Good day,
I have previously already complained that my bluetooth was not working. It happens quite regularly, but I managed to fix it by reinstalling “bluetooth-*” related packages or with a following commands.
Or with following commands:
# rmmod btusb
# rmmod btintel
# systemctl stop bluetooth.service
# modprobe btintel
# modprobe btusb
# systemctl start bluetooth.service
Unfortunately, bluetooth is not working again and non of those workaround are working for me anymore.
I would appreciate an advice. I found couple of places that seems strange.
Why is there a “no default controller” here?
bluetoothctl ✔
[bluetooth]# Agent registered
[bluetooth]# power on
No default controller available
[bluetooth]#
Or why I can find a device id here?
sudo dmesg | grep -i bluetooth
[ 7.671708] Bluetooth: Core ver 2.22
[ 7.671739] NET: Registered PF_BLUETOOTH protocol family
[ 7.671740] Bluetooth: HCI device and connection manager initialized
[ 7.671744] Bluetooth: HCI socket layer initialized
[ 7.671747] Bluetooth: L2CAP socket layer initialized
[ 7.671751] Bluetooth: SCO socket layer initialized
[ 7.692407] Bluetooth: hci0: Failed to claim iso interface
[ 7.717169] Bluetooth: hci0: Failed to get device id (-108)
[ 7.717178] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 7.786101] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.786104] Bluetooth: BNEP filters: protocol multicast
[ 7.786108] Bluetooth: BNEP socket layer initialized
Some other info:
rfkill list ✔
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
inxi - Fazy
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=683a8752-1b08-4f6c-9169-2a64c4a6c097 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=08e1c4f5-be58-4588-96af-118006cdff61 udev.log_priority=3
rtc_cmos.use_acpi_alarm=1 mem_sleep_default=s2idle
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell with: albert
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 83AA v: Yoga Slim 7 14APU8
serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 14APU8
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_83AA_BU_idea_FM_Yoga Slim 7 14APU8
uuid: <superuser required> UEFI: LENOVO v: M6CN38WW date: 11/16/2023
ID-1: BAT0 charge: 53.8 Wh (79.4%) condition: 67.8/70.0 Wh (96.8%)
power: 2.7 W volts: 16.8 min: 15.5 model: Celxpert L22C4PF7 type: Li-poly
serial: <filter> status: not charging cycles: 138
Info: model: AMD Ryzen 7 7840S with Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
microcode: 0xA704107
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1099 min/max: 400/5132 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1099 2: 1099 3: 1099
4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105436
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
affected
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Lenovo
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
bus-ID: c3:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 31.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:5293
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4189 built: 2022 res: 2944x1840 dpi: 240
gamma: 1.2 size: 312x195mm (12.28x7.68") diag: 368mm (14.5") ratio: 16:10
modes: max: 2944x1840 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi gfx1103_r1
LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:15bf
memory: 3.91 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: N/A device-ID: 1002:15bf
surfaces: xcb,xlib,wayland
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c3:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c3:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth2d4c303 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-5:3 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 953.87 GiB used: 256.69 GiB (26.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EL1QGXA7 temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
used: 256.68 GiB (27.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 7.6 MiB (2.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
ID-4: /var/log raw-size: 923.66 GiB size: 923.66 GiB (100.00%)
ID-1: swap-1 type: partition size: 29.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 40.5 C mobo: 40.0 C gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Memory: total: 28 GiB available: 27.19 GiB used: 1.6 GiB (5.9%)
Processes: 408 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
image: 10.85 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1606 pm: pacman pkgs: 1591 libs: 349 tools: gnome-software,pamac
pm: flatpak pkgs: 15 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9
running-in: ghostty inxi: 3.3.36
systemctl status bluetooth ✔
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sun 2025-01-05 01:00:22 CET; 2min 38s ago
Invocation: c6632fe2a88f488ea90e345d97fe3430
Docs: man:bluetoothd(8)
Main PID: 2722 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 33280)
Memory: 2M (peak: 2.5M)
CPU: 23ms
CGroup: /system.slice/bluetooth.service
└─2722 /usr/lib/bluetooth/bluetoothd
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support bap plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support bass plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support mcp plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support vcp plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support micp plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support ccp plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support csip plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: src/plugin.c:init_plugin() System does not support asha plugin
Jan 05 01:00:22 the-beast bluetoothd[2722]: Bluetooth management interface 1.23 initialized
