Some help needed a few days ago i had my bluetooth headphones connected and they started running out of battery (normally i would turn them off) so i turned on the other pair of headphones and got distorted sound out of them, restarted the laptop ever since then i cannot connect to bluetooth devices. What i have tried check the kernel is not 5.8, make sure the service is on, reloaded old time shift images, tried to connect different devices, install blueman, nothing has worked so looking on the google
inxi -Fazy
Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=8d1e2e78-8f42-442a-b16e-4d37b8c2a361 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <filter> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 58.3 Wh condition: 61.3/60.0 Wh (102%) volts: 17.2/15.4
model: Celxpert L19C4PC0 type: Li-poly serial: <filter> status: Unknown
cycles: 2
Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 L2 cache: 4096 KiB
bogomips: 92666
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1396 5: 1397 6: 1396 7: 1397 8: 1397 9: 1397
10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1396
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:1f95
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-3:2 chip ID: 13d3:56ff
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: amdgpu,modesetting,nouveau FAILED: ati alternate: fbdev,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.37.0 5.7.19-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.7 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10fa
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x bus ID: 05:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.19-2-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000
bus ID: 04:00.0 chip ID: 8086:2723
IF: wlp4s0 state: down mac: <filter>
Local Storage: total: 1.14 TiB used: 412.28 GiB (35.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HBHQ-000L2
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 3L1QEXH7 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LFM1 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 121.68 GiB (52.1%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 42.1 C mobo: N/A
GPU: device: amdgpu temp: 33 C device: nouveau temp: 25 C
Processes: 341 Uptime: 23m Memory: 15.07 GiB used: 2.79 GiB (18.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1343 lib: 363 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
sudo systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2020-09-22 20:44:49 NZST; 17s ago
Docs: man:bluetoothd(8)
Main PID: 2270 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18427)
Memory: 1.3M
CGroup: /system.slice/bluetooth.service
└─2270 /usr/lib/bluetooth/bluetoothd
Sep 22 20:44:49 borche-82b5 systemd[1]: Starting Bluetooth service...
Sep 22 20:44:49 borche-82b5 bluetoothd[2270]: Bluetooth daemon 5.54
Sep 22 20:44:49 borche-82b5 systemd[1]: Started Bluetooth service.
Sep 22 20:44:49 borche-82b5 bluetoothd[2270]: Starting SDP server
Sep 22 20:44:49 borche-82b5 bluetoothd[2270]: Bluetooth management interface 1.16 initialized
Sep 22 20:44:49 borche-82b5 bluetoothd[2270]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSink/sbc
Sep 22 20:44:49 borche-82b5 bluetoothd[2270]: Endpoint registered: sender=:1.43 path=/MediaEndpoint/A2DPSource/sbc
