Until not long ago my dual Windows+Manjaro installation worked fine.
Since yesterday Windows boot fine from Grub but Manjaro boots to black screen from Grub.
I tried, based on these instructions i found in one of the internet sites, to reboot manually but it failed:
grub> set root=(hdX,X)
grub> linux /boot/vmlinuz-XXXXXXXXX root=/dev/sdXX
grub> initrd /boot/initrd.XXXXXXXXXXX
grub> boot
The error message i got was:
> בלוק ציטוט
mount: /new_root: no filesystem type specified
(i tried to add images or links but the this forum won’t allow)
Since i have very low understanding in Linux and cases like these i would like to see if someone can offer easy solution.
I have already created Live USB and i read something about chroot command but i’m not sure i understand everything.
> בלוק ציטוט
[manjaro@manjaro ~]$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: KDE Plasma 5.18.5 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: Z68 Pro3 serial: <filter>
BIOS: American Megatrends v: P1.60 date: 07/13/2011
Memory: RAM: total: 15.55 GiB used: 2.30 GiB (14.8%)
CPU: Topology: Quad Core model: Intel Core i7-2600K bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 8192 KiB bogomips: 54297
Speed: 1596 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1596 2: 1596
3: 1596 4: 1596 5: 1596 6: 1596 7: 1596 8: 1596
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx
vnmi vpid xsave xsaveopt xtopology xtpr
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASRock driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0122
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: PNY driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1c03
Display: x11 server: X.Org 1.20.8 driver: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 2560x1440~60Hz
OpenGL: renderer: NV136 v: 4.3 Mesa 20.0.7 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASRock driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Device-2: NVIDIA GP106 High Definition Audio vendor: PNY driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:10f1
Device-3: JMTek LLC. type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 4-1.6:5 chip ID: 0c76:1467 serial: <filter>
Sound Server: ALSA v: k5.6.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock
driver: r8169 v: kernel port: d000 bus ID: 05:00.0 chip ID: 10ec:8168
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 2.30 TiB used: 219.3 MiB (0.0%)
ID-1: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 6.0 Gb/s serial: <filter> rev: 40WD scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-07WN4A0 size: 931.51 GiB
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-00WN4A0 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-4: /dev/sdd type: USB vendor: Kingston model: DataTraveler 3.0
size: 28.88 GiB serial: <filter> rev: PMAP scheme: MBR
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 11.67 GiB used: 219.3 MiB (1.8%) fs: overlay source: ERR-102
label: N/A uuid: N/A
ID-2: /run/miso/bootmnt raw size: 2.91 GiB size: <root required>
used: <root required> fs: iso9660 dev: /dev/sdd1 label: MANJARO_KDE_2003
uuid: 2020-06-06-08-14-33-00
ID-3: /run/miso/sfs/desktopfs raw size: 1.69 GiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop2 label: N/A uuid: N/A
ID-4: /run/miso/sfs/livefs raw size: 20.8 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop0 label: N/A uuid: N/A
ID-5: /run/miso/sfs/mhwdfs raw size: 565.6 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop1 label: N/A uuid: N/A
ID-6: /run/miso/sfs/rootfs raw size: 596.1 MiB size: <root required>
used: <root required> fs: squashfs dev: /dev/loop3 label: N/A uuid: N/A
Unmounted: ID-1: /dev/sda1 size: 100.0 MiB fs: vfat label: N/A uuid: 7667-8077
ID-2: /dev/sda2 size: 16.0 MiB fs: <root required> label: N/A uuid: N/A
ID-3: /dev/sda3 size: 465.15 GiB fs: ntfs label: N/A uuid: 308A69048A68C844
ID-4: /dev/sda4 size: 505.0 MiB fs: ntfs label: N/A uuid: 4632C4FE32C4F449
ID-5: /dev/sdb1 size: 931.51 GiB fs: ntfs label: N/A uuid: AA943D7F943D4F57
ID-6: /dev/sdc1 size: 300.0 MiB fs: vfat label: N/A uuid: D8E0-CD32
ID-7: /dev/sdc2 size: 922.42 GiB fs: ext4 label: N/A
uuid: 0c95387f-2997-4fa3-9e8a-d7cd6e5bd932
ID-8: /dev/sdc3 size: 8.80 GiB fs: swap label: N/A
uuid: 9aed5cbc-9060-442a-a8d3-51bfccf72790
ID-9: /dev/sdd2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: 2265-C918
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:0024
Device-1: 1-1.3:3 info: Kingston DataTraveler 100 G3/G4/SE9 G2
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0951:1666 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-2: 4-1.1:3 info: Corsair type: Mouse,HID driver: hid-generic,usbhid
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 1b1c:1b5c serial: <filter>
Device-3: 4-1.2:4 info: Holtek type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 4 rev: 1.1 speed: 12 Mb/s chip ID: 04d9:a131
Device-4: 4-1.6:5 info: JMTek LLC. type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A gpu: nouveau temp: 46 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 0
Info: Processes: 227 Uptime: 38m Init: systemd v: 245 Compilers: gcc: 10.1.0
Shell: bash v: 5.0.17 running in: konsole inxi: 3.0.37
