Iv just brought a used Dell Optiplex 7050 after doing a lot of checking for a nice stable linux based “thin” client.
Problem is it will not shutdown. Even from a live stick. Windows works just fine.
It will just hang forever at the point where it is supposed to switch the system off. Can not access any terminals with Ctrl+Alt+F keys , F1 does nothing either.
I have tried :-
tried many BIOS setting, turned off all wake on lan and/or USB etc
also turned off virtulization.
tried apm=power_off acpi=force intel_iommu=off, there was also sugettion to remove “quite” and “wake” so i tried that too.
GRUB_CMDLINE_LINUX_DEFAULT=“udev.log_priority=3 apm=power_off acpi=force intel_iommu=off”
The BIOS is fully up to date ver 1.26.0
https://www.dell.com/support/home/en-uk/product-support/product/optiplex-7050-micro/drivers
Just looking at the last few lines of the journalctl, it looks to be ending linux as far as linux can see.
journalctl -b -1
Oct 20 22:08:11 greg-optiplex7050 systemd[1]: Shutting down.
Oct 20 22:08:11 greg-optiplex7050 systemd-shutdown[1]: Syncing filesystems and block devices.
Oct 20 22:08:11 greg-optiplex7050 systemd-shutdown[1]: Sending SIGTERM to remaining processes…
Oct 20 22:08:11 greg-optiplex7050 systemd-journald[224]: Received SIGTERM from PID 1 (systemd-shutdow).
Oct 20 22:08:11 greg-optiplex7050 systemd-journald[224]: Journal stopped
Im at a loss
inxi
❱inxi --admin --verbosity=7 --filter --no-host
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=885a2b3e-3404-4ba8-b0ab-9dcfcff35d84 rw udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop System: Dell product: OptiPlex 7050 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 055H3G v: A01 serial: <superuser required> UEFI: Dell
v: 1.26.0 date: 08/20/2023
System RAM: total: 16 GiB available: 15.49 GiB used: 3.28 GiB (21.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 875 high: 900 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 900 3: 900 4: 900
bogomips: 27208
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1
empty: DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:5912 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: DP-1 model-id: RTK 0x1d1a serial: <filter> built: 2015
res: 1920x1080 hz: 60 dpi: 305 gamma: 1.2 size: 160x90mm (6.3x3.54")
diag: 1168mm (46") ratio: 16:9 modes: max: 1024x768 min: 720x400
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:5912 memory: 15.13 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 1 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:5912 surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15e3 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0a2b
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 968.58 GiB used: 32.35 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV1T02
NVMe 1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: AADA4101
temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: JetFlash 16GB
size: 14.71 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: / raw-size: 852.87 GiB size: 838.41 GiB (98.30%)
used: 32.31 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 885a2b3e-3404-4ba8-b0ab-9dcfcff35d84
used: 34.2 MiB (35.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 9C53-43DC
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 02B25309B2530119
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 100.37 GiB fs: ntfs label: N/A
uuid: FAC45710C456CF0F
ID-4: /dev/sda1 maj-min: 8:1 size: 3.63 GiB fs: iso9660
ID-5: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: A19E-3AF4
Device-1: 1-3:2 info: Microsoft Wired Keyboard 600 (model 1576)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 045e:07f8 class-ID: 0300
Device-2: 1-7:3 info: Maxxter Wireless Receiver type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 50mA chip-ID: 248a:8514 class-ID: 0301
Device-3: 1-9:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
Device-1: 2-1:2 info: Transcend Information JetFlash type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 304mA chip-ID: 8564:1000 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 217 Uptime: 4m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1369 libs: 399 tools: pamac,yay pm: flatpak pkgs: 0 Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.30
