io 0x3090-0x3097]
kern :info : [ +0.000007] pci 0000:00:1f.2: reg 0x1c: [io 0x30b8-0x30bb]
kern :info : [ +0.000007] pci 0000:00:1f.2: reg 0x20: [io 0x3060-0x307f]
kern :info : [ +0.000008] pci 0000:00:1f.2: reg 0x24: [mem 0xc1c16000-0xc1c167ff]
kern :info : [ +0.000041] pci 0000:00:1f.2: PME# supported from D3hot
kern :info : [ +0.000085] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
kern :info : [ +0.000016] pci 0000:00:1f.3: reg 0x10: [mem 0xc1c17000-0xc1c170ff 64bit]
kern :info : [ +0.000015] pci 0000:00:1f.3: reg 0x20: [io 0xefa0-0xefbf]
kern :info : [ +0.000148] pci 0000:01:00.0: [10de:0fd5] type 00 class 0x030000
kern :info : [ +0.000011] pci 0000:01:00.0: reg 0x10: [mem 0xc0000000-0xc0ffffff]
kern :info : [ +0.000010] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
kern :info : [ +0.000009] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
kern :info : [ +0.000007] pci 0000:01:00.0: reg 0x24: [io 0x2000-0x207f]
kern :info : [ +0.000007] pci 0000:01:00.0: reg 0x30: [mem 0xc1000000-0xc107ffff pref]
kern :info : [ +0.000017] pci 0000:01:00.0: BAR 1: assigned to efifb
kern :info : [ +0.000066] pci 0000:01:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
kern :info : [ +0.000095] pci 0000:01:00.1: [10de:0e1b] type 00 class 0x040300
kern :info : [ +0.000010] pci 0000:01:00.1: reg 0x10: [mem 0xc1080000-0xc1083fff]
kern :info : [ +0.000170] pci 0000:00:01.0: PCI bridge to [bus 01]
kern :info : [ +0.000003] pci 0000:00:01.0: bridge window [io 0x2000-0x2fff]
kern :info : [ +0.000002] pci 0000:00:01.0: bridge window [mem 0xc0000000-0xc10fffff]
kern :info : [ +0.000002] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
kern :info : [ +0.000053] pci 0000:05:00.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000031] pci 0000:05:00.0: enabling Extended Tags
kern :info : [ +0.000049] pci 0000:05:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000152] pci 0000:00:01.1: PCI bridge to [bus 05-6b]
kern :info : [ +0.000002] pci 0000:00:01.1: bridge window [io 0x4000-0x6fff]
kern :info : [ +0.000002] pci 0000:00:01.1: bridge window [mem 0xc1d00000-0xce9fffff]
kern :info : [ +0.000002] pci 0000:00:01.1: bridge window [mem 0xcea00000-0xdabfffff 64bit pref]
kern :info : [ +0.000133] pci 0000:06:00.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000034] pci 0000:06:00.0: enabling Extended Tags
kern :info : [ +0.000054] pci 0000:06:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:06:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000099] pci 0000:06:03.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000034] pci 0000:06:03.0: enabling Extended Tags
kern :info : [ +0.000053] pci 0000:06:03.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:06:03.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000097] pci 0000:06:04.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000034] pci 0000:06:04.0: enabling Extended Tags
kern :info : [ +0.000053] pci 0000:06:04.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:06:04.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000096] pci 0000:06:05.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000030] pci 0000:06:05.0: enabling Extended Tags
kern :info : [ +0.000053] pci 0000:06:05.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:06:05.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000102] pci 0000:06:06.0: [8086:1547] type 01 class 0x060400
kern :info : [ +0.000030] pci 0000:06:06.0: enabling Extended Tags
kern :info : [ +0.000053] pci 0000:06:06.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:06:06.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000103] pci 0000:05:00.0: PCI bridge to [bus 06-6b]
kern :info : [ +0.000004] pci 0000:05:00.0: bridge window [io 0x4000-0x5fff]
kern :info : [ +0.000002] pci 0000:05:00.0: bridge window [mem 0xc1d00000-0xca9fffff]
kern :info : [ +0.000004] pci 0000:05:00.0: bridge window [mem 0xcea00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000045] acpiphp: Slot [1] registered
kern :info : [ +0.000024] pci 0000:07:00.0: [8086:1547] type 00 class 0x088000
kern :info : [ +0.000016] pci 0000:07:00.0: reg 0x10: [mem 0xc1f00000-0xc1f3ffff]
kern :info : [ +0.000009] pci 0000:07:00.0: reg 0x14: [mem 0xc1f40000-0xc1f40fff]
kern :info : [ +0.000044] pci 0000:07:00.0: enabling Extended Tags
kern :info : [ +0.000082] pci 0000:07:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000243] pci 0000:06:00.0: PCI bridge to [bus 07]
kern :info : [ +0.000006] pci 0000:06:00.0: bridge window [mem 0xc1f00000-0xc1ffffff]
kern :info : [ +0.000174] pci 0000:08:00.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000082] pci 0000:08:00.0: enabling Extended Tags
kern :info : [ +0.000130] pci 0000:08:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000188] pci 0000:06:03.0: PCI bridge to [bus 08-38]
kern :info : [ +0.000004] pci 0000:06:03.0: bridge window [io 0x4000-0x4fff]
kern :info : [ +0.000003] pci 0000:06:03.0: bridge window [mem 0xc2000000-0xc64fffff]
kern :info : [ +0.000004] pci 0000:06:03.0: bridge window [mem 0xcea00000-0xd2afffff 64bit pref]
kern :info : [ +0.000091] pci 0000:09:00.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000087] pci 0000:09:00.0: enabling Extended Tags
kern :info : [ +0.000135] pci 0000:09:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:09:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000173] pci 0000:09:01.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000087] pci 0000:09:01.0: enabling Extended Tags
kern :info : [ +0.000134] pci 0000:09:01.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:09:01.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000173] pci 0000:09:02.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000087] pci 0000:09:02.0: enabling Extended Tags
kern :info : [ +0.000134] pci 0000:09:02.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:09:02.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000177] pci 0000:09:04.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000075] pci 0000:09:04.0: enabling Extended Tags
kern :info : [ +0.000137] pci 0000:09:04.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:09:04.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000175] pci 0000:09:05.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000075] pci 0000:09:05.0: enabling Extended Tags
kern :info : [ +0.000137] pci 0000:09:05.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:09:05.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000193] pci 0000:08:00.0: PCI bridge to [bus 09-10]
kern :info : [ +0.000013] pci 0000:08:00.0: bridge window [mem 0xc2000000-0xc24fffff]
kern :info : [ +0.000009] pci 0000:08:00.0: bridge window [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000103] pci 0000:0a:00.0: [12d8:400c] type 01 class 0x060400
kern :info : [ +0.000308] pci 0000:0a:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:0a:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000196] pci 0000:09:00.0: PCI bridge to [bus 0a-0c]
kern :info : [ +0.000013] pci 0000:09:00.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000150] pci 0000:0b:03.0: [12d8:400c] type 01 class 0x060400
kern :info : [ +0.000269] pci 0000:0b:03.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:0b:03.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000184] pci 0000:0a:00.0: PCI bridge to [bus 0b-0c]
kern :info : [ +0.000018] pci 0000:0a:00.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000139] pci 0000:0c:00.0: [12d8:400e] type 00 class 0x0c0310
kern :info : [ +0.000039] pci 0000:0c:00.0: reg 0x10: [mem 0xc2401000-0xc2401fff]
kern :info : [ +0.000253] pci 0000:0c:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:0c:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000149] pci 0000:0c:00.1: [12d8:400e] type 00 class 0x0c0310
kern :info : [ +0.000039] pci 0000:0c:00.1: reg 0x10: [mem 0xc2400000-0xc2400fff]
kern :info : [ +0.000252] pci 0000:0c:00.1: supports D1 D2
kern :info : [ +0.000001] pci 0000:0c:00.1: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000126] pci 0000:0c:00.2: [12d8:400f] type 00 class 0x0c0320
kern :info : [ +0.000040] pci 0000:0c:00.2: reg 0x10: [mem 0xc2402000-0xc24020ff]
kern :info : [ +0.000251] pci 0000:0c:00.2: supports D1 D2
kern :info : [ +0.000001] pci 0000:0c:00.2: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000188] pci 0000:0b:03.0: PCI bridge to [bus 0c]
kern :info : [ +0.000019] pci 0000:0b:03.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000153] pci 0000:0d:00.0: [14e4:16b0] type 00 class 0x020000
kern :info : [ +0.000054] pci 0000:0d:00.0: reg 0x10: [mem 0xcea00000-0xcea0ffff 64bit pref]
kern :info : [ +0.000035] pci 0000:0d:00.0: reg 0x18: [mem 0xcea10000-0xcea1ffff 64bit pref]
kern :info : [ +0.002033] pci 0000:0d:00.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.004767] pci 0000:09:01.0: PCI bridge to [bus 0d]
kern :info : [ +0.000013] pci 0000:09:01.0: bridge window [mem 0xc2300000-0xc23fffff]
kern :info : [ +0.000010] pci 0000:09:01.0: bridge window [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000102] pci 0000:0e:00.0: [11c1:5901] type 00 class 0x0c0010
kern :info : [ +0.000054] pci 0000:0e:00.0: reg 0x10: [mem 0xc2200000-0xc2200fff 64bit]
kern :info : [ +0.000288] pci 0000:0e:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:0e:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000202] pci 0000:09:02.0: PCI bridge to [bus 0e]
kern :info : [ +0.000013] pci 0000:09:02.0: bridge window [mem 0xc2200000-0xc22fffff]
kern :info : [ +0.000062] pci 0000:09:04.0: PCI bridge to [bus 0f]
kern :info : [ +0.000013] pci 0000:09:04.0: bridge window [mem 0xc2100000-0xc21fffff]
kern :info : [ +0.000063] pci 0000:09:05.0: PCI bridge to [bus 10]
kern :info : [ +0.000013] pci 0000:09:05.0: bridge window [mem 0xc2000000-0xc20fffff]
kern :info : [ +0.000230] pci 0000:39:00.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000081] pci 0000:39:00.0: enabling Extended Tags
kern :info : [ +0.000130] pci 0000:39:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:39:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000192] pci 0000:06:04.0: PCI bridge to [bus 39-69]
kern :info : [ +0.000004] pci 0000:06:04.0: bridge window [io 0x5000-0x5fff]
kern :info : [ +0.000003] pci 0000:06:04.0: bridge window [mem 0xc6500000-0xca9fffff]
kern :info : [ +0.000004] pci 0000:06:04.0: bridge window [mem 0xd2b00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000090] pci 0000:3a:00.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000086] pci 0000:3a:00.0: enabling Extended Tags
kern :info : [ +0.000135] pci 0000:3a:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3a:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000174] pci 0000:3a:01.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000086] pci 0000:3a:01.0: enabling Extended Tags
kern :info : [ +0.000134] pci 0000:3a:01.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3a:01.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000171] pci 0000:3a:02.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000086] pci 0000:3a:02.0: enabling Extended Tags
kern :info : [ +0.000134] pci 0000:3a:02.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3a:02.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000175] pci 0000:3a:04.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000074] pci 0000:3a:04.0: enabling Extended Tags
kern :info : [ +0.000136] pci 0000:3a:04.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3a:04.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000173] pci 0000:3a:05.0: [8086:1513] type 01 class 0x060400
kern :info : [ +0.000075] pci 0000:3a:05.0: enabling Extended Tags
kern :info : [ +0.000135] pci 0000:3a:05.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3a:05.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000194] pci 0000:39:00.0: PCI bridge to [bus 3a-41]
kern :info : [ +0.000013] pci 0000:39:00.0: bridge window [mem 0xc6500000-0xc69fffff]
kern :info : [ +0.000009] pci 0000:39:00.0: bridge window [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000103] pci 0000:3b:00.0: [12d8:400c] type 01 class 0x060400
kern :info : [ +0.000306] pci 0000:3b:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3b:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000194] pci 0000:3a:00.0: PCI bridge to [bus 3b-3d]
kern :info : [ +0.000014] pci 0000:3a:00.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000148] pci 0000:3c:03.0: [12d8:400c] type 01 class 0x060400
kern :info : [ +0.000268] pci 0000:3c:03.0: supports D1 D2
kern :info : [ +0.000002] pci 0000:3c:03.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000182] pci 0000:3b:00.0: PCI bridge to [bus 3c-3d]
kern :info : [ +0.000019] pci 0000:3b:00.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000137] pci 0000:3d:00.0: [12d8:400e] type 00 class 0x0c0310
kern :info : [ +0.000040] pci 0000:3d:00.0: reg 0x10: [mem 0xc6901000-0xc6901fff]
kern :info : [ +0.000251] pci 0000:3d:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3d:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000151] pci 0000:3d:00.1: [12d8:400e] type 00 class 0x0c0310
kern :info : [ +0.000039] pci 0000:3d:00.1: reg 0x10: [mem 0xc6900000-0xc6900fff]
kern :info : [ +0.000251] pci 0000:3d:00.1: supports D1 D2
kern :info : [ +0.000001] pci 0000:3d:00.1: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000127] pci 0000:3d:00.2: [12d8:400f] type 00 class 0x0c0320
kern :info : [ +0.000040] pci 0000:3d:00.2: reg 0x10: [mem 0xc6902000-0xc69020ff]
kern :info : [ +0.000251] pci 0000:3d:00.2: supports D1 D2
kern :info : [ +0.000001] pci 0000:3d:00.2: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000187] pci 0000:3c:03.0: PCI bridge to [bus 3d]
kern :info : [ +0.000019] pci 0000:3c:03.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000153] pci 0000:3e:00.0: [14e4:16b0] type 00 class 0x020000
kern :info : [ +0.000054] pci 0000:3e:00.0: reg 0x10: [mem 0xd2b00000-0xd2b0ffff 64bit pref]
kern :info : [ +0.000035] pci 0000:3e:00.0: reg 0x18: [mem 0xd2b10000-0xd2b1ffff 64bit pref]
kern :info : [ +0.000460] pci 0000:3e:00.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.008090] pci 0000:3a:01.0: PCI bridge to [bus 3e]
kern :info : [ +0.000013] pci 0000:3a:01.0: bridge window [mem 0xc6800000-0xc68fffff]
kern :info : [ +0.000009] pci 0000:3a:01.0: bridge window [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000105] pci 0000:3f:00.0: [11c1:5901] type 00 class 0x0c0010
kern :info : [ +0.000055] pci 0000:3f:00.0: reg 0x10: [mem 0xc6700000-0xc6700fff 64bit]
kern :info : [ +0.000285] pci 0000:3f:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:3f:00.0: PME# supported from D0 D1 D2 D3hot D3cold
kern :info : [ +0.000199] pci 0000:3a:02.0: PCI bridge to [bus 3f]
kern :info : [ +0.000014] pci 0000:3a:02.0: bridge window [mem 0xc6700000-0xc67fffff]
kern :info : [ +0.000061] pci 0000:3a:04.0: PCI bridge to [bus 40]
kern :info : [ +0.000013] pci 0000:3a:04.0: bridge window [mem 0xc6600000-0xc66fffff]
kern :info : [ +0.000061] pci 0000:3a:05.0: PCI bridge to [bus 41]
kern :info : [ +0.000014] pci 0000:3a:05.0: bridge window [mem 0xc6500000-0xc65fffff]
kern :info : [ +0.000088] pci 0000:06:05.0: PCI bridge to [bus 6a]
kern :info : [ +0.000006] pci 0000:06:05.0: bridge window [mem 0xc1e00000-0xc1efffff]
kern :info : [ +0.000032] pci 0000:06:06.0: PCI bridge to [bus 6b]
kern :info : [ +0.000006] pci 0000:06:06.0: bridge window [mem 0xc1d00000-0xc1dfffff]
kern :info : [ +0.000068] pci 0000:00:01.2: PCI bridge to [bus 02]
kern :info : [ +0.000005] pci 0000:00:01.2: bridge window [mem 0xc1b00000-0xc1bfffff]
kern :info : [ +0.000166] pci 0000:03:00.0: [14e4:16a3] type 00 class 0x020000
kern :info : [ +0.000040] pci 0000:03:00.0: reg 0x10: [mem 0xc1800000-0xc180ffff 64bit pref]
kern :info : [ +0.000024] pci 0000:03:00.0: reg 0x18: [mem 0xc1810000-0xc181ffff 64bit pref]
kern :info : [ +0.000040] pci 0000:03:00.0: reg 0x30: [mem 0xfffff800-0xffffffff pref]
kern :info : [ +0.000178] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000232] pci 0000:03:00.1: [14e4:16bc] type 00 class 0x080501
kern :info : [ +0.000044] pci 0000:03:00.1: reg 0x10: [mem 0xc1820000-0xc182ffff 64bit pref]
kern :info : [ +0.000241] pci 0000:03:00.1: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000238] pci 0000:00:1c.0: PCI bridge to [bus 03]
kern :info : [ +0.000008] pci 0000:00:1c.0: bridge window [mem 0xc1a00000-0xc1afffff]
kern :info : [ +0.000008] pci 0000:00:1c.0: bridge window [mem 0xc1800000-0xc18fffff 64bit pref]
kern :info : [ +0.000133] pci 0000:04:00.0: [14e4:4331] type 00 class 0x028000
kern :info : [ +0.000035] pci 0000:04:00.0: reg 0x10: [mem 0xc1900000-0xc1903fff 64bit]
kern :info : [ +0.000085] pci 0000:04:00.0: enabling Extended Tags
kern :info : [ +0.000120] pci 0000:04:00.0: supports D1 D2
kern :info : [ +0.000001] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
kern :info : [ +0.000160] pci 0000:00:1c.1: PCI bridge to [bus 04]
kern :info : [ +0.000006] pci 0000:00:1c.1: bridge window [mem 0xc1900000-0xc19fffff]
kern :info : [ +0.000648] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
kern :info : [ +0.000083] ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
kern :info : [ +0.000081] ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
kern :info : [ +0.000076] ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
kern :info : [ +0.000078] ACPI: PCI Interrupt Link [LNKE] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
kern :info : [ +0.000078] ACPI: PCI Interrupt Link [LNKF] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
kern :info : [ +0.000079] ACPI: PCI Interrupt Link [LNKG] (IRQs 1 3 4 5 6 7 10 12 14 15) *0, disabled.
kern :info : [ +0.000079] ACPI: PCI Interrupt Link [LNKH] (IRQs 1 3 4 5 6 7 11 12 14 15) *0, disabled.
kern :info : [ +0.000246] ACPI: EC: interrupt unblocked
kern :info : [ +0.000001] ACPI: EC: event unblocked
kern :info : [ +0.000005] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
kern :info : [ +0.000000] ACPI: EC: GPE=0x17
kern :info : [ +0.000002] ACPI: _SB.PCI0.LPCB.EC: Boot ECDT EC initialization complete
kern :info : [ +0.000001] ACPI: _SB.PCI0.LPCB.EC: EC: Used to handle transactions and events
kern :info : [ +0.000052] iommu: Default domain type: Translated
kern :info : [ +0.000792] pci 0000:00:02.0: vgaarb: setting as boot VGA device
kern :info : [ +0.000000] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
kern :info : [ +0.000000] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
kern :info : [ +0.000004] pci 0000:00:02.0: vgaarb: no bridge control possible
kern :info : [ +0.000001] pci 0000:01:00.0: vgaarb: bridge control possible
kern :info : [ +0.000001] pci 0000:01:00.0: vgaarb: overriding boot device
kern :info : [ +0.000001] vgaarb: loaded
kern :notice: [ +0.000159] SCSI subsystem initialized
kern :debug : [ +0.000008] libata version 3.00 loaded.
kern :info : [ +0.000000] ACPI: bus type USB registered
kern :info : [ +0.000000] usbcore: registered new interface driver usbfs
kern :info : [ +0.000000] usbcore: registered new interface driver hub
kern :info : [ +0.000000] usbcore: registered new device driver usb
kern :info : [ +0.000000] pps_core: LinuxPPS API ver. 1 registered
kern :info : [ +0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
kern :info : [ +0.000000] PTP clock support registered
kern :info : [ +0.000000] EDAC MC: Ver: 3.0.0
kern :info : [ +0.000217] Registered efivars operations
kern :info : [ +0.000000] NetLabel: Initializing
kern :info : [ +0.000000] NetLabel: domain hash size = 128
kern :info : [ +0.000000] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
kern :info : [ +0.000000] NetLabel: unlabeled traffic allowed by default
kern :info : [ +0.000000] PCI: Using ACPI for IRQ routing
kern :debug : [ +0.005894] PCI: pci_cache_line_size set to 64 bytes
kern :debug : [ +0.000475] e820: reserve RAM buffer [mem 0x0008e000-0x0008ffff]
kern :debug : [ +0.000002] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
kern :debug : [ +0.000001] e820: reserve RAM buffer [mem 0x8ad14000-0x8bffffff]
kern :debug : [ +0.000002] e820: reserve RAM buffer [mem 0x8ad69000-0x8bffffff]
kern :debug : [ +0.000001] e820: reserve RAM buffer [mem 0x8ae28000-0x8bffffff]
kern :debug : [ +0.000002] e820: reserve RAM buffer [mem 0x8aece000-0x8bffffff]
kern :debug : [ +0.000001] e820: reserve RAM buffer [mem 0x8af8f000-0x8bffffff]
kern :debug : [ +0.000001] e820: reserve RAM buffer [mem 0x8b000000-0x8bffffff]
kern :debug : [ +0.000001] e820: reserve RAM buffer [mem 0x46f600000-0x46fffffff]
kern :info : [ +0.000558] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
kern :info : [ +0.000006] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
kern :info : [ +0.002644] clocksource: Switched to clocksource tsc-early
kern :notice: [ +0.011162] VFS: Disk quotas dquot_6.6.0
kern :info : [ +0.000016] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
kern :info : [ +0.000103] AppArmor: AppArmor Filesystem Enabled
kern :info : [ +0.000029] pnp: PnP ACPI init
kern :info : [ +0.000317] system 00:00: [mem 0xfed00000-0xfed003ff] has been reserved
kern :debug : [ +0.000007] system 00:00: Plug and Play ACPI device, IDs PNP0103 PNP0c01 (active)
kern :info : [ +0.000045] system 00:01: [io 0x1000-0x100f] has been reserved
kern :info : [ +0.000002] system 00:01: [io 0x0400-0x047f] has been reserved
kern :info : [ +0.000001] system 00:01: [io 0x0500-0x057f] has been reserved
kern :debug : [ +0.000004] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
kern :debug : [ +0.000019] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
kern :debug : [ +0.000079] pnp 00:03: Plug and Play ACPI device, IDs APP000b (active)
kern :info : [ +0.000198] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
kern :info : [ +0.000001] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
kern :info : [ +0.000001] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
kern :info : [ +0.000002] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
kern :info : [ +0.000001] system 00:04: [mem 0xe0000000-0xefffffff] could not be reserved
kern :info : [ +0.000002] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
kern :info : [ +0.000001] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
kern :info : [ +0.000002] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
kern :info : [ +0.000001] system 00:04: [mem 0xff000000-0xffffffff] could not be reserved
kern :info : [ +0.000001] system 00:04: [mem 0xfee00000-0xfeefffff] has been reserved
kern :debug : [ +0.000004] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
kern :info : [ +0.000236] system 00:05: [mem 0x20000000-0x201fffff] has been reserved
kern :info : [ +0.000001] system 00:05: [mem 0x40000000-0x401fffff] could not be reserved
kern :debug : [ +0.000004] system 00:05: Plug and Play ACPI device, IDs PNP0c01 (active)
kern :info : [ +0.000008] pnp: PnP ACPI: found 6 devices
kern :info : [ +0.005651] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
kern :info : [ +0.000053] NET: Registered protocol family 2
kern :info : [ +0.000145] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
kern :info : [ +0.000076] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
kern :info : [ +0.000209] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
kern :info : [ +0.000077] TCP: Hash tables configured (established 131072 bind 65536)
kern :info : [ +0.000072] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
kern :info : [ +0.000074] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
kern :info : [ +0.000043] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
kern :info : [ +0.000089] NET: Registered protocol family 1
kern :info : [ +0.000004] NET: Registered protocol family 44
kern :info : [ +0.000008] pci 0000:03:00.0: can’t claim BAR 6 [mem 0xfffff800-0xffffffff pref]: no compatible bridge window
kern :info : [ +0.000007] pci 0000:09:04.0: bridge window [io 0x1000-0x0fff] to [bus 0f] add_size 1000
kern :info : [ +0.000002] pci 0000:09:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0f] add_size 200000 add_align 100000
kern :info : [ +0.000001] pci 0000:09:05.0: bridge window [io 0x1000-0x0fff] to [bus 10] add_size 1000
kern :info : [ +0.000002] pci 0000:09:05.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 10] add_size 200000 add_align 100000
kern :info : [ +0.000002] pci 0000:08:00.0: bridge window [io 0x1000-0x0fff] to [bus 09-10] add_size 2000
kern :info : [ +0.000003] pci 0000:3a:04.0: bridge window [io 0x1000-0x0fff] to [bus 40] add_size 1000
kern :info : [ +0.000002] pci 0000:3a:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 40] add_size 200000 add_align 100000
kern :info : [ +0.000001] pci 0000:3a:05.0: bridge window [io 0x1000-0x0fff] to [bus 41] add_size 1000
kern :info : [ +0.000002] pci 0000:3a:05.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 41] add_size 200000 add_align 100000
kern :info : [ +0.000001] pci 0000:39:00.0: bridge window [io 0x1000-0x0fff] to [bus 3a-41] add_size 2000
kern :info : [ +0.000002] pci 0000:06:05.0: bridge window [io 0x1000-0x0fff] to [bus 6a] add_size 1000
kern :info : [ +0.000002] pci 0000:06:05.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 6a] add_size 200000 add_align 100000
kern :info : [ +0.000001] pci 0000:06:06.0: bridge window [io 0x1000-0x0fff] to [bus 6b] add_size 1000
kern :info : [ +0.000001] pci 0000:06:06.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 6b] add_size 200000 add_align 100000
kern :info : [ +0.000006] pci 0000:00:01.0: PCI bridge to [bus 01]
kern :info : [ +0.000010] pci 0000:06:05.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:06:05.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000003] pci 0000:06:06.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:06:06.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:06:05.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:06:05.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000001] pci 0000:06:06.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:06:06.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000002] pci 0000:06:06.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000002] pci 0000:06:05.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000002] pci 0000:06:05.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:06:00.0: PCI bridge to [bus 07]
kern :info : [ +0.000004] pci 0000:06:00.0: bridge window [mem 0xc1f00000-0xc1ffffff]
kern :info : [ +0.000006] pci 0000:08:00.0: BAR 13: no space for [io size 0x2000]
kern :info : [ +0.000001] pci 0000:08:00.0: BAR 13: failed to assign [io size 0x2000]
kern :info : [ +0.000002] pci 0000:08:00.0: BAR 13: no space for [io size 0x2000]
kern :info : [ +0.000004] pci 0000:09:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:09:04.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000002] pci 0000:09:05.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:09:05.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:09:04.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:09:04.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000002] pci 0000:09:05.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:09:05.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000001] pci 0000:09:05.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000002] pci 0000:09:05.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000002] pci 0000:09:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000002] pci 0000:0b:03.0: PCI bridge to [bus 0c]
kern :info : [ +0.000010] pci 0000:0b:03.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000019] pci 0000:0a:00.0: PCI bridge to [bus 0b-0c]
kern :info : [ +0.000010] pci 0000:0a:00.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000018] pci 0000:09:00.0: PCI bridge to [bus 0a-0c]
kern :info : [ +0.000008] pci 0000:09:00.0: bridge window [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000013] pci 0000:09:01.0: PCI bridge to [bus 0d]
kern :info : [ +0.000007] pci 0000:09:01.0: bridge window [mem 0xc2300000-0xc23fffff]
kern :info : [ +0.000005] pci 0000:09:01.0: bridge window [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000009] pci 0000:09:02.0: PCI bridge to [bus 0e]
kern :info : [ +0.000007] pci 0000:09:02.0: bridge window [mem 0xc2200000-0xc22fffff]
kern :info : [ +0.000013] pci 0000:09:04.0: PCI bridge to [bus 0f]
kern :info : [ +0.000007] pci 0000:09:04.0: bridge window [mem 0xc2100000-0xc21fffff]
kern :info : [ +0.000013] pci 0000:09:05.0: PCI bridge to [bus 10]
kern :info : [ +0.000007] pci 0000:09:05.0: bridge window [mem 0xc2000000-0xc20fffff]
kern :info : [ +0.000013] pci 0000:08:00.0: PCI bridge to [bus 09-10]
kern :info : [ +0.000007] pci 0000:08:00.0: bridge window [mem 0xc2000000-0xc24fffff]
kern :info : [ +0.000005] pci 0000:08:00.0: bridge window [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000009] pci 0000:06:03.0: PCI bridge to [bus 08-38]
kern :info : [ +0.000002] pci 0000:06:03.0: bridge window [io 0x4000-0x4fff]
kern :info : [ +0.000003] pci 0000:06:03.0: bridge window [mem 0xcea00000-0xd2afffff 64bit pref]
kern :info : [ +0.000004] pci 0000:39:00.0: BAR 13: no space for [io size 0x2000]
kern :info : [ +0.000001] pci 0000:39:00.0: BAR 13: failed to assign [io size 0x2000]
kern :info : [ +0.000002] pci 0000:39:00.0: BAR 13: no space for [io size 0x2000]
kern :info : [ +0.000003] pci 0000:3a:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:3a:04.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000002] pci 0000:3a:05.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:3a:05.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
kern :info : [ +0.000001] pci 0000:3a:04.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:3a:04.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000001] pci 0000:3a:05.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000002] pci 0000:3a:05.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000001] pci 0000:3a:05.0: BAR 13: failed to assign [io size 0x1000]
kern :info : [ +0.000002] pci 0000:3a:04.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
kern :info : [ +0.000002] pci 0000:3a:04.0: BAR 13: no space for [io size 0x1000]
kern :info : [ +0.000001] pci 0000:3c:03.0: PCI bridge to [bus 3d]
kern :info : [ +0.000010] pci 0000:3c:03.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000019] pci 0000:3b:00.0: PCI bridge to [bus 3c-3d]
kern :info : [ +0.000010] pci 0000:3b:00.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000018] pci 0000:3a:00.0: PCI bridge to [bus 3b-3d]
kern :info : [ +0.000007] pci 0000:3a:00.0: bridge window [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000014] pci 0000:3a:01.0: PCI bridge to [bus 3e]
kern :info : [ +0.000007] pci 0000:3a:01.0: bridge window [mem 0xc6800000-0xc68fffff]
kern :info : [ +0.000005] pci 0000:3a:01.0: bridge window [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000009] pci 0000:3a:02.0: PCI bridge to [bus 3f]
kern :info : [ +0.000007] pci 0000:3a:02.0: bridge window [mem 0xc6700000-0xc67fffff]
kern :info : [ +0.000013] pci 0000:3a:04.0: PCI bridge to [bus 40]
kern :info : [ +0.000007] pci 0000:3a:04.0: bridge window [mem 0xc6600000-0xc66fffff]
kern :info : [ +0.000013] pci 0000:3a:05.0: PCI bridge to [bus 41]
kern :info : [ +0.000007] pci 0000:3a:05.0: bridge window [mem 0xc6500000-0xc65fffff]
kern :info : [ +0.000012] pci 0000:39:00.0: PCI bridge to [bus 3a-41]
kern :info : [ +0.000007] pci 0000:39:00.0: bridge window [mem 0xc6500000-0xc69fffff]
kern :info : [ +0.000005] pci 0000:39:00.0: bridge window [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000009] pci 0000:06:04.0: PCI bridge to [bus 39-69]
kern :info : [ +0.000002] pci 0000:06:04.0: bridge window [io 0x5000-0x5fff]
kern :info : [ +0.000003] pci 0000:06:04.0: bridge window [mem 0xd2b00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000003] pci 0000:06:05.0: PCI bridge to [bus 6a]
kern :info : [ +0.000004] pci 0000:06:05.0: bridge window [mem 0xc1e00000-0xc1efffff]
kern :info : [ +0.000005] pci 0000:06:06.0: PCI bridge to [bus 6b]
kern :info : [ +0.000003] pci 0000:06:06.0: bridge window [mem 0xc1d00000-0xc1dfffff]
kern :info : [ +0.000006] pci 0000:05:00.0: PCI bridge to [bus 06-6b]
kern :info : [ +0.000002] pci 0000:05:00.0: bridge window [io 0x4000-0x5fff]
kern :info : [ +0.000003] pci 0000:05:00.0: bridge window [mem 0xc1d00000-0xca9fffff]
kern :info : [ +0.000002] pci 0000:05:00.0: bridge window [mem 0xcea00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000004] pci 0000:00:01.1: PCI bridge to [bus 05-6b]
kern :info : [ +0.000001] pci 0000:00:01.1: bridge window [io 0x4000-0x6fff]
kern :info : [ +0.000003] pci 0000:00:01.2: PCI bridge to [bus 02]
kern :info : [ +0.000004] pci 0000:00:01.2: bridge window [mem 0xc1b00000-0xc1bfffff]
kern :info : [ +0.000009] pci 0000:03:00.0: BAR 6: assigned [mem 0xc1a00000-0xc1a007ff pref]
kern :info : [ +0.000001] pci 0000:00:1c.0: PCI bridge to [bus 03]
kern :info : [ +0.000009] pci 0000:00:1c.0: bridge window [mem 0xc1a00000-0xc1afffff]
kern :info : [ +0.000004] pci 0000:00:1c.0: bridge window [mem 0xc1800000-0xc18fffff 64bit pref]
kern :info : [ +0.000008] pci 0000:00:1c.1: PCI bridge to [bus 04]
kern :info : [ +0.000013] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
kern :info : [ +0.000002] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
kern :info : [ +0.000002] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 20 [mem 0x8fa00000-0xfeafffff window]
kern :info : [ +0.000001] pci_bus 0000:00: resource 21 [mem 0xfed40000-0xfed44fff window]
kern :info : [ +0.000001] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
kern :info : [ +0.000002] pci_bus 0000:01: resource 1 [mem 0xc0000000-0xc10fffff]
kern :info : [ +0.000001] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa1ffffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:05: resource 0 [io 0x4000-0x6fff]
kern :info : [ +0.000001] pci_bus 0000:05: resource 1 [mem 0xc1d00000-0xce9fffff]
kern :info : [ +0.000001] pci_bus 0000:05: resource 2 [mem 0xcea00000-0xdabfffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:06: resource 0 [io 0x4000-0x5fff]
kern :info : [ +0.000001] pci_bus 0000:06: resource 1 [mem 0xc1d00000-0xca9fffff]
kern :info : [ +0.000001] pci_bus 0000:06: resource 2 [mem 0xcea00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:07: resource 1 [mem 0xc1f00000-0xc1ffffff]
kern :info : [ +0.000001] pci_bus 0000:08: resource 0 [io 0x4000-0x4fff]
kern :info : [ +0.000002] pci_bus 0000:08: resource 1 [mem 0xc2000000-0xc64fffff]
kern :info : [ +0.000001] pci_bus 0000:08: resource 2 [mem 0xcea00000-0xd2afffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:09: resource 1 [mem 0xc2000000-0xc24fffff]
kern :info : [ +0.000001] pci_bus 0000:09: resource 2 [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:0a: resource 1 [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000001] pci_bus 0000:0b: resource 1 [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000001] pci_bus 0000:0c: resource 1 [mem 0xc2400000-0xc24fffff]
kern :info : [ +0.000002] pci_bus 0000:0d: resource 1 [mem 0xc2300000-0xc23fffff]
kern :info : [ +0.000001] pci_bus 0000:0d: resource 2 [mem 0xcea00000-0xceafffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:0e: resource 1 [mem 0xc2200000-0xc22fffff]
kern :info : [ +0.000001] pci_bus 0000:0f: resource 1 [mem 0xc2100000-0xc21fffff]
kern :info : [ +0.000001] pci_bus 0000:10: resource 1 [mem 0xc2000000-0xc20fffff]
kern :info : [ +0.000001] pci_bus 0000:39: resource 0 [io 0x5000-0x5fff]
kern :info : [ +0.000001] pci_bus 0000:39: resource 1 [mem 0xc6500000-0xca9fffff]
kern :info : [ +0.000001] pci_bus 0000:39: resource 2 [mem 0xd2b00000-0xd6bfffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:3a: resource 1 [mem 0xc6500000-0xc69fffff]
kern :info : [ +0.000001] pci_bus 0000:3a: resource 2 [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000002] pci_bus 0000:3b: resource 1 [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000001] pci_bus 0000:3c: resource 1 [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000001] pci_bus 0000:3d: resource 1 [mem 0xc6900000-0xc69fffff]
kern :info : [ +0.000001] pci_bus 0000:3e: resource 1 [mem 0xc6800000-0xc68fffff]
kern :info : [ +0.000001] pci_bus 0000:3e: resource 2 [mem 0xd2b00000-0xd2bfffff 64bit pref]
kern :info : [ +0.000001] pci_bus 0000:3f: resource 1 [mem 0xc6700000-0xc67fffff]
kern :info : [ +0.000001] pci_bus 0000:40: resource 1 [mem 0xc6600000-0xc66fffff]
kern :info : [ +0.000001] pci_bus 0000:41: resource 1 [mem 0xc6500000-0xc65fffff]
kern :info : [ +0.000002] pci_bus 0000:6a: resource 1 [mem 0xc1e00000-0xc1efffff]
kern :info : [ +0.000001] pci_bus 0000:6b: resource 1 [mem 0xc1d00000-0xc1dfffff]
kern :info : [ +0.000001] pci_bus 0000:02: resource 1 [mem 0xc1b00000-0xc1bfffff]
kern :info : [ +0.000001] pci_bus 0000:03: resource 1 [mem 0xc1a00000-0xc1afffff]
kern :info : [ +0.000001] pci_bus 0000:03: resource 2 [mem 0xc1800000-0xc18fffff 64bit pref]
kern :info : [ +0.000002] pci_bus 0000:04: resource 1 [mem 0xc1900000-0xc19fffff]
kern :info : [ +0.000099] pci 0000:00:14.0: enabling device (0000 → 0002)
kern :warn : [ +0.000077] pci 0000:00:14.0: can’t derive routing for PCI INT A
kern :warn : [ +0.000001] pci 0000:00:14.0: PCI INT A: no GSI
kern :info : [ +0.000419] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
kern :info : [ +0.000049] pci 0000:05:00.0: CLS mismatch (256 != 128), using 64 bytes
kern :info : [ +0.000018] pci 0000:0c:00.0: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:0c:00.0: PME# is unreliable, disabling it
kern :info : [ +0.000339] pci 0000:0c:00.1: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:0c:00.1: PME# is unreliable, disabling it
kern :info : [ +0.000096] pci 0000:0c:00.2: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:0c:00.2: PME# is unreliable, disabling it
kern :warn : [ +0.000056] pci 0000:0c:00.2: EHCI: unrecognized capability 00
kern :info : [ +0.000050] pci 0000:3d:00.0: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:3d:00.0: PME# is unreliable, disabling it
kern :info : [ +0.000219] pci 0000:3d:00.1: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:3d:00.1: PME# is unreliable, disabling it
kern :info : [ +0.000094] pci 0000:3d:00.2: MSI is not implemented on this device, disabling it
kern :info : [ +0.000001] pci 0000:3d:00.2: PME# is unreliable, disabling it
kern :warn : [ +0.000061] pci 0000:3d:00.2: EHCI: unrecognized capability 00
kern :info : [ +0.000084] Trying to unpack rootfs image as initramfs…
kern :info : [ +0.116258] Freeing initrd memory: 12064K
kern :info : [ +0.000053] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
kern :info : [ +0.000002] software IO TLB: mapped [mem 0x0000000078a98000-0x000000007ca98000] (64MB)
kern :info : [ +0.000660] check: Scanning for low memory corruption every 60 seconds
kern :notice: [ +0.000289] Initialise system trusted keyrings
kern :notice: [ +0.000008] Key type blacklist registered
kern :info : [ +0.000041] workingset: timestamp_bits=41 max_order=22 bucket_order=0
kern :info : [ +0.001002] zbud: loaded
kern :notice: [ +0.010837] Key type asymmetric registered
kern :notice: [ +0.000001] Asymmetric key parser ‘x509’ registered
kern :info : [ +0.000006] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
kern :info : [ +0.000028] io scheduler mq-deadline registered
kern :info : [ +0.000001] io scheduler kyber registered
kern :info : [ +0.000019] io scheduler bfq registered
kern :info : [ +0.000079] atomic64_test: passed for x86-64 platform with CX8 and with SSE
kern :info : [ +0.000294] pcieport 0000:00:01.2: enabling device (0000 → 0002)
kern :info : [ +0.000756] pcieport 0000:06:03.0: pciehp: Slot #3 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000152] pcieport 0000:06:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000101] pcieport 0000:06:05.0: enabling device (0000 → 0002)
kern :info : [ +0.000091] pcieport 0000:06:05.0: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000098] pcieport 0000:06:06.0: enabling device (0000 → 0002)
kern :info : [ +0.000090] pcieport 0000:06:06.0: pciehp: Slot #6 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000912] pcieport 0000:09:04.0: enabling device (0000 → 0002)
kern :info : [ +0.000093] pcieport 0000:09:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000178] pcieport 0000:09:05.0: enabling device (0000 → 0002)
kern :info : [ +0.000094] pcieport 0000:09:05.0: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.001176] pcieport 0000:3a:04.0: enabling device (0000 → 0002)
kern :info : [ +0.000092] pcieport 0000:3a:04.0: pciehp: Slot #4 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000171] pcieport 0000:3a:05.0: enabling device (0000 → 0002)
kern :info : [ +0.000096] pcieport 0000:3a:05.0: pciehp: Slot #5 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+ (with Cmd Compl erratum)
kern :info : [ +0.000450] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
kern :info : [ +0.000030] efifb: probing for efifb
kern :info : [ +0.000042] efifb: No BGRT, not showing boot graphics
kern :info : [ +0.000002] efifb: framebuffer at 0x90020000, using 23040k, total 23040k
kern :info : [ +0.000001] efifb: mode is 2560x1440x32, linelength=16384, pages=1
kern :info : [ +0.000000] efifb: scrolling: redraw
kern :info : [ +0.000001] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
kern :info : [ +0.000033] fbcon: Deferring console take-over
kern :info : [ +0.000001] fb0: EFI VGA frame buffer device
kern :debug : [ +0.000007] intel_idle: MWAIT substates: 0x21120
kern :debug : [ +0.000002] intel_idle: v0.5.1 model 0x3A
kern :debug : [ +0.000292] intel_idle: Local APIC timer is reliable in all C-states
kern :info : [ +0.000124] ACPI: AC Adapter [ADP1] (on-line)
kern :info : [ +0.000053] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
kern :info : [ +0.004235] ACPI: Lid Switch [LID0]
kern :info : [ +0.000045] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
kern :info : [ +0.000019] ACPI: Power Button [PWRB]
kern :info : [ +0.000025] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
kern :info : [ +0.000014] ACPI: Sleep Button [SLPB]
kern :info : [ +0.000026] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
kern :info : [ +0.003185] ACPI: Power Button [PWRF]
kern :info : [ +0.003988] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
kern :info : [ +0.001726] Non-volatile memory driver v1.3
kern :info : [ +0.000002] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel jroedel@suse.de
kern :info : [ +0.000001] AMD-Vi: AMD IOMMUv2 functionality not available on this system
kern :debug : [ +0.000873] ahci 0000:00:1f.2: version 3.0
kern :info : [ +0.000215] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1 impl SATA mode
kern :info : [ +0.000003] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
kern :info : [ +0.000475] scsi host0: ahci
kern :info : [ +0.000167] scsi host1: ahci
kern :info : [ +0.000113] scsi host2: ahci
kern :info : [ +0.000076] scsi host3: ahci
kern :info : [ +0.000068] scsi host4: ahci
kern :info : [ +0.000073] scsi host5: ahci
kern :info : [ +0.000032] ata1: SATA max UDMA/133 abar m2048@0xc1c16000 port 0xc1c16100 irq 45
kern :info : [ +0.000001] ata2: DUMMY
kern :info : [ +0.000001] ata3: DUMMY
kern :info : [ +0.000000] ata4: DUMMY
kern :info : [ +0.000001] ata5: DUMMY
kern :info : [ +0.000001] ata6: DUMMY
kern :info : [ +0.000048] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
kern :info : [ +0.000007] ehci-pci: EHCI PCI platform driver
kern :info : [ +0.000147] ehci-pci 0000:00:1a.0: EHCI Host Controller
kern :info : [ +0.000005] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
kern :info : [ +0.000014] ehci-pci 0000:00:1a.0: debug port 2
kern :info : [ +0.003911] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
kern :info : [ +0.000011] ehci-pci 0000:00:1a.0: irq 23, io mem 0xc1c16c00
kern :info : [ +0.011439] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
kern :info : [ +0.000072] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
kern :info : [ +0.000002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb1: Product: EHCI Host Controller
kern :info : [ +0.000001] usb usb1: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
kern :info : [ +0.000001] usb usb1: SerialNumber: 0000:00:1a.0
kern :info : [ +0.000254] hub 1-0:1.0: USB hub found
kern :info : [ +0.000010] hub 1-0:1.0: 2 ports detected
kern :info : [ +0.000331] ehci-pci 0000:00:1d.0: EHCI Host Controller
kern :info : [ +0.000008] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
kern :info : [ +0.000016] ehci-pci 0000:00:1d.0: debug port 2
kern :info : [ +0.003907] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
kern :info : [ +0.000013] ehci-pci 0000:00:1d.0: irq 22, io mem 0xc1c16800
kern :info : [ +0.012050] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
kern :info : [ +0.000066] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
kern :info : [ +0.000001] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000002] usb usb2: Product: EHCI Host Controller
kern :info : [ +0.000001] usb usb2: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
kern :info : [ +0.000001] usb usb2: SerialNumber: 0000:00:1d.0
kern :info : [ +0.000232] hub 2-0:1.0: USB hub found
kern :info : [ +0.000010] hub 2-0:1.0: 2 ports detected
kern :info : [ +0.000301] ehci-pci 0000:0c:00.2: EHCI Host Controller
kern :info : [ +0.000006] ehci-pci 0000:0c:00.2: new USB bus registered, assigned bus number 3
kern :info : [ +0.000077] ehci-pci 0000:0c:00.2: irq 17, io mem 0xc2402000
kern :info : [ +0.012635] ehci-pci 0000:0c:00.2: USB 2.0 started, EHCI 1.00
kern :info : [ +0.000061] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
kern :info : [ +0.000002] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb3: Product: EHCI Host Controller
kern :info : [ +0.000001] usb usb3: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
kern :info : [ +0.000001] usb usb3: SerialNumber: 0000:0c:00.2
kern :info : [ +0.000219] hub 3-0:1.0: USB hub found
kern :info : [ +0.000009] hub 3-0:1.0: 4 ports detected
kern :info : [ +0.000333] ehci-pci 0000:3d:00.2: EHCI Host Controller
kern :info : [ +0.000006] ehci-pci 0000:3d:00.2: new USB bus registered, assigned bus number 4
kern :info : [ +0.000076] ehci-pci 0000:3d:00.2: irq 18, io mem 0xc6902000
kern :info : [ +0.012621] ehci-pci 0000:3d:00.2: USB 2.0 started, EHCI 1.00
kern :info : [ +0.000080] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
kern :info : [ +0.000002] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb4: Product: EHCI Host Controller
kern :info : [ +0.000001] usb usb4: Manufacturer: Linux 5.10.7-3-MANJARO ehci_hcd
kern :info : [ +0.000001] usb usb4: SerialNumber: 0000:3d:00.2
kern :info : [ +0.000213] hub 4-0:1.0: USB hub found
kern :info : [ +0.000009] hub 4-0:1.0: 4 ports detected
kern :info : [ +0.000193] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
kern :info : [ +0.000005] ohci-pci: OHCI PCI platform driver
kern :info : [ +0.000146] ohci-pci 0000:0c:00.0: OHCI PCI host controller
kern :info : [ +0.000006] ohci-pci 0000:0c:00.0: new USB bus registered, assigned bus number 5
kern :info : [ +0.000043] ohci-pci 0000:0c:00.0: irq 19, io mem 0xc2401000
kern :info : [ +0.060080] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
kern :info : [ +0.000003] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb5: Product: OHCI PCI host controller
kern :info : [ +0.000001] usb usb5: Manufacturer: Linux 5.10.7-3-MANJARO ohci_hcd
kern :info : [ +0.000001] usb usb5: SerialNumber: 0000:0c:00.0
kern :info : [ +0.000196] hub 5-0:1.0: USB hub found
kern :info : [ +0.000015] hub 5-0:1.0: 2 ports detected
kern :info : [ +0.000251] ohci-pci 0000:0c:00.1: OHCI PCI host controller
kern :info : [ +0.000006] ohci-pci 0000:0c:00.1: new USB bus registered, assigned bus number 6
kern :info : [ +0.000035] ohci-pci 0000:0c:00.1: irq 16, io mem 0xc2400000
kern :info : [ +0.059490] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
kern :info : [ +0.000003] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb6: Product: OHCI PCI host controller
kern :info : [ +0.000001] usb usb6: Manufacturer: Linux 5.10.7-3-MANJARO ohci_hcd
kern :info : [ +0.000001] usb usb6: SerialNumber: 0000:0c:00.1
kern :info : [ +0.000226] hub 6-0:1.0: USB hub found
kern :info : [ +0.000014] hub 6-0:1.0: 2 ports detected
kern :info : [ +0.000254] ohci-pci 0000:3d:00.0: OHCI PCI host controller
kern :info : [ +0.000005] ohci-pci 0000:3d:00.0: new USB bus registered, assigned bus number 7
kern :info : [ +0.000029] ohci-pci 0000:3d:00.0: irq 16, io mem 0xc6901000
kern :info : [ +0.059453] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
kern :info : [ +0.000003] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb7: Product: OHCI PCI host controller
kern :info : [ +0.000001] usb usb7: Manufacturer: Linux 5.10.7-3-MANJARO ohci_hcd
kern :info : [ +0.000001] usb usb7: SerialNumber: 0000:3d:00.0
kern :info : [ +0.000227] hub 7-0:1.0: USB hub found
kern :info : [ +0.000015] hub 7-0:1.0: 2 ports detected
kern :info : [ +0.000284] ohci-pci 0000:3d:00.1: OHCI PCI host controller
kern :info : [ +0.000007] ohci-pci 0000:3d:00.1: new USB bus registered, assigned bus number 8
kern :info : [ +0.000030] ohci-pci 0000:3d:00.1: irq 17, io mem 0xc6900000
kern :info : [ +0.059451] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
kern :info : [ +0.000003] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb8: Product: OHCI PCI host controller
kern :info : [ +0.000002] usb usb8: Manufacturer: Linux 5.10.7-3-MANJARO ohci_hcd
kern :info : [ +0.000000] usb usb8: SerialNumber: 0000:3d:00.1
kern :info : [ +0.000201] hub 8-0:1.0: USB hub found
kern :info : [ +0.000015] hub 8-0:1.0: 2 ports detected
kern :info : [ +0.000144] uhci_hcd: USB Universal Host Controller Interface driver
kern :info : [ +0.000059] usbcore: registered new interface driver usbserial_generic
kern :info : [ +0.000005] usbserial: USB Serial support registered for generic
kern :info : [ +0.000023] i8042: PNP: No PS/2 controller found.
kern :info : [ +0.000568] rtc_cmos 00:02: RTC can wake from S4
kern :info : [ +0.000303] rtc_cmos 00:02: registered as rtc0
kern :info : [ +0.000070] rtc_cmos 00:02: setting system clock to 2021-02-08T21:33:52 UTC (1612820032)
kern :info : [ +0.000017] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
kern :info : [ +0.000051] intel_pstate: Intel P-state driver initializing
kern :info : [ +0.000625] ledtrig-cpu: registered to indicate activity on CPUs
kern :info : [ +0.013786] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
kern :info : [ +0.000868] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kern :info : [ +0.000054] ata1.00: ATA-10: Aura Pro S MB258, R1016ANR, max UDMA/133
kern :info : [ +0.000002] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
kern :warn : [ +0.000184] ata1.00: READ LOG DMA EXT failed, trying PIO
kern :debug : [ +0.000001] ata1.00: failed to get Identify Device Data, Emask 0x40
kern :err : [ +0.000004] ata1.00: failed to set xfermode (err_mask=0x40)
kern :info : [ +0.032163] usb 1-1: new high-speed USB device number 2 using ehci-pci
kern :info : [ +0.016664] usb 2-1: new high-speed USB device number 2 using ehci-pci
kern :info : [ +0.009996] usb 3-1: new high-speed USB device number 2 using ehci-pci
kern :info : [ +0.013335] usb 4-1: new high-speed USB device number 2 using ehci-pci
kern :info : [ +0.085479] pstore: Registered efi as persistent store backend
kern :info : [ +0.000011] hid: raw HID events driver (C) Jiri Kosina
kern :info : [ +0.000113] ashmem: initialized
kern :info : [ +0.000085] drop_monitor: Initializing network drop monitor service
kern :info : [ +0.000049] Initializing XFRM netlink socket
kern :info : [ +0.000067] NET: Registered protocol family 10
kern :info : [ +0.005213] Segment Routing with IPv6
kern :info : [ +0.000001] RPL Segment Routing with IPv6
kern :info : [ +0.000054] NET: Registered protocol family 17
kern :info : [ +0.001278] microcode: sig=0x306a9, pf=0x10, revision=0x21
kern :info : [ +0.000285] microcode: Microcode Update Driver: v2.2.
kern :info : [ +0.000005] IPI shorthand broadcast: enabled
kern :info : [ +0.000006] sched_clock: Marking stable (939127041, 212335)->(946924279, -7584903)
kern :info : [ +0.000290] registered taskstats version 1
kern :notice: [ +0.000016] Loading compiled-in X.509 certificates
kern :notice: [ +0.005229] Loaded X.509 cert ‘Build time autogenerated kernel key: 8a686ad556c46e452fd7dfcd5b8bb6b61e7f128b’
kern :info : [ +0.001363] zswap: loaded using pool zstd/z3fold
kern :notice: [ +0.000359] Key type ._fscrypt registered
kern :notice: [ +0.000010] Key type .fscrypt registered
kern :notice: [ +0.000001] Key type fscrypt-provisioning registered
kern :info : [ +0.000153] pstore: Using crash dump compression: zstd
kern :info : [ +0.000032] AppArmor: AppArmor sha1 policy hashing enabled
kern :info : [ +0.000638] PM: Magic number: 9:832:600
kern :info : [ +0.000227] RAS: Correctable Errors collector initialized.
kern :info : [ +0.006167] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
kern :info : [ +0.000007] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.000423] hub 1-1:1.0: USB hub found
kern :info : [ +0.000239] hub 1-1:1.0: 6 ports detected
kern :info : [ +0.019346] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
kern :info : [ +0.000004] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.000458] hub 2-1:1.0: USB hub found
kern :info : [ +0.000194] hub 2-1:1.0: 8 ports detected
kern :info : [ +0.009566] usb 3-1: New USB device found, idVendor=05ac, idProduct=9127, bcdDevice= 1.00
kern :info : [ +0.000006] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.000398] hub 3-1:1.0: USB hub found
kern :info : [ +0.000218] hub 3-1:1.0: 7 ports detected
kern :info : [ +0.016179] usb 4-1: New USB device found, idVendor=05ac, idProduct=9127, bcdDevice= 1.00
kern :info : [ +0.000011] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.000540] hub 4-1:1.0: USB hub found
kern :info : [ +0.000301] hub 4-1:1.0: 7 ports detected
kern :info : [ +0.231721] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
kern :info : [ +0.019989] usb 2-1.8: new high-speed USB device number 3 using ehci-pci
kern :info : [ +0.010018] usb 3-1.4: new full-speed USB device number 3 using ehci-pci
kern :info : [ +0.020002] usb 4-1.4: new full-speed USB device number 3 using ehci-pci
kern :info : [ +0.066689] usb 1-1.1: New USB device found, idVendor=05ac, idProduct=8510, bcdDevice=80.25
kern :info : [ +0.000007] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 1-1.1: Product: FaceTime HD Camera (Built-in)
kern :info : [ +0.000002] usb 1-1.1: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 1-1.1: SerialNumber: CC2EAS060JDN9KE0
kern :info : [ +0.000478] usb 2-1.8: New USB device found, idVendor=0424, idProduct=2512, bcdDevice= b.b3
kern :info : [ +0.000005] usb 2-1.8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.000427] hub 2-1.8:1.0: USB hub found
kern :info : [ +0.000186] hub 2-1.8:1.0: 2 ports detected
kern :notice: [ +0.062882] random: fast init done
kern :info : [ +0.009669] usb 3-1.4: New USB device found, idVendor=05ac, idProduct=1107, bcdDevice= 2.09
kern :info : [ +0.000006] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 3-1.4: Product: Display Audio
kern :info : [ +0.000002] usb 3-1.4: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 3-1.4: SerialNumber: 17020545
kern :info : [ +0.012928] tsc: Refined TSC clocksource calibration: 2693.872 MHz
kern :info : [ +0.000017] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26d4a150b53, max_idle_ns: 440795215022 ns
kern :info : [ +0.000057] clocksource: Switched to clocksource tsc
kern :info : [ +0.006532] usb 4-1.4: New USB device found, idVendor=05ac, idProduct=1107, bcdDevice= 2.09
kern :info : [ +0.000023] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 4-1.4: Product: Display Audio
kern :info : [ +0.000003] usb 4-1.4: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 4-1.4: SerialNumber: 16100E97
kern :info : [ +0.070065] usb 3-1.5: new high-speed USB device number 4 using ehci-pci
kern :info : [ +0.003322] usb 4-1.5: new high-speed USB device number 4 using ehci-pci
kern :info : [ +0.111078] usb 3-1.5: New USB device found, idVendor=05ac, idProduct=1112, bcdDevice=71.60
kern :info : [ +0.000007] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 3-1.5: Product: FaceTime HD Camera (Display)
kern :info : [ +0.000002] usb 3-1.5: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 3-1.5: SerialNumber: CCGCBV004GDJ9DFX
kern :info : [ +0.002215] usb 2-1.8.1: new full-speed USB device number 4 using ehci-pci
kern :info : [ +0.000431] usb 4-1.5: New USB device found, idVendor=05ac, idProduct=1112, bcdDevice=71.60
kern :info : [ +0.000005] usb 4-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 4-1.5: Product: FaceTime HD Camera (Display)
kern :info : [ +0.000002] usb 4-1.5: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 4-1.5: SerialNumber: CCGC2Q02PQDJ9DFX
kern :info : [ +0.072958] usb 3-1.7: new full-speed USB device number 5 using ehci-pci
kern :info : [ +0.003293] usb 4-1.7: new full-speed USB device number 5 using ehci-pci
kern :info : [ +0.022709] usb 2-1.8.1: New USB device found, idVendor=0a5c, idProduct=4500, bcdDevice= 1.00
kern :info : [ +0.000006] usb 2-1.8.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern :info : [ +0.000003] usb 2-1.8.1: Product: BRCM20702 Hub
kern :info : [ +0.000002] usb 2-1.8.1: Manufacturer: Apple Inc.
kern :info : [ +0.000405] hub 2-1.8.1:1.0: USB hub found
kern :info : [ +0.000330] hub 2-1.8.1:1.0: 3 ports detected
kern :info : [ +0.072763] usb 3-1.7: New USB device found, idVendor=05ac, idProduct=9227, bcdDevice= 1.38
kern :info : [ +0.000007] usb 3-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 3-1.7: Product: Apple Thunderbolt Display
kern :info : [ +0.000002] usb 3-1.7: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 3-1.7: SerialNumber: 17020545
kern :info : [ +0.000378] usb 2-1.8.2: new full-speed USB device number 5 using ehci-pci
kern :info : [ +0.002650] usb 4-1.7: New USB device found, idVendor=05ac, idProduct=9227, bcdDevice= 1.38
kern :info : [ +0.000007] usb 4-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
kern :info : [ +0.000003] usb 4-1.7: Product: Apple Thunderbolt Display
kern :info : [ +0.000002] usb 4-1.7: Manufacturer: Apple Inc.
kern :info : [ +0.000002] usb 4-1.7: SerialNumber: 16100E97
kern :info : [ +0.101252] usb 2-1.8.2: New USB device found, idVendor=05ac, idProduct=0262, bcdDevice= 2.22
kern :info : [ +0.000007] usb 2-1.8.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern :info : [ +0.000003] usb 2-1.8.2: Product: Apple Internal Keyboard / Trackpad
kern :info : [ +0.000002] usb 2-1.8.2: Manufacturer: Apple Inc.
kern :info : [ +0.102803] usb 2-1.8.1.1: new full-speed USB device number 6 using ehci-pci
kern :info : [ +0.099555] usb 2-1.8.1.1: New USB device found, idVendor=05ac, idProduct=820a, bcdDevice= 1.00
kern :info : [ +0.000007] usb 2-1.8.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.073770] usb 2-1.8.1.2: new full-speed USB device number 7 using ehci-pci
kern :info : [ +0.099318] usb 2-1.8.1.2: New USB device found, idVendor=05ac, idProduct=820b, bcdDevice= 1.00
kern :info : [ +0.000006] usb 2-1.8.1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
kern :info : [ +0.074015] usb 2-1.8.1.3: new full-speed USB device number 8 using ehci-pci
kern :info : [ +0.100476] usb 2-1.8.1.3: New USB device found, idVendor=05ac, idProduct=8286, bcdDevice= 1.56
kern :info : [ +0.000006] usb 2-1.8.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern :info : [ +0.000003] usb 2-1.8.1.3: Product: Bluetooth USB Host Controller
kern :info : [ +0.000002] usb 2-1.8.1.3: Manufacturer: Apple Inc.
kern :info : [ +3.827086] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
kern :info : [ +0.001133] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kern :info : [ +0.000729] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kern :info : [ +0.000310] ata1.00: configured for UDMA/133
kern :notice: [ +0.010477] scsi 0:0:0:0: Direct-Access ATA Aura Pro S MB258 6ANR PQ: 0 ANSI: 5
kern :notice: [ +0.000464] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
kern :notice: [ +0.000014] sd 0:0:0:0: [sda] Write Protect is off
kern :debug : [ +0.000002] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
kern :notice: [ +0.000018] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
kern :info : [ +0.010628] sda: sda1 sda2 sda3 sda4
kern :notice: [ +0.000681] sd 0:0:0:0: [sda] Attached SCSI disk
kern :info : [ +0.001437] Freeing unused decrypted memory: 2036K
kern :info : [ +0.000618] Freeing unused kernel image (initmem) memory: 1720K
kern :info : [ +0.032620] Write protecting the kernel read-only data: 22528k
kern :info : [ +0.001102] Freeing unused kernel image (text/rodata gap) memory: 2036K
kern :info : [ +0.000643] Freeing unused kernel image (rodata/data gap) memory: 1312K
kern :info : [ +0.091059] x86/mm: Checked W+X mappings: passed, no W+X pages found.
kern :info : [ +0.000004] rodata_test: all tests were successful
kern :info : [ +0.000002] x86/mm: Checking user space page tables
kern :info : [ +0.042676] x86/mm: Checked W+X mappings: passed, no W+X pages found.
kern :info : [ +0.000006] Run /init as init process
kern :debug : [ +0.000001] with arguments:
kern :debug : [ +0.000001] /init
kern :debug : [ +0.000001] splash
kern :debug : [ +0.000000] with environment:
kern :debug : [ +0.000001] HOME=/
kern :debug : [ +0.000000] TERM=linux
kern :debug : [ +0.000001] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
kern :warn : [ +0.540193] xhci_hcd 0000:00:14.0: can’t derive routing for PCI INT A
kern :warn : [ +0.000003] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
kern :info : [ +0.000032] xhci_hcd 0000:00:14.0: xHCI Host Controller
kern :info : [ +0.000007] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 9
kern :info : [ +0.001076] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x000000000000b930
kern :info : [ +0.000009] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
kern :info : [ +0.000163] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
kern :info : [ +0.000002] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb9: Product: xHCI Host Controller
kern :info : [ +0.000002] usb usb9: Manufacturer: Linux 5.10.7-3-MANJARO xhci-hcd
kern :info : [ +0.000001] usb usb9: SerialNumber: 0000:00:14.0
kern :info : [ +0.000173] hub 9-0:1.0: USB hub found
kern :info : [ +0.000015] hub 9-0:1.0: 4 ports detected
kern :info : [ +0.000249] xhci_hcd 0000:00:14.0: xHCI Host Controller
kern :info : [ +0.000003] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 10
kern :info : [ +0.000002] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
kern :info : [ +0.000044] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
kern :info : [ +0.000002] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
kern :info : [ +0.000001] usb usb10: Product: xHCI Host Controller
kern :info : [ +0.000001] usb usb10: Manufacturer: Linux 5.10.7-3-MANJARO xhci-hcd
kern :info : [ +0.000001] usb usb10: SerialNumber: 0000:00:14.0
kern :info : [ +0.000102] hub 10-0:1.0: USB hub found
kern :info : [ +0.000140] hub 10-0:1.0: 4 ports detected
kern :info : [ +0.004902] input: Apple Inc. Display Audio as /devices/pci0000:00/0000:00:01.1/0000:05:00.0/0000:06:03.0/0000:08:00.0/0000:09:00.0/0000:0a:00.0/0000:0b:03.0/0000:0c:00.2/usb3/3-1/3-1.4/3-1.4:1.3/0003:05AC:1107.0001/input/input4
kern :info : [ +0.000067] hid-generic 0003:05AC:1107.0001: input,hidraw0: USB HID v1.11 Device [Apple Inc. Display Audio] on usb-0000:0c:00.2-1.4/input3
kern :info : [ +0.000934] sdhci: Secure Digital Host Controller Interface driver
kern :info : [ +0.000002] sdhci: Copyright(c) Pierre Ossman
kern :info : [ +0.002787] sdhci-pci 0000:03:00.1: SDHCI controller found [14e4:16bc] (rev 10)
kern :info : [ +0.000560] mmc0: SDHCI controller on PCI [0000:03:00.1] using ADMA 64-bit
kern :info : [ +0.006419] input: Apple Inc. Display Audio as /devices/pci0000:00/0000:00:01.1/0000:05:00.0/0000:06:04.0/0000:39:00.0/0000:3a:00.0/0000:3b:00.0/0000:3c:03.0/0000:3d:00.2/usb4/4-1/4-1.4/4-1.4:1.3/0003:05AC:1107.0002/input/input5
kern :info : [ +0.000084] hid-generic 0003:05AC:1107.0002: input,hidraw1: USB HID v1.11 Device [Apple Inc. Display Audio] on usb-0000:3d:00.2-1.4/input3
kern :info : [ +0.001543] hid-generic 0003:05AC:9227.0003: hiddev96,hidraw2: USB HID v1.11 Device [Apple Inc. Apple Thunderbolt Display] on usb-0000:0c:00.2-1.7/input0
kern :info : [ +0.001491] hid-generic 0003:05AC:9227.0004: hiddev97,hidraw3: USB HID v1.11 Device [Apple Inc. Apple Thunderbolt Display] on usb-0000:3d:00.2-1.7/input0
kern :info : [ +0.005743] input: HID 05ac:820a as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.1/2-1.8.1.1/2-1.8.1.1:1.0/0003:05AC:820A.0007/input/input6
kern :notice: [ +0.027801] firewire_ohci 0000:0e:00.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x0, physUB
kern :info : [ +0.026776] hid-generic 0003:05AC:820A.0007: input,hidraw4: USB HID v1.11 Keyboard [HID 05ac:820a] on usb-0000:00:1d.0-1.8.1.1/input0
kern :info : [ +0.001104] input: HID 05ac:820b as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.1/2-1.8.1.2/2-1.8.1.2:1.0/0003:05AC:820B.0008/input/input7
kern :info : [ +0.000151] hid-generic 0003:05AC:820B.0008: input,hidraw5: USB HID v1.11 Mouse [HID 05ac:820b] on usb-0000:00:1d.0-1.8.1.2/input0
kern :info : [ +0.000044] usbcore: registered new interface driver usbhid
kern :info : [ +0.000001] usbhid: USB HID core driver
kern :info : [ +0.002359] input: Apple Inc. Apple Internal Keyboard / Trackpad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.2/2-1.8.2:1.0/0003:05AC:0262.0005/input/input8
kern :notice: [ +0.026312] firewire_ohci 0000:3f:00.0: added OHCI v1.10 device as card 1, 8 IR + 8 IT contexts, quirks 0x0, physUB
kern :info : [ +0.030214] apple 0003:05AC:0262.0005: input,hidraw6: USB HID v1.11 Keyboard [Apple Inc. Apple Internal Keyboard / Trackpad] on usb-0000:00:1d.0-1.8.2/input0
kern :info : [ +0.000193] apple 0003:05AC:0262.0006: hidraw7: USB HID v1.11 Device [Apple Inc. Apple Internal Keyboard / Trackpad] on usb-0000:00:1d.0-1.8.2/input1
kern :info : [ +0.070896] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
kern :info : [ +0.121840] usb 9-1: new full-speed USB device number 2 using xhci_hcd
daemon:info : [ +0.068843] systemd[1]: systemd 247.2-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
daemon:info : [ +0.014797] systemd[1]: Detected architecture x86-64.
daemon:info : [ +0.041744] systemd[1]: Set hostname to .
kern :info : [ +0.017486] usb 9-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
kern :info : [ +0.000006] usb 9-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
kern :info : [ +0.000003] usb 9-1: Product: USB Receiver
kern :info : [ +0.000003] usb 9-1: Manufacturer: Logitech
kern :info : [ +0.002941] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.0/0003:046D:C52B.0009/input/input9
kern :info : [ +0.054449] hid-generic 0003:046D:C52B.0009: input,hidraw8: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-1/input0
kern :info : [ +0.002579] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.1/0003:046D:C52B.000A/input/input10
kern :info : [ +0.000166] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.1/0003:046D:C52B.000A/input/input11
kern :notice: [ +0.040389] firewire_core 0000:0e:00.0: created device fw0: GUID 000a270200501872, S800
kern :notice: [ +0.000011] firewire_core 0000:0e:00.0: phy config: new root=ffc0, gap_count=63
kern :info : [ +0.013350] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.1/0003:046D:C52B.000A/input/input12
kern :info : [ +0.000161] hid-generic 0003:046D:C52B.000A: input,hiddev98,hidraw9: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-1/input1
kern :info : [ +0.001915] hid-generic 0003:046D:C52B.000B: hiddev99,hidraw10: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-1/input2
kern :notice: [ +0.038027] firewire_core 0000:3f:00.0: created device fw1: GUID 000a27020043856c, S800
kern :notice: [ +0.000020] firewire_core 0000:3f:00.0: phy config: new root=ffc0, gap_count=63
daemon:warn : [ +0.169573] systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
daemon:info : [ +0.043794] systemd[1]: Queued start job for default target Graphical Interface.
daemon:info : [ +0.009496] systemd[1]: Created slice system-getty.slice.
daemon:info : [ +0.000265] systemd[1]: Created slice system-modprobe.slice.
daemon:info : [ +0.000207] systemd[1]: Created slice system-systemd\x2dfsck.slice.
daemon:info : [ +0.000212] systemd[1]: Created slice User and Session Slice.
daemon:info : [ +0.000049] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
daemon:info : [ +0.000117] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
daemon:info : [ +0.000028] systemd[1]: Reached target Login Prompts.
daemon:info : [ +0.000017] systemd[1]: Reached target Remote File Systems.
daemon:info : [ +0.000007] systemd[1]: Reached target Slices.
daemon:info : [ +0.000062] systemd[1]: Listening on Device-mapper event daemon FIFOs.
daemon:info : [ +0.000214] systemd[1]: Listening on LVM2 metadata daemon socket.
daemon:info : [ +0.000318] systemd[1]: Listening on LVM2 poll daemon socket.
daemon:info : [ +0.000872] systemd[1]: Listening on Process Core Dump Socket.
daemon:info : [ +0.000120] systemd[1]: Listening on Journal Audit Socket.
daemon:info : [ +0.000074] systemd[1]: Listening on Journal Socket (/dev/log).
daemon:info : [ +0.000088] systemd[1]: Listening on Journal Socket.
daemon:info : [ +0.001415] systemd[1]: Listening on udev Control Socket.
daemon:info : [ +0.000079] systemd[1]: Listening on udev Kernel Socket.
daemon:info : [ +0.000662] systemd[1]: Mounting Huge Pages File System…
daemon:info : [ +0.000728] systemd[1]: Mounting POSIX Message Queue File System…
daemon:info : [ +0.000713] systemd[1]: Mounting Kernel Debug File System…
daemon:info : [ +0.000704] systemd[1]: Mounting Kernel Trace File System…
daemon:info : [ +0.000929] systemd[1]: Starting Load AppArmor profiles…
daemon:info : [ +0.000760] systemd[1]: Starting Create list of static device nodes for the current kernel…
daemon:info : [ +0.000663] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
daemon:info : [ +0.000705] systemd[1]: Starting Load Kernel Module configfs…
daemon:info : [ +0.000804] systemd[1]: Starting Load Kernel Module drm…
daemon:info : [ +0.000707] systemd[1]: Starting Load Kernel Module fuse…
daemon:info : [ +0.002578] systemd[1]: Starting Set Up Additional Binary Formats…
daemon:info : [ +0.000634] systemd[1]: Starting File System Check on Root Device…
daemon:info : [ +0.001330] systemd[1]: Starting Journal Service…
daemon:info : [ +0.001359] systemd[1]: Starting Load Kernel Modules…
daemon:info : [ +0.000083] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
daemon:info : [ +0.001037] systemd[1]: Starting Coldplug All udev Devices…
daemon:info : [ +0.001011] systemd[1]: Starting Setup Virtual Console…
kern :info : [ +0.001730] Linux agpgart interface v0.103
daemon:info : [ +0.000531] systemd[1]: Mounted Huge Pages File System.
daemon:info : [ +0.000136] systemd[1]: Mounted POSIX Message Queue File System.
daemon:info : [ +0.000117] systemd[1]: Mounted Kernel Debug File System.
daemon:info : [ +0.000118] systemd[1]: Mounted Kernel Trace File System.
daemon:info : [ +0.000539] systemd[1]: Finished Create list of static device nodes for the current kernel.
daemon:info : [ +0.000316] systemd[1]: modprobe@configfs.service: Succeeded.
daemon:info : [ +0.000392] systemd[1]: Finished Load Kernel Module configfs.
daemon:info : [ +0.000151] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 284 (systemd-binfmt)
daemon:info : [ +0.001012] systemd[1]: Mounting Arbitrary Executable File Formats File System…
daemon:info : [ +0.001238] systemd[1]: Mounting Kernel Configuration File System…
daemon:info : [ +0.002451] systemd[1]: Mounted Kernel Configuration File System.
daemon:info : [ +0.001001] systemd[1]: Mounted Arbitrary Executable File Formats File System.
kern :info : [ +0.000768] fuse: init (API version 7.32)
daemon:info : [ +0.000579] systemd[1]: modprobe@fuse.service: Succeeded.
daemon:info : [ +0.000299] systemd[1]: Finished Load Kernel Module fuse.
daemon:info : [ +0.000405] systemd[1]: Finished Set Up Additional Binary Formats.
daemon:info : [ +0.000784] systemd[1]: Mounting FUSE Control File System…
kern :notice: [ +0.000987] random: lvm: uninitialized urandom read (4 bytes read)
daemon:info : [ +0.000793] systemd[1]: Mounted FUSE Control File System.
kern :notice: [ +0.004668] sd 0:0:0:0: Attached scsi generic sg0 type 0
daemon:info : [ +0.007880] systemd[1]: Finished Load Kernel Modules.
kern :notice: [ +0.000046] audit: type=1130 audit(1612820039.654:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-modules-load comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.000825] systemd[1]: Starting Apply Kernel Variables…
daemon:info : [ +0.005420] systemd[1]: modprobe@drm.service: Succeeded.
daemon:info : [ +0.000731] systemd[1]: Finished Load Kernel Module drm.
kern :notice: [ +0.000089] audit: type=1130 audit(1612820039.664:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=modprobe@drm comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.000045] audit: type=1131 audit(1612820039.664:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=modprobe@drm comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.002703] systemd[1]: Finished File System Check on Root Device.
kern :notice: [ +0.000041] audit: type=1130 audit(1612820039.664:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-fsck-root comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.000601] systemd[1]: Finished Apply Kernel Variables.
kern :notice: [ +0.000039] audit: type=1130 audit(1612820039.667:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-sysctl comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.001097] systemd[1]: Starting Remount Root and Kernel File Systems…
daemon:info : [ +0.006335] systemd[1]: Starting CLI Netfilter Manager…
kern :info : [ +0.001458] EXT4-fs (sda4): re-mounted. Opts: (null)
daemon:info : [ +0.001596] systemd[1]: Finished Remount Root and Kernel File Systems.
kern :notice: [ +0.000065] audit: type=1130 audit(1612820039.677:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-remount-fs comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.000143] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
daemon:info : [ +0.008152] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
daemon:info : [ +0.002807] systemd[1]: Starting Load/Save Random Seed…
daemon:info : [ +0.000079] systemd[1]: Condition check resulted in Create System Users being skipped.
daemon:info : [ +0.000915] systemd[1]: Starting Create Static Device Nodes in /dev…
daemon:info : [ +0.006552] systemd[1]: Finished Setup Virtual Console.
kern :notice: [ +0.000052] audit: type=1130 audit(1612820039.694:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-vconsole-setup comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.011790] systemd[1]: Finished CLI Netfilter Manager.
kern :notice: [ +0.000047] audit: type=1130 audit(1612820039.707:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=ufw comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
daemon:info : [ +0.002531] systemd[1]: Finished Create Static Device Nodes in /dev.
kern :notice: [ +0.000035] audit: type=1130 audit(1612820039.711:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-tmpfiles-setup-dev comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.001015] audit: type=1334 audit(1612820039.711:11): prog-id=5 op=LOAD
daemon:info : [ +0.000526] systemd[1]: Starting Rule-based Manager for Device Events and Files…
daemon:info : [ +0.037581] systemd[1]: Finished Coldplug All udev Devices.
daemon:info : [ +0.053185] systemd[1]: Started Journal Service.
kern :info : [ +0.134696] apple_gmux: Found gmux version 3.2.19 [indexed]
kern :info : [ +0.019499] smbus_hc ACPI0001:00: SBS HC: offset = 0x20, query_bit = 0x10
kern :notice: [ +0.036296] random: mktemp: uninitialized urandom read (6 bytes read)
kern :notice: [ +0.003236] random: mktemp: uninitialized urandom read (6 bytes read)
kern :info : [ +0.113357] bcma-pci-bridge 0000:04:00.0: bus0: Found chip with id 0x4331, rev 0x02 and package 0x09
kern :info : [ +0.000034] bcma-pci-bridge 0000:04:00.0: bus0: Core 0 found: ChipCommon (manuf 0x4BF, id 0x800, rev 0x25, class 0x0)
kern :info : [ +0.000026] bcma-pci-bridge 0000:04:00.0: bus0: Core 1 found: IEEE 802.11 (manuf 0x4BF, id 0x812, rev 0x1D, class 0x0)
kern :info : [ +0.000053] bcma-pci-bridge 0000:04:00.0: bus0: Core 2 found: PCIe (manuf 0x4BF, id 0x820, rev 0x13, class 0x0)
kern :warn : [ +0.003864] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
kern :info : [ +0.000007] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
kern :warn : [ +0.000003] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
kern :info : [ +0.000005] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
kern :warn : [ +0.000001] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
kern :info : [ +0.000004] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
kern :warn : [ +0.000001] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
kern :warn : [ +0.000000] lpc_ich: Resource conflict(s) found affecting gpio_ich
kern :info : [ +0.003762] input: PC Speaker as /devices/platform/pcspkr/input/input14
kern :info : [ +0.007919] i801_smbus 0000:00:1f.3: enabling device (0000 → 0003)
kern :info : [ +0.000184] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
kern :info : [ +0.000268] i2c i2c-0: 2/2 memory slots populated (from DMI)
kern :info : [ +0.047534] ACPI: Smart Battery System [SBS0]: Battery Slot [BAT0] (battery present)
kern :info : [ +0.007340] tg3 0000:0d:00.0 eth0: Tigon3 [partno(BCM957761) rev 57785100] (PCI Express) MAC address a8:20:66:4a:1b:dd
kern :info : [ +0.000005] tg3 0000:0d:00.0 eth0: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
kern :info : [ +0.000002] tg3 0000:0d:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
kern :info : [ +0.000001] tg3 0000:0d:00.0 eth0: dma_rwctrl[00000001] dma_mask[64-bit]
kern :info : [ +0.002603] bcma-pci-bridge 0000:04:00.0: bus0: Bus registered
kern :info : [ +0.003748] Adding 15612924k swap on /dev/sda3. Priority:-2 extents:1 across:15612924k SSFS
kern :info : [ +0.111540] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
kern :info : [ +0.000003] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
kern :info : [ +0.000001] RAPL PMU: hw unit of domain package 2^-16 Joules
kern :info : [ +0.000002] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
kern :info : [ +0.030357] tg3 0000:3e:00.0 eth1: Tigon3 [partno(BCM957761) rev 57785100] (PCI Express) MAC address 40:6c:8f:19:32:e7
kern :info : [ +0.000004] tg3 0000:3e:00.0 eth1: attached PHY is 57765 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[1])
kern :info : [ +0.000002] tg3 0000:3e:00.0 eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
kern :info : [ +0.000002] tg3 0000:3e:00.0 eth1: dma_rwctrl[00000001] dma_mask[64-bit]
kern :info : [ +0.041010] loop: module loaded
kern :info : [ +0.015104] cryptd: max_cpu_qlen set to 1000
kern :info : [ +0.019361] AVX version of gcm_enc/dec engaged.
kern :info : [ +0.000003] AES CTR mode by8 optimization enabled
kern :info : [ +0.054665] tg3 0000:0d:00.0 enp13s0: renamed from eth0
kern :info : [ +0.003308] applesmc: key=493 fan=2 temp=44 index=43 acc=0 lux=2 kbd=1
kern :warn : [ +0.000204] applesmc applesmc.768: hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
kern :info : [ +0.022635] iTCO_vendor_support: vendor-support=0
kern :info : [ +0.034301] tg3 0000:3e:00.0 enp62s0: renamed from eth1
kern :info : [ +0.010277] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
kern :info : [ +0.000054] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
kern :debug : [ +0.000109] checking generic (90020000 1680000) vs hw (c1400000 400000)
kern :debug : [ +0.000002] checking generic (90020000 1680000) vs hw (b0000000 10000000)
kern :info : [ +0.051786] i915 0000:00:02.0: BAR 6: can’t assign [??? 0x00000000 flags 0x20000000] (bogus alignment)
kern :info : [ +0.000004] i915 0000:00:02.0: [drm] Failed to find VBIOS tables (VBT)
kern :info : [ +0.000394] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
kern :warn : [ +0.066310] ACPI Warning: _SB.PCI0.IGPU.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
kern :info : [ +0.000029] ACPI: _SB.PCI0.IGPU: failed to evaluate _DSM
kern :warn : [ +0.000031] ACPI Warning: _SB.PCI0.P0P2.GFX0.DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
kern :info : [ +0.000024] ACPI: _SB.PCI0.P0P2.GFX0: failed to evaluate _DSM
kern :info : [ +0.000055] nouveau 0000:01:00.0: enabling device (0006 → 0007)
kern :debug : [ +0.000175] checking generic (90020000 1680000) vs hw (c0000000 1000000)
kern :debug : [ +0.000002] checking generic (90020000 1680000) vs hw (90000000 10000000)
kern :info : [ +0.000001] fb0: switching to nouveaufb from EFI VGA
kern :info : [ +0.000107] nouveau 0000:01:00.0: vgaarb: deactivate vga console
kern :info : [ +0.000076] nouveau 0000:01:00.0: NVIDIA GK107 (0e7150a2)
kern :info : [ +0.007450] snd_hda_intel 0000:00:1b.0: enabling device (0000 → 0002)
kern :info : [ +0.003706] snd_hda_intel 0000:01:00.1: enabling device (0000 → 0002)
kern :info : [ +0.000064] snd_hda_intel 0000:01:00.1: Disabling MSI
kern :info : [ +0.000006] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
kern :info : [ +0.007973] i915 0000:00:02.0: [drm] failed to retrieve link info, disabling eDP
kern :info : [ +0.006418] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
kern :warn : [ +0.000241] [Firmware Bug]: ACPI(GFX0) defines _DOD but not _DOS
kern :info : [ +0.000044] ACPI: Video Device [GFX0] (multi-head: yes rom: yes post: no)
kern :info : [ +0.000173] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/LNXVIDEO:00/input/input15
kern :info : [ +0.000757] ACPI: Video Device [IGPU] (multi-head: yes rom: no post: no)
kern :info : [ +0.000138] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input16
kern :info : [ +0.000273] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
kern :info : [ +0.006812] nouveau 0000:01:00.0: bios: version 80.07.26.04.01
kern :info : [ +0.011844] nouveau 0000:01:00.0: fb: 1024 MiB GDDR5
kern :info : [ +0.015165] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
kern :info : [ +0.000056] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
kern :info : [ +0.000047] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
kern :info : [ +0.000044] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
kern :info : [ +0.000051] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
kern :info : [ +0.000044] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input22
kern :notice: [Feb 8 15:34] cfg80211: Loading compiled-in X.509 certificates for regulatory database
kern :notice: [ +0.011000] random: crng init done
kern :notice: [ +0.000003] random: 7 urandom warning(s) missed due to ratelimiting
kern :notice: [ +0.029725] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
kern :info : [ +0.013496] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
kern :info : [ +0.003139] vga_switcheroo: enabled
kern :info : [ +0.000163] [TTM] Zone kernel: Available graphics memory: 8149380 KiB
kern :info : [ +0.000002] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
kern :info : [ +0.000001] [TTM] Initializing pool allocator
kern :info : [ +0.000006] [TTM] Initializing DMA pool allocator
kern :info : [ +0.000036] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
kern :info : [ +0.000005] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB version 4.0
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB outp 00: 048101b6 0f230010
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB outp 01: 018212d6 0f220020
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB outp 02: 01021212 00020020
kern :info : [ +0.000001] nouveau 0000:01:00.0: DRM: DCB outp 03: 088324c6 0f220010
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB outp 04: 08032402 00020010
kern :info : [ +0.000001] nouveau 0000:01:00.0: DRM: DCB outp 05: 02843862 00020010
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB conn 00: 00020047
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB conn 01: 02208146
kern :info : [ +0.000001] nouveau 0000:01:00.0: DRM: DCB conn 02: 01104246
kern :info : [ +0.000002] nouveau 0000:01:00.0: DRM: DCB conn 03: 00410361
kern :info : [ +0.002819] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
kern :info : [ +0.061874] squashfs: version 4.0 (2009/01/31) Phillip Lougher
kern :info : [ +0.034749] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
kern :info : [ +0.028215] snd_hda_codec_cirrus hdaudioC0D0: autoconfig for CS4206: line_outs=2 (0xb/0xa/0x0/0x0/0x0) type:speaker
kern :info : [ +0.000004] snd_hda_codec_cirrus hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
kern :info : [ +0.000002] snd_hda_codec_cirrus hdaudioC0D0: hp_outs=1 (0x9/0x0/0x0/0x0/0x0)
kern :info : [ +0.000002] snd_hda_codec_cirrus hdaudioC0D0: mono: mono_out=0x0
kern :info : [ +0.000001] snd_hda_codec_cirrus hdaudioC0D0: dig-out=0x10/0x0
kern :info : [ +0.000002] snd_hda_codec_cirrus hdaudioC0D0: inputs:
kern :info : [ +0.000002] snd_hda_codec_cirrus hdaudioC0D0: Mic=0xe
kern :info : [ +0.000834] intel_rapl_common: Found RAPL domain package
kern :info : [ +0.000002] intel_rapl_common: Found RAPL domain core
kern :info : [ +0.000001] intel_rapl_common: Found RAPL domain uncore
kern :info : [ +0.007280] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
kern :info : [ +0.014744] thunderbolt 0-1: new device found, vendor=0x1 device=0x8002
kern :info : [ +0.000002] thunderbolt 0-1: Apple, Inc. Thunderbolt Display
kern :info : [ +0.019797] b43-phy0: Broadcom 4331 WLAN found (core revision 29)
kern :info : [ +0.000412] b43-phy0: Found PHY: Analog 9, Type 7 (HT), Revision 1
kern :info : [ +0.000012] b43-phy0: Found Radio: Manuf 0x17F, ID 0x2059, Revision 0, Version 1
kern :warn : [ +0.000001] b43-phy0 warning: 5 GHz band is unsupported on this PHY
kern :info : [ +0.000526] Broadcom 43xx driver loaded [ Features: PNLS ]
kern :debug : [ +0.001533] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
kern :info : [ +0.005080] b43 bcma0:1 wlp4s0b1: renamed from wlan0
kern :info : [ +0.155800] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
kern :info : [ +0.119308] nouveau 0000:01:00.0: DRM: allocated 2880x1800 fb: 0xa0000, bo 00000000bc7385e3
kern :info : [ +0.000057] fbcon: nouveaudrmfb (fb0) is primary device
kern :info : [ +0.000001] fbcon: Deferring console take-over
kern :info : [ +0.000003] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
kern :info : [ +0.033434] nouveau 0000:01:00.0: DRM: Apple GMUX detected: not registering Nouveau backlight interface
kern :info : [ +0.000153] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
kern :info : [ +0.071531] usbcore: registered new device driver apple-mfi-fastcharge
kern :info : [ +0.180125] thunderbolt 0-3: new device found, vendor=0x1 device=0x8002
kern :info : [ +0.000003] thunderbolt 0-3: Apple, Inc. Thunderbolt Display
kern :info : [ +0.078327] logitech-djreceiver 0003:046D:C52B.000B: hiddev98,hidraw8: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:14.0-1/input2
kern :info : [ +0.118622] input: Logitech Wireless Device PID:400f Keyboard as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:400F.000C/input/input24
kern :info : [ +0.000262] input: Logitech Wireless Device PID:400f Consumer Control as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:400F.000C/input/input25
kern :info : [ +0.000065] hid-generic 0003:046D:400F.000C: input,hidraw9: USB HID v1.11 Keyboard [Logitech Wireless Device PID:400f] on usb-0000:00:14.0-1/input2:1
kern :info : [ +0.001622] input: Logitech Wireless Device PID:4082 Keyboard as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000D/input/input29
kern :info : [ +0.000229] input: Logitech Wireless Device PID:4082 Mouse as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000D/input/input30
kern :info : [ +0.000064] hid-generic 0003:046D:4082.000D: input,hidraw10: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4082] on usb-0000:00:14.0-1/input2:2
kern :info : [ +0.002062] input: Logitech Wireless Device PID:4082 Keyboard as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000E/input/input34
kern :info : [ +0.000644] input: Logitech Wireless Device PID:4082 Mouse as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000E/input/input35
kern :info : [ +0.000059] hid-generic 0003:046D:4082.000E: input,hidraw11: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4082] on usb-0000:00:14.0-1/input2:3
kern :info : [ +0.001031] mousedev: PS/2 mouse device common for all mice
kern :info : [ +0.208477] mc: Linux media interface: v0.10
kern :info : [ +0.025320] input: Logitech K750 as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:400F.000C/input/input39
kern :info : [ +0.000219] logitech-hidpp-device 0003:046D:400F.000C: input,hidraw9: USB HID v1.11 Keyboard [Logitech K750] on usb-0000:00:14.0-1/input2:1
kern :info : [ +0.001592] videodev: Linux video capture interface: v2.00
kern :info : [ +0.024724] uvcvideo: Found UVC 1.00 device FaceTime HD Camera (Built-in) (05ac:8510)
kern :info : [ +0.043922] input: FaceTime HD Camera (Built-in): as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/input/input40
kern :info : [ +0.080003] uvcvideo: Found UVC 1.00 device FaceTime HD Camera (Display) (05ac:1112)
kern :info : [ +0.003551] input: Logitech MX Master 3 as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000D/input/input41
kern :info : [ +0.000591] logitech-hidpp-device 0003:046D:4082.000D: input,hidraw10: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:00:14.0-1/input2:2
kern :info : [ +0.020432] input: FaceTime HD Camera (Display): F as /devices/pci0000:00/0000:00:01.1/0000:05:00.0/0000:06:03.0/0000:08:00.0/0000:09:00.0/0000:0a:00.0/0000:0b:03.0/0000:0c:00.2/usb3/3-1/3-1.5/3-1.5:1.0/input/input42
kern :err : [ +0.008584] usb 3-1.4: 1:1: cannot get freq at ep 0x4
kern :err : [ +0.004033] usb 3-1.4: 1:2: cannot get freq at ep 0x4
kern :err : [ +0.005978] usb 3-1.4: 2:1: cannot get freq at ep 0x84
kern :warn : [ +0.032961] usb 3-1.4: Warning! Unlikely big volume range (=16384), cval->res is probably wrong.
kern :warn : [ +0.000003] usb 3-1.4: [2] FU [PCM Playback Volume] ch = 2, val = -16384/0/1
kern :warn : [ +0.031902] usb 3-1.4: Warning! Unlikely big volume range (=15872), cval->res is probably wrong.
kern :warn : [ +0.000007] usb 3-1.4: [5] FU [Mic Capture Volume] ch = 1, val = -11264/4608/1
kern :info : [ +0.081433] input: Logitech MX Master 3 as /devices/pci0000:00/0000:00:14.0/usb9/9-1/9-1:1.2/0003:046D:C52B.000B/0003:046D:4082.000E/input/input43
kern :info : [ +0.000322] uvcvideo: Found UVC 1.00 device FaceTime HD Camera (Display) (05ac:1112)
kern :info : [ +0.000120] logitech-hidpp-device 0003:046D:4082.000E: input,hidraw11: USB HID v1.11 Keyboard [Logitech MX Master 3] on usb-0000:00:14.0-1/input2:3
kern :info : [ +0.026686] input: FaceTime HD Camera (Display): F as /devices/pci0000:00/0000:00:01.1/0000:05:00.0/0000:06:04.0/0000:39:00.0/0000:3a:00.0/0000:3b:00.0/0000:3c:03.0/0000:3d:00.2/usb4/4-1/4-1.5/4-1.5:1.0/input/input44
kern :info : [ +0.000186] usbcore: registered new interface driver uvcvideo
kern :info : [ +0.000001] USB Video Class driver (1.1.1)
kern :err : [ +0.068090] usb 4-1.4: 1:1: cannot get freq at ep 0x4
kern :err : [ +0.004013] usb 4-1.4: 1:2: cannot get freq at ep 0x4
kern :err : [ +0.005077] usb 4-1.4: 2:1: cannot get freq at ep 0x84
kern :warn : [ +0.032973] usb 4-1.4: Warning! Unlikely big volume range (=16384), cval->res is probably wrong.
kern :warn : [ +0.000002] usb 4-1.4: [2] FU [PCM Playback Volume] ch = 2, val = -16384/0/1
kern :warn : [ +0.033001] usb 4-1.4: Warning! Unlikely big volume range (=15872), cval->res is probably wrong.
kern :warn : [ +0.000007] usb 4-1.4: [5] FU [Mic Capture Volume] ch = 1, val = -11264/4608/1
kern :info : [ +0.000691] usbcore: registered new interface driver snd-usb-audio
kern :info : [ +0.042577] input: bcm5974 as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.2/2-1.8.2:1.2/input/input45
kern :info : [ +0.000114] usbcore: registered new interface driver bcm5974
kern :info : [ +0.626708] Bluetooth: Core ver 2.22
kern :info : [ +0.000028] NET: Registered protocol family 31
kern :info : [ +0.000001] Bluetooth: HCI device and connection manager initialized
kern :info : [ +0.000003] Bluetooth: HCI socket layer initialized
kern :info : [ +0.000002] Bluetooth: L2CAP socket layer initialized
kern :info : [ +0.000012] Bluetooth: SCO socket layer initialized
kern :info : [ +0.015187] usbcore: registered new interface driver btusb
kern :info : [ +0.041020] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
kern :info : [ +0.000002] Bluetooth: BNEP filters: protocol multicast
kern :info : [ +0.000003] Bluetooth: BNEP socket layer initialized
kern :info : [ +0.021709] usb 2-1.8.1.1: USB disconnect, device number 6
kern :info : [ +0.047388] Bluetooth: hci0: BCM: chip id 63 build 1822
kern :info : [ +0.000988] Bluetooth: hci0: BCM: product 05ac:8286
kern :info : [ +0.001000] Bluetooth: hci0: BCM: features 0x07
kern :info : [ +0.016036] Bluetooth: hci0: manjaro
kern :info : [ +0.057120] NET: Registered protocol family 38
kern :info : [ +0.097116] usb 2-1.8.1.2: USB disconnect, device number 7
kern :warn : [ +1.328991] kauditd_printk_skb: 82 callbacks suppressed
kern :notice: [ +0.000002] audit: type=1130 audit(1612820044.774:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=accounts-daemon comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.040520] audit: type=1100 audit(1612820044.814:93): pid=1832 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:authentication grantors=pam_shells,pam_permit acct=“bryankarlan” exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success’
kern :notice: [ +0.002810] audit: type=1101 audit(1612820044.817:94): pid=1832 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“bryankarlan” exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success’
kern :notice: [ +0.001891] audit: type=1103 audit(1612820044.821:95): pid=1832 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:setcred grantors=pam_shells,pam_permit acct=“bryankarlan” exe="/usr/lib/gdm-session-worker" hostname=manjaro addr=? terminal=/dev/tty1 res=success’
kern :info : [ +0.008715] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
kern :notice: [ +0.002560] audit: type=1130 audit(1612820044.831:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=snapd comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.042332] audit: type=1006 audit(1612820044.874:97): pid=1832 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
kern :notice: [ +0.025913] audit: type=1130 audit(1612820044.901:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=user-runtime-dir@1000 comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.005909] audit: type=1101 audit(1612820044.907:99): pid=1843 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=“bryankarlan” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.000033] audit: type=1103 audit(1612820044.907:100): pid=1843 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=PAM:setcred grantors=? acct=“bryankarlan” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed’
kern :notice: [ +0.000054] audit: type=1006 audit(1612820044.907:101): pid=1843 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
kern :info : [ +0.286521] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
kern :info : [ +1.806761] tg3 0000:0d:00.0 enp13s0: Link is up at 1000 Mbps, full duplex
kern :info : [ +0.000006] tg3 0000:0d:00.0 enp13s0: Flow control is on for TX and on for RX
kern :info : [ +0.000001] tg3 0000:0d:00.0 enp13s0: EEE is disabled
kern :info : [ +0.099996] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
kern :info : [ +0.147224] IPv6: ADDRCONF(NETDEV_CHANGE): enp13s0: link becomes ready
kern :info : [ +1.497392] wlp4s0b1: authenticate with 20:f3:75:c4:c3:8d
kern :info : [ +0.052137] wlp4s0b1: send auth to 20:f3:75:c4:c3:8d (try 1/3)
kern :info : [ +0.001116] wlp4s0b1: authenticated
kern :info : [ +0.001983] wlp4s0b1: associate with 20:f3:75:c4:c3:8d (try 1/3)
kern :info : [ +0.203339] wlp4s0b1: associate with 20:f3:75:c4:c3:8d (try 2/3)
kern :info : [ +0.001811] wlp4s0b1: RX AssocResp from 20:f3:75:c4:c3:8d (capab=0x831 status=0 aid=1)
kern :info : [ +0.000242] wlp4s0b1: associated
kern :info : [ +0.111896] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0b1: link becomes ready
kern :info : [ +0.120125] Bluetooth: RFCOMM TTY layer initialized
kern :info : [ +0.000007] Bluetooth: RFCOMM socket layer initialized
kern :info : [ +0.000006] Bluetooth: RFCOMM ver 1.11
kern :debug : [ +0.521044] rfkill: input handler disabled
kern :warn : [ +0.042108] kauditd_printk_skb: 12 callbacks suppressed
kern :notice: [ +0.000002] audit: type=1334 audit(1612820049.801:114): prog-id=14 op=LOAD
kern :notice: [ +0.000024] audit: type=1334 audit(1612820049.801:115): prog-id=15 op=LOAD
kern :notice: [ +0.015674] audit: type=1130 audit(1612820049.814:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=upower comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.049766] audit: type=1130 audit(1612820049.864:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-timedated comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +1.066989] audit: type=1130 audit(1612820050.931:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=fprintd comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.002443] audit: type=1100 audit(1612820050.934:119): pid=2415 uid=1000 auid=1000 ses=2 subj==unconfined msg=‘op=PAM:authentication grantors=? acct=“bryankarlan” exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=failed’
kern :notice: [ +0.817141] audit: type=1334 audit(1612820051.751:120): prog-id=16 op=LOAD
kern :notice: [ +0.000035] audit: type=1334 audit(1612820051.751:121): prog-id=17 op=LOAD
kern :notice: [ +0.076357] audit: type=1130 audit(1612820051.827:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-localed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +1.922647] audit: type=1131 audit(1612820053.751:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +12.012119] audit: type=1130 audit(1612820065.764:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=plymouth-quit-wait comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.534304] audit: type=1130 audit(1612820066.297:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=tlp comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +13.419067] audit: type=1131 audit(1612820079.880:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-timedated comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.021869] audit: type=1334 audit(1612820079.903:127): prog-id=15 op=UNLOAD
kern :notice: [ +0.000012] audit: type=1334 audit(1612820079.903:128): prog-id=14 op=UNLOAD
kern :notice: [ +0.856206] audit: type=1131 audit(1612820080.768:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=fprintd comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +1.065694] audit: type=1131 audit(1612820081.848:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.176641] audit: type=1334 audit(1612820082.030:131): prog-id=10 op=UNLOAD
kern :notice: [ +0.000019] audit: type=1334 audit(1612820082.030:132): prog-id=9 op=UNLOAD
kern :info : [ +3.022409] logitech-hidpp-device 0003:046D:400F.000C: HID++ 2.0 device connected.
kern :info : [ +2.618743] logitech-hidpp-device 0003:046D:4082.000D: HID++ 4.5 device connected.
kern :notice: [ +12.889851] audit: type=1334 audit(1612820100.636:133): prog-id=18 op=LOAD
kern :notice: [ +0.000096] audit: type=1334 audit(1612820100.636:134): prog-id=19 op=LOAD
kern :notice: [ +0.068706] audit: type=1130 audit(1612820100.703:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :warn : [ +0.097484] L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and L1TF - L1 Terminal Fault — The Linux Kernel documentation for details.
kern :notice: [Feb 8 15:35] audit: type=1131 audit(1612820111.415:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-localed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.088031] audit: type=1334 audit(1612820111.505:137): prog-id=17 op=UNLOAD
kern :notice: [ +0.000006] audit: type=1334 audit(1612820111.505:138): prog-id=16 op=UNLOAD
kern :notice: [ +19.228612] audit: type=1131 audit(1612820130.736:139): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=systemd-hostnamed comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
kern :notice: [ +0.097136] audit: type=1334 audit(1612820130.836:140): prog-id=19 op=UNLOAD
