szsdk
January 6, 2023, 7:01am
#1
My bluetooth stops working after I upgrade the system and reboot yesterday. I tried with kernel 5.15 and 6.1. None of them works. Here is the the output of the dmesg
[ 2.509888] Bluetooth: Core ver 2.22
[ 2.509931] Bluetooth: HCI device and connection manager initialized
[ 2.509938] Bluetooth: HCI socket layer initialized
[ 2.509942] Bluetooth: L2CAP socket layer initialized
[ 2.509948] Bluetooth: SCO socket layer initialized
[ 2.658085] Bluetooth: HCI UART driver ver 2.3
[ 2.658087] Bluetooth: HCI UART protocol H4 registered
[ 2.658088] Bluetooth: HCI UART protocol BCSP registered
[ 2.658096] Bluetooth: HCI UART protocol LL registered
[ 2.658097] Bluetooth: HCI UART protocol ATH3K registered
[ 2.658100] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.658128] Bluetooth: HCI UART protocol Intel registered
[ 2.658144] Bluetooth: HCI UART protocol Broadcom registered
[ 2.658147] Bluetooth: HCI UART protocol QCA registered
[ 2.658147] Bluetooth: HCI UART protocol AG6XX registered
[ 2.658150] Bluetooth: HCI UART protocol Marvell registered
[ 4.109500] Bluetooth: hci0: setting up ROME/QCA6390
[ 4.227179] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.227181] Bluetooth: BNEP filters: protocol multicast
[ 4.227184] Bluetooth: BNEP socket layer initialized
[ 6.572640] Bluetooth: hci0: command 0xfc00 tx timeout
[ 14.462740] Bluetooth: hci0: Reading QCA version information failed (-110)
[ 14.462749] Bluetooth: hci0: Retry BT power ON:0
[ 16.809408] Bluetooth: hci0: command 0xfc00 tx timeout
[ 24.916086] Bluetooth: hci0: Reading QCA version information failed (-110)
[ 24.916097] Bluetooth: hci0: Retry BT power ON:1
[ 27.262583] Bluetooth: hci0: command 0xfc00 tx timeout
[ 30.319551] Bluetooth: hci0: Reading QCA version information failed (-110)
[ 30.319562] Bluetooth: hci0: Retry BT power ON:2
[ 30.653116] Bluetooth: hci0: QCA Product ID :0x00000010
[ 30.653121] Bluetooth: hci0: QCA SOC Version :0x400a0200
[ 30.653121] Bluetooth: hci0: QCA ROM Version :0x00000200
[ 30.653122] Bluetooth: hci0: QCA Patch Version:0x00003ac0
[ 30.653123] Bluetooth: hci0: QCA controller version 0x02000200
[ 30.653123] Bluetooth: hci0: QCA Downloading qca/htbtfw20.tlv
[ 30.657380] Bluetooth: hci0: QCA Failed to send TLV segment (-110)
[ 30.657401] Bluetooth: hci0: QCA Failed to download patch (-110)
[ 56.056121] Bluetooth: hci0: QCA collecting dump of size:458752
[ 57.670996] Bluetooth: hci0: QCA memdump Done, received 458752, total 458752
And this is the output of the inxi.
Kernel: 6.1.2-1-MANJARO arch: x86_64 bits: 64 Desktop: Qtile v: 0.22.1
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 13 9310 v: N/A
serial: <superuser required>
Mobo: Dell model: 0DMPXV v: A02 serial: <superuser required> UEFI: Dell
v: 3.1.0 date: 07/22/2021
ID-1: BAT0 charge: 37.9 Wh (100.0%) condition: 37.9/51.0 Wh (74.3%)
Info: quad core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 2734 min/max: 400/4800 cores: 1: 3000 2: 875 3: 3000
4: 3000 5: 3000 6: 3000 7: 3000 8: 3000
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
1: 1920x1080~60Hz 2: 1280x800
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
Sound API: ALSA v: k6.1.2-1-MANJARO running: yes
Sound Server-1: PulseAudio v: 16.1 running: yes
Device-1: Qualcomm QCA6390 Wireless Network Adapter driver: ath11k_pci
IF: wlp114s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
IF: enp0s13f0u1u4u1 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 195.81 GiB (20.5%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC711 NVMe 1TB size: 953.87 GiB
ID-1: / size: 919.03 GiB used: 97.47 GiB (10.6%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 483 MiB used: 304 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 45.0 C mobo: 37.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 222 Uptime: 7m Memory: 31.07 GiB used: 3.34 GiB (10.8%)
Shell: Zsh inxi: 3.3.24
Hi @szsdk , and welcome!
That doesn’t look like the complete, required inxi
output. Please provide the output of:
Hope you manage!
szsdk
January 6, 2023, 7:12am
#3
This is the output
Kernel: 6.1.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=2b6a9ed7-817b-4a02-a426-d13bb1be4027 rw quiet
udev.log_priority=3
Desktop: Qtile v: 0.22.1 vt: 2 dm: GDM v: 43.0 Distro: Manjaro Linux
base: Arch Linux
ID-1: BAT0 charge: 35.8 Wh (94.5%) condition: 37.9/51.0 Wh (74.3%) volts: 8.3
min: 7.6 model: BYD_0 DELL FP86V16 type: Li-poly serial: <filter>
status: not charging
RAM: total: 31.07 GiB used: 3.77 GiB (12.1%)
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2224 high: 3000 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 913 2: 936 3: 3000 4: 3000
5: 944 6: 3000 7: 3000 8: 3000 bogomips: 47936
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: DP-1,eDP-1 empty: DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
bus-ID: 3-6:3 chip-ID: 0bda:5517 class-ID: fe01 serial: <filter>
compositor: xcompmgr driver: X: loaded: modesetting unloaded: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3200x1080 s-dpi: 96 s-size: 846x285mm (33.31x11.22")
s-diag: 893mm (35.15")
Monitor-1: DP-1 pos: primary,left model: Dell S2721HSX serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: right model: Sharp 0x14fa built: 2020 res: 1280x800
dpi: 113 gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: 3840x2400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-3: PipeWire v: 0.3.63 running: no
Device-1: Qualcomm QCA6390 Wireless Network Adapter vendor: Rivet Networks
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 72:00.0 chip-ID: 17cb:1101 class-ID: 0280
bus-ID: 2-1.4.1:5 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41001131 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 934.78 GiB size: 919.03 GiB (98.32%)
used: 97.47 GiB (10.6%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 2b6a9ed7-817b-4a02-a426-d13bb1be4027
ID-2: /boot/efi raw-size: 484 MiB size: 483 MiB (99.80%)
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: B75D-2718
ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 500 GiB
used: 98.34 GiB (19.7%) fs: fuse source: ERR-102
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 18.14 GiB fs: ext4 label: N/A
uuid: a1ee8a98-3741-4eaa-8d27-500b5a4bfc4a
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Hub-4: 2-1.4:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Device-1: 2-1.4.1:5 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
Device-2: 2-1.4.4:4 info: Genesys Logic SD Card Reader and Writer
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:533c class-ID: ff00
Device-2: 3-6:3 info: Realtek Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-6: 3-8:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Device-1: 3-8.3:5 info: TG3 Poker II type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 0f39:0611 class-ID: 0300
Hub-7: 3-8.4:6 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-8.4.3:7 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 2109:0102 class-ID: 1100 serial: <filter>
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: 39.0 C
Processes: 226 Uptime: 21m wakeups: 6 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages:
pm: pacman pkgs: 1651 libs: 358 tools: gnome-software,pamac,yay Shell: Zsh
v: 5.9 running-in: wezterm-gui inxi: 3.3.24
It is interesting that no bluetooth data is found.
